Thread: Radio needs to come out to get info to obtain proper radio code. How can I get it out? |
New member Username: Mariajd
Bridgewater,
MA
Post Number: 1 Registered: Mar-09
| Posted on Sunday, March 08, 2009 - 03:41 pm: |
Unfortunately, I'm finding myself here because the battery died on my 2004 MB ML350 and I need a radio code too, who knew?! (I know it's a security feature but what a pain)! After reviewing some threads here I realize not only is the VIN necessary to obtain the code, but pertinent info about the radio itself ---Can I use a small tool to try to pop it out or do I need to trek all the way to the dealership? The radio is original to the car and it just says "Mercedes Benz" on the front, nothing more. Thanks in advance for any advice. |
Silver Member Username: Regrooster
Post Number: 648 Registered: Aug-08
| Posted on Sunday, March 08, 2009 - 05:49 pm: |
Have a look here http://www.fitaudio.com/index.php?CategoryID=22 |
Bridgewater,
MA
Post Number: 2 Registered: Mar-09
| Posted on Monday, March 09, 2009 - 10:42 am: |
Thanks for the link. The only 3 instructions listed there are for C-class not M-class and the radios/panels shown are completely different. Thanks for your response though, I do appreciate it just the same. |
Post Number: 651 Registered: Aug-08
| Posted on Monday, March 09, 2009 - 11:56 am: |
How about this then ? http://forums.mbworld.org/forums/m-class-w164/164542-w164-ml350-radio-comand-rem oval.html |
Bridgewater,
MA
Post Number: 3 Registered: Mar-09
| Posted on Tuesday, March 10, 2009 - 10:00 am: |
Thanks Reg Rooster. You've been kind and I am thankful. Would you believe when I went out to my car, the radio code was in the glove box (left in there from the first owner 4 years ago). I've since taken it out and placed it in safekeeping. And, oh, the code worked fine and I'm up and singing again. Thanks!! |
