Home > Message Board > Car Audio > Multimedia Systems > Vm9022 disable touch screen? please h...
Author Thread: Vm9022 disable touch screen? please help!
Username: Ign_5
Aurora, Co
Us
hello, I was showing a friend how easy ot was to change the brake code...and pressed setup and entered some numbers (not the right ones for the brake menu) and somehow disabled my touch screen....
I have tried pressing the reset button in the front, and that did nothing it was like i just turned it off and back on, so i unhooked it for about 2 hours, and when i went back to turn it on...my eq was still set and still no touch screen!!!
so I guess the question is, does anyone know how to turn back on the touch screen? or does anyone know how to do a hard reset, as if i never put power to it be4? please help!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Multimedia Systems > Vm9022 disable touch screen? please h... [ « Previous ] [ Next » ]
