Thread: Renault megane radio code |
Gold Member Username: Regrooster
Post Number: 1170 Registered: Aug-08
| Posted on Saturday, June 06, 2009 - 09:14 am: |
Jams New member Username: The_irritant Post Number: 2 Registered: Jun-09 Posted on Friday, June 05, 2009 - 07:26 am: -------------------------------------------------------------------------------- Hi i need help!!!!!!!!! I neet the code for a renault megane radio its a Philips - RN449FW4198701 hope you can help Cheers } ==================================================== Quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING. There should also be a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find ___________________________________________ |
Post Number: 1171 Registered: Aug-08
| Posted on Saturday, June 06, 2009 - 09:16 am: |
Thomas Hutton New member Username: Thutt UK Post Number: 2 Registered: May-09 Posted on Saturday, June 06, 2009 - 05:56 am: -------------------------------------------------------------------------------- Hi Reg Rooster. Not sure if you can help. After disconnection of my battery my radio requires a code which I don't have. Renault Philips Radiosat 6010 7700433943 Philips 22DC461/62P 9022 214 61628 PA4Bis 4x15w RDS FD 11 99 26 8014930 Model no. 22DC461/62P Prod no. 11992680K1930 mch 015287 ==================================================== Quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING. There should be a 14 character Serial Number beginning withGM or RG or RN or PH or similar ..usually found stamped in the metal casing. And maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find ___________________________________________ Reg Rooster, this is what I could find... RN461FX8014930 Thanks again Tom } ================================================== There should also be a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find |
New member Username: Terza
Post Number: 1 Registered: Jun-09
| Posted on Monday, June 08, 2009 - 01:02 pm: |
HI ... PLS help me, I need radio code for my Renault Megane 1998 PHILIPS 6010 7700 426 412 Y943 22DC459/62L 9022 214 59624 RN459FW4085222 HELP PLSSSSSS!!!! |
Post Number: 1191 Registered: Aug-08
| Posted on Monday, June 08, 2009 - 06:31 pm: |
Marko Terzic New member Username: Terza Post Number: 1 Registered: Jun-09 Posted on Monday, June 08, 2009 - 01:02 pm: -------------------------------------------------------------------------------- HI ... PLS help me, I need radio code for my Renault Megane 1998 PHILIPS 6010 7700 426 412 Y943 22DC459/62L 9022 214 59624 RN459FW4085222 ================================================================ Your code is 1044 |
New member Username: Umpire
| Posted on Tuesday, June 09, 2009 - 03:56 pm: |
Hi, hope you can help: Radio code for my Chrysler Voyager is lost after 3/4 motor replacement S/N TQAAA094739218 Date code 0947 Part Nr. P4704345-G Supplier 17719 Thanks in advance, umpire |
Post Number: 1204 Registered: Aug-08
| Posted on Tuesday, June 09, 2009 - 04:31 pm: |
"Segadlo New member Username: Umpire Post Number: 1 Registered: Jun-09 Posted on Tuesday, June 09, 2009 - 03:56 pm: -------------------------------------------------------------------------------- Hi, hope you can help: Radio code for my Chrysler Voyager is lost after 3/4 motor replacement S/N TQAAA094739218 Date code 0947 Part Nr. P4704345-G Supplier 17719 Thanks in advance, umpire =================================================== CHRYSLER do not make radios .They only affix their badge onto radios made by the large manufacturers (ALPINE , CLARION etc). This radio is made by ALPINE and unfortunately the code is not available for free from anywhere on the Internet. Main Dealer or a Decoding Service only |
New member Username: Aymen_a22
Uk
| Posted on Friday, June 12, 2009 - 09:32 am: |
Hi, Please could someone help with the radio code? All the numbers from the unit are here. Model no: 22DC593/62L Prod No: FD0597254185995 RN593FV4185995 Other numbers: 9022 215 93624 77 00 413 537 M/ch: 184942 M 36 C 106 3111 186 94130 Thanks very much again |
Post Number: 1219 Registered: Aug-08
| Posted on Friday, June 12, 2009 - 11:17 am: |
Aymen Al-Sheikhly New member Username: Aymen_a22 Uk Post Number: 2 Registered: May-09 Posted on Friday, June 12, 2009 - 09:32 am: -------------------------------------------------------------------------------- Hi, Please could someone help with the radio code? All the numbers from the unit are here. Model no: 22DC593/62L Prod No: FD0597254185995 RN593FV4185995 Other numbers: 9022 215 93624 77 00 413 537 M/ch: 184942 M 36 C 106 3111 186 94130 -------------------------------------------------------------------------------- --------- Sorry ...not in my database Try emailing restoredclassic@aol.com to see if they can help. Mention this Foruum |
New member Username: Zequino
| Posted on Sunday, June 14, 2009 - 05:10 pm: |
Help me I need radio code for my Renault Scenic Car radio: GAMME RADIOSAT MODEL No: 22DC259/62P PROD No: FD0501390308032 Others No:TOW 353 RN 259F10308032 TW 353 7700 434 424 |
Post Number: 1232 Registered: Aug-08
| Posted on Sunday, June 14, 2009 - 08:21 pm: |
joaquim bras New member Username: Zequino Post Number: 1 Registered: Jun-09 Posted on Sunday, June 14, 2009 - 05:10 pm: -------------------------------------------------------------------------------- Help me I need radio code for my Renault Scenic Car radio: GAMME RADIOSAT MODEL No: 22DC259/62P PROD No: FD0501390308032 Others No:TOW 353 RN 259F10308032 TW 353 7700 434 424 ====================================== Try code 3623 |
New member Username: Ramoncitos
| Posted on Monday, June 15, 2009 - 01:22 pm: |
Hi!! Please, I need your help, because I lost code radio My car: Renault Megane 1998 Radio: Philips 22DC594/72B 9022 215 94721 Prod. No. FD0096331000762 RN594FT1000762 Thanks for your help!! Ron |
Post Number: 1237 Registered: Aug-08
| Posted on Monday, June 15, 2009 - 03:49 pm: |
Ronald Romano New member Username: Ramoncitos Post Number: 1 Registered: Jun-09 Posted on Monday, June 15, 2009 - 01:22 pm: -------------------------------------------------------------------------------- Hi!! Please, I need your help, because I lost code radio My car: Renault Megane 1998 Radio: Philips 22DC594/72B 9022 215 94721 Prod. No. FD0096331000762 RN594FT1000762 ============================================== Your code is 8711 |
| Posted on Monday, June 15, 2009 - 04:31 pm: |
Thank´s for your help you´re the best Ron |
| Posted on Monday, June 15, 2009 - 06:04 pm: |
Thank´s for your help code ok  |
New member Username: Jensower
| Posted on Wednesday, June 17, 2009 - 12:01 pm: |
Hello, Please, I need your help, I lost my code radio too... My car is a Megane 2000 The radio is a Philips 22DC461/72T 9022 214 61726 Prod. No. FD1100366003688 RN461FY6003688 Thanks |
Post Number: 1249 Registered: Aug-08
| Posted on Wednesday, June 17, 2009 - 01:31 pm: |
dominique duconseil New member Username: Jensower Post Number: 1 Registered: Jun-09 Posted on Wednesday, June 17, 2009 - 12:01 pm: -------------------------------------------------------------------------------- Hello, Please, I need your help, I lost my code radio too... My car is a Megane 2000 The radio is a Philips 22DC461/72T 9022 214 61726 Prod. No. FD1100366003688 RN461FY6003688 ================================================= Sorry ...not in my database |
New member Username: Beduinhio
| Posted on Thursday, June 18, 2009 - 01:40 pm: |
Hi All Can You uncode my radio? my car is Megane 2001 Radio: Philips Model NO: 22DC259/62T TOW963 RN259F13563188 Prod. NO: FD0501373563188 Thanks a lot! |
Post Number: 1261 Registered: Aug-08
| Posted on Thursday, June 18, 2009 - 02:00 pm: |
mr beduin New member Username: Beduinhio Post Number: 1 Registered: Jun-09 Posted on Thursday, June 18, 2009 - 01:40 pm: -------------------------------------------------------------------------------- Hi All Can You uncode my radio? my car is Megane 2001 Radio: Philips Model NO: 22DC259/62T TOW963 RN259F13563188 Prod. NO: FD0501373563188 ================================================== Sorry...Not in my database |
New member Username: Aidy12
| Posted on Saturday, June 20, 2009 - 06:56 am: |
Hi can you please provide code for 05 megane radio , please see pic , thanks in advance
Silver Member Username: Decode
POLAND
Post Number: 193 Registered: Jan-09
| Posted on Saturday, June 20, 2009 - 07:54 am: |
mr beduin ------> code 3044 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
POLAND
Post Number: 194 Registered: Jan-09
| Posted on Saturday, June 20, 2009 - 07:55 am: |
aidy mee ------> code 2470 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: Loonball
| Posted on Saturday, June 20, 2009 - 09:44 am: |
hi could you help me with my radio code Radiosat 4000 7700 426 414 Philips 22DC449/62L Prod No. FD 04 97 44 4056290 another thing, i can't figure out how to input the code, any ideas? Many Thanks chaps. |
New member Username: Helenka
| Posted on Saturday, June 20, 2009 - 10:17 am: |
HI ... PLS help me, I need radio code for my Renault Megane. TOL371 RN279f20238022 PROD No: FD0402380238022 Model: 22DC279/62T many thanks in advance. Helen |
Post Number: 3 Registered: Jun-09
| Posted on Saturday, June 20, 2009 - 10:50 am: |
Post Number: 1276 Registered: Aug-08
| Posted on Saturday, June 20, 2009 - 10:57 am: |
New member Username: Loonball Post Number: 1 Registered: Jun-09 Posted on Saturday, June 20, 2009 - 09:44 am: -------------------------------------------------------------------------------- hi could you help me with my radio code Radiosat 4000 7700 426 414 Philips 22DC449/62L Prod No. FD 04 97 44 4056290 another thing, i can't figure out how to input the code, any ideas? =================================================== Try emailing here for free advice restoredclassic@aol.com Mention this forum |
Post Number: 1277 Registered: Aug-08
| Posted on Saturday, June 20, 2009 - 10:59 am: |
ELENA New member Username: Helenka Post Number: 2 Registered: Jun-09 Posted on Saturday, June 20, 2009 - 10:17 am: -------------------------------------------------------------------------------- HI ... PLS help me, I need radio code for my Renault Megane. TOL371 RN279f20238022 PROD No: FD0402380238022 Model: 22DC279/62T many thanks in advance. ======================================================== Your code is 3388 |
| Posted on Saturday, June 20, 2009 - 02:02 pm: |
as per above would you be able to tell me what the code is? thanks about the other thing though |
Post Number: 1282 Registered: Aug-08
| Posted on Saturday, June 20, 2009 - 03:09 pm: |
lindsay New member Username: Loonball Post Number: 2 Registered: Jun-09 Posted on Saturday, June 20, 2009 - 02:02 pm: -------------------------------------------------------------------------------- as per above would you be able to tell me what the code is? thanks about the other thing though =================================================== Sorry ....not in my database. |
New member Username: Del123
| Posted on Sunday, June 21, 2009 - 06:23 am: |
I changed my battery and lost my radio code for my Megane. Can any one help? Details Model No: 22DC277/62 TG927 RN277F3059358 ProdNo:FD0303480359358 Thank You Del |
POLAND
Post Number: 202 Registered: Jan-09
| Posted on Sunday, June 21, 2009 - 06:56 am: |
AK wert ------> code 5227 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: Pavelthegoalie
| Posted on Sunday, June 21, 2009 - 05:51 pm: |
Hi can anyone help me with a code for my megane radio, got a long drive coming up and could really do with the radio for company model no 22DC277/62 RN277F40399967 PROD NO FD0304030399967 SERIAL 8200256141TM158 Thanks in advance David |
Post Number: 1287 Registered: Aug-08
| Posted on Sunday, June 21, 2009 - 05:58 pm: |
New member Username: Pavelthegoalie Post Number: 1 Registered: Jun-09 Posted on Sunday, June 21, 2009 - 05:51 pm: Hi can anyone help me with a code for my megane radio, got a long drive coming up and could really do with the radio for company model no 22DC277/62 RN277F40399967 PROD NO FD0304030399967 SERIAL 8200256141TM158 Thanks in advance ================================================== Your code is 1735 |
New member Username: Scenic
| Posted on Monday, June 22, 2009 - 03:41 pm: |
incredible Reg Rooster, is there still really a chance to get that code ?! I won't believe that it might bo so easy. So you'll need all the numbers on the radio, right ? It is a Renault Scenic II, so all I have to do is to pull the radio out ? thx ! |
| Posted on Monday, June 22, 2009 - 03:58 pm: |
ok - brute force ! I opened a cold bottle of Zywiec (no joke) and just pulled the radio out ! It worked very fine and easy. May I really post the numbers ? Model# RENRDW 132-10 TOK 874 RNRD0430026591 prod# FD0203390026591 8200300859TK874 8200300859 --- I am so excited ! greetings |
POLAND
Post Number: 205 Registered: Jan-09
| Posted on Monday, June 22, 2009 - 06:01 pm: |
Weber ------> code 4347 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
Post Number: 1290 Registered: Aug-08
| Posted on Monday, June 22, 2009 - 06:04 pm: |
New member Username: Scenic Post Number: 2 Registered: Jun-09 Posted on Monday, June 22, 2009 - 03:58 pm: ok - brute force ! I opened a cold bottle of Zywiec (no joke) and just pulled the radio out ! It worked very fine and easy. May I really post the numbers ? Model# RENRDW 132-10 TOK 874 RNRD0430026591 prod# FD0203390026591 8200300859TK874 8200300859 ==================================================================== Your code is 4347 |
| Posted on Monday, June 22, 2009 - 06:45 pm: |
ok guys, you are incredible. I got the code twice of two sources and guess... of course both were right: it works again ! I'll be abroad the next days (nice work in nice Brazil) but I will remember the beer donation and will take action as soon as I will be back. Thanx a lot, cu soon. Weber - Germany |
New member Username: Vranik
| Posted on Wednesday, June 24, 2009 - 10:07 am: |
hi, could i get code number for my radio please? here are every numbers which i found: RENAULT <276> RADIOSTAT 6010 700 426 412 PHILIPS 22DC459/62L 9022 214 59624 7700 426212 426 412 T800 FD 05 97 48 4021872 MODEL NO: 22DC45Ã/62L PROD NO: FD 0597484021872 Code Gravage: 4021872 RN459FV4021872 Thank you very much, vranik, Czech Republic |
POLAND
Post Number: 212 Registered: Jan-09
| Posted on Wednesday, June 24, 2009 - 12:37 pm: |
Mirek Vrana------> code 6168 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: Ampp
| Posted on Wednesday, June 24, 2009 - 06:53 pm: |
Hi can you please provide code for 06 megane ii radio , please see pic , thanks in advance  |
| Posted on Wednesday, June 24, 2009 - 06:56 pm: |
Sorry!!, please see the new pic |
Post Number: 1303 Registered: Aug-08
| Posted on Wednesday, June 24, 2009 - 07:27 pm: |
maurcio paez New member Username: Ampp Post Number: 1 Registered: Jun-09 06 Megane ===================================================== Try code 8540 |
New member Username: Hummer_boy
| Posted on Thursday, June 25, 2009 - 04:45 am: |
hi, could i get code number for my radio please? MODEL NO: 22DC279/62 R402 SECURITY SERIAL NO: RN279F30274580 PROD NO: FD0703520274580 7700433948TR402 7700 433 948 --E |
New member Username: Voxxs
| Posted on Thursday, June 25, 2009 - 07:56 pm: |
help me please i need code for my radio philips"Renault Scenic" Model: 22DC942/72 Prod.no:FDO497269015180 thanks a lot |
Post Number: 1309 Registered: Aug-08
| Posted on Friday, June 26, 2009 - 04:46 pm: |
r: 2 Registered: Jun-09 Posted on Thursday, June 25, 2009 - 07:56 pm: help me please i need code for my radio philips"Renault Scenic" Model: 22DC942/72 Prod.no:FDO497269015180 ----------------------------------------------------------------- Ask here for free advice +code restoredclassic@aol.com Mention this forum |
Post Number: 1310 Registered: Aug-08
| Posted on Friday, June 26, 2009 - 04:48 pm: |
hael ivanovich New member Username: Hummer_boy Post Number: 1 Registered: Jun-09 Posted on Thursday, June 25, 2009 - 04:45 am: hi, could i get code number for my radio please? MODEL NO: 22DC279/62 R402 SECURITY SERIAL NO: RN279F30274580 PROD NO: FD0703520274580 7700433948TR402 7700 433 948 --E ------------------------------------------------------------------- Try code 8523 |
New member Username: Crishti
Craiova,
Romania
Romania
| Posted on Saturday, June 27, 2009 - 04:46 am: |
hello i need help could i get code number for my radio please? MODEL NO: 22DC279/62 F SERIAL NO: RN279F50223755 PROD NO: FD1205250223755 8200029541TD767 8200029541 --F |
Post Number: 1326 Registered: Aug-08
| Posted on Saturday, June 27, 2009 - 08:53 am: |
ra cristian New member Username: Crishti Craiova, Romania Romania Post Number: 1 Registered: Jun-09 Posted on Saturday, June 27, 2009 - 04:46 am: hello i need help could i get code number for my radio please? MODEL NO: 22DC279/62 F SERIAL NO: RN279F50223755 PROD NO: FD1205250223755 8200029541TD767 8200029541 --F --------------------------------------------------------------- Try code 0082 |
New member Username: Alwin
| Posted on Sunday, June 28, 2009 - 11:32 am: |
Hello All! After new battery on my megane i need a radio code.can anybody help please! Model No: 22DC259/62T TOL 222 RN259F13589258 Prod No: FD0501473589258 7700434422TL222 |
| Posted on Sunday, June 28, 2009 - 11:42 am: |
| Posted on Sunday, June 28, 2009 - 12:07 pm: |
New member Username: Aauriss
| Posted on Sunday, June 28, 2009 - 02:15 pm: |
hello, please hellp me, because one yer i can't listten to the radio, and i was enter the code tree times, and after 4 times it will block at all.. RADIOSAT 6010 7700 433 072 W324 PHILIPS 22DC461/62L 9022 214 61624 FD 09 98 39 4038544 MODEL NO: 22DC461/62L PROD NO: FD 0998394038544 THANK YOU WERY MUCH |
Post Number: 1334 Registered: Aug-08
| Posted on Monday, June 29, 2009 - 08:11 am: |
Szpisjak Gyorgy New member Username: Alwin Post Number: 3 Registered: Jun-09 Posted on Sunday, June 28, 2009 - 12:07 pm: Hello All! After new battery on my megane i need a radio code.can anybody help please! Model No: 22DC259/62T TOL 222 RN259F13589258 Prod No: FD0501473589258 7700434422TL222 ================================================ Try code 3583 |
| Posted on Monday, June 29, 2009 - 09:05 am: |
please tell me the code, i can pay if you need RADIOSAT 6010 7700 433 072 W324 PHILIPS 22DC461/62L 9022 214 61624 FD 09 98 39 4038544 MODEL NO: 22DC461/62L PROD NO: FD 0998394038544 |
Post Number: 4 Registered: Jun-09
| Posted on Monday, June 29, 2009 - 02:23 pm: |
Dear Reg Rooser! Thank you ever so much!!!!!!!! Alwin Hungary Békéscsaba} |
Post Number: 1342 Registered: Aug-08
| Posted on Monday, June 29, 2009 - 03:46 pm: |
s New member Username: Aauriss Post Number: 2 Registered: Jun-09 Posted on Monday, June 29, 2009 - 09:05 am: please tell me the code, i can pay if you need RADIOSAT 6010 7700 433 072 W324 PHILIPS 22DC461/62L 9022 214 61624 FD 09 98 39 4038544 MODEL NO: 22DC461/62L PROD NO: FD 0998394038544 ---------------------------------------------------------------- Duplicate post...already answered ! |
New member Username: Attila_zsedely
| Posted on Tuesday, June 30, 2009 - 11:19 am: |
after new battery on my Megane 2005. I need a radio code. Can anybody help please? Thanks!
Post Number: 1351 Registered: Aug-08
| Posted on Tuesday, June 30, 2009 - 11:34 am: |
ly New member Username: Attila_zsedely Post Number: 1 Registered: Jun-09 Posted on Tuesday, June 30, 2009 - 11:19 am: after new battery on my Megane 2005. I need a radio code. Can anybody help please? Thanks ==================================== Your code is 8291 |
New member Username: Tietsje
| Posted on Tuesday, June 30, 2009 - 04:19 pm: |
Can you also help me with this renault radio? modelnr RENRDW133-10 ProdNr FD0003210003267 RNRD0530003267 T0G837 |
New member Username: 86jeba
Post Number: 1 Registered: Jul-09
| Posted on Wednesday, July 01, 2009 - 12:08 pm: |
Hi can anyone help, i have 97 renault megane scenic and need radio code. Model no- 22DC593/62L Prod no- FD0297144123542 Other no- 902221593624 If any1 could help be very grateful. Thanks |
New member Username: Amandamalone
Post Number: 2 Registered: Jul-09
| Posted on Wednesday, July 01, 2009 - 05:43 pm: |
Hi Can anyone help? Renault Megane Model No 22DC277/62 TOR027 RN277F30086390 Prod No FD0103010086390 8200256141--C TR027 I have (stupidly) paid another few people for codes before getting them and then the codes not working! Needless to say they are now not refuding me my payment! I'm hoping that you can help me with the correct code, or at least tell me that you can't get it! Regards |
Post Number: 1355 Registered: Aug-08
| Posted on Wednesday, July 01, 2009 - 06:51 pm: |
New member Username: Amandamalone Post Number: 2 Registered: Jul-09 Posted on Wednesday, July 01, 2009 - 05:43 pm: Hi Can anyone help? Renault Megane Model No 22DC277/62 TOR027 RN277F30086390 Prod No FD0103010086390 8200256141--C TR027 I have (stupidly) paid another few people for codes before getting them and then the codes not working! Needless to say they are now not refuding me my payment! I'm hoping that you can help me with the correct code, or at least tell me that you can't get it! Regards =================================== Duplicate post ! |
Post Number: 1356 Registered: Aug-08
| Posted on Wednesday, July 01, 2009 - 06:55 pm: |
mes New member Username: 86jeba Post Number: 1 Registered: Jul-09 Posted on Wednesday, July 01, 2009 - 12:08 pm: Hi can anyone help, i have 97 renault megane scenic and need radio code. Model no- 22DC593/62L Prod no- FD0297144123542 Other no- 902221593624 If any1 could help be very grateful. Thanks ============================================= Insufficient information Please post all the letters+numbers on your radio |
Post Number: 1357 Registered: Aug-08
| Posted on Wednesday, July 01, 2009 - 06:59 pm: |
theo iets New member Username: Tietsje Post Number: 1 Registered: Jun-09 Posted on Tuesday, June 30, 2009 - 04:19 pm: Can you also help me with this renault radio? modelnr RENRDW133-10 ProdNr FD0003210003267 RNRD0530003267 T0G837 ============================== Try code 5553 |
New member Username: Sa_wolf
South Africa
| Posted on Thursday, July 02, 2009 - 01:42 am: |
Good day I have the same problem as many others Removed my 97' renault megane's battery and dont have the radio code, any help will be appreciated. Phillips 22DC594/62F FD 0096 45 3027441 7700413 538 X872 9022 215 9467441 There is also a "276" inside a Renault badge shape Thanks in advance |
Post Number: 1360 Registered: Aug-08
| Posted on Friday, July 03, 2009 - 05:18 am: |
tephen New member Username: Sa_wolf South Africa Post Number: 1 Registered: Jul-09 Posted on Thursday, July 02, 2009 - 01:42 am: Good day I have the same problem as many others Removed my 97' renault megane's battery and dont have the radio code, any help will be appreciated. Phillips 22DC594/62F FD 0096 45 3027441 7700413 538 X872 9022 215 9467441 There is also a "276" inside a Renault badge shape ==================================== Sorry...not in my database |
New member Username: Marco_mark
| Posted on Sunday, July 05, 2009 - 01:44 pm: |
Hi, same problem as many others removed my 2001 renault megane's battery and now need a code... Forgot... Phillips 22DC279/62t prod no- FD 0301140114243 serial no- RN279F10114243 security no-TOU203 security no on the right-7700434423TU203 |7700 434 423|---| Thanks for help in advance!!! |
Post Number: 1377 Registered: Aug-08
| Posted on Sunday, July 05, 2009 - 07:13 pm: |
New member Username: Marco_mark Post Number: 1 Registered: Jul-09 Posted on Sunday, July 05, 2009 - 01:44 pm: Hi, same problem as many others removed my 2001 renault megane's battery and now need a code... Forgot... Phillips 22DC279/62t prod no- FD 0301140114243 serial no- RN279F10114243 security no-TOU203 security no on the right-7700434423TU203 |7700 434 423|---| ===================================== Try code 5753 |
South Africa
| Posted on Monday, July 06, 2009 - 01:25 am: |
I also found the serial no. engraved in the casing if that may help: RN594FT3027441 Good day I have the same problem as many others Removed my 97' renault megane's battery and dont have the radio code, any help will be appreciated. Phillips 22DC594/62F FD 0096 45 3027441 7700413 538 X872 9022 215 9467441 There is also a "276" inside a Renault badge shape Thanks in advance} |
New member Username: Oakim
| Posted on Monday, July 06, 2009 - 12:44 pm: |
In need code too! See image.
New member Username: Pieeki
| Posted on Monday, July 06, 2009 - 12:46 pm: |
hallo, please help me, my car battery is dead and i got problem with my radio renaul scenic 2.0 dci 2002 model No: 22DC278/62R TOG132 RN278F20010187 prod No: FD0102230010187 8200150474TG132 thanx a lot |
Post Number: 1392 Registered: Aug-08
| Posted on Thursday, July 09, 2009 - 10:30 am: |
lukas bartkowiak New member Username: Pieeki Post Number: 1 Registered: Jul-09 Posted on Monday, July 06, 2009 - 12:46 pm: hallo, please help me, my car battery is dead and i got problem with my radio renaul scenic 2.0 dci 2002 model No: 22DC278/62R TOG132 RN278F20010187 prod No: FD0102230010187 8200150474TG132 thanx a lot ==================================== Try 1515 |
New member Username: Adel44
| Posted on Monday, July 20, 2009 - 03:28 pm: |
hi have lost code for radio please help renault scenic model no: 22dc259/62p prod no:fd0501450324092 tog714 rn259f10324092 hope you can help thanks |
New member Username: Nutte
Post Number: 3 Registered: Feb-09
| Posted on Tuesday, July 21, 2009 - 07:34 pm: |
I have a renault megane 02 fidji? same old story battery was removed and code was lost! could someone please give me the code? Serial NO/ RN278F20029937 Sec code/ 4TQ785 Thanks |
Post Number: 5 Registered: Feb-09
| Posted on Tuesday, July 21, 2009 - 07:36 pm: |
Post Number: 1464 Registered: Aug-08
| Posted on Wednesday, July 22, 2009 - 09:17 am: |
adelheid read New member Username: Adel44 Post Number: 1 Registered: Jul-09 Posted on Monday, July 20, 2009 - 03:28 pm: hi have lost code for radio please help renault scenic model no: 22dc259/62p prod no:fd0501450324092 tog714 rn259f10324092 hope you can help thanks ============================================ Try code 5876 |
Post Number: 1465 Registered: Aug-08
| Posted on Wednesday, July 22, 2009 - 09:19 am: |
Carlk New member Username: Nutte Post Number: 3 Registered: Feb-09 Posted on Tuesday, July 21, 2009 - 07:34 pm: I have a renault megane 02 fidji? same old story battery was removed and code was lost! could someone please give me the code? Serial NO/ RN278F20029937 Sec code/ 4TQ785 ===================================== Try code 9246 |
| Posted on Friday, July 24, 2009 - 02:57 am: |
hi thanks for the code tried it today and it didnt work sorry to say ... please could u try again or give me any info on where i can get the code many thanks |
New member Username: Johnny_hotrod
| Posted on Sunday, July 26, 2009 - 12:26 pm: |
Help !! Just bought a Renault Megane Fidji for the wife, which she's pleased with apart from no working cd player. Previous owner changed the battery but didn't know the stereo code. Anyone out there help ? Model No. 22DC279/62T product no. FD0402230210700 TOQ391 RN279F20210700 7700434423TQ391 7700 434 423 5 05 29 N No idea if you need all the info above but too much is better than too little, right ? Bot the wife and myself thank you in advance for any help you can provide |
Post Number: 1504 Registered: Aug-08
| Posted on Wednesday, July 29, 2009 - 09:52 am: |
imon ring New member Username: Johnny_hotrod Post Number: 2 Registered: Jul-09 Posted on Sunday, July 26, 2009 - 12:26 pm: Help !! Just bought a Renault Megane Fidji for the wife, which she's pleased with apart from no working cd player. Previous owner changed the battery but didn't know the stereo code. Anyone out there help ? Model No. 22DC279/62T product no. FD0402230210700 TOQ391 RN279F20210700 7700434423TQ391 7700 434 423 =================================== Duplicate request....ALREADY ANSWERED ! |
Post Number: 1505 Registered: Aug-08
| Posted on Wednesday, July 29, 2009 - 09:54 am: |
adelheid read New member Username: Adel44 Post Number: 2 Registered: Jul-09 Posted on Friday, July 24, 2009 - 02:57 am: hi thanks for the code tried it today and it didnt work sorry to say ... please could u try again or give me any info on where i can get the code many thanks ============================================== The code quoted 5876 is the correct code using the information given |
New member Username: Ademea
Scotland
| Posted on Thursday, July 30, 2009 - 09:17 am: |
Hi there So nice for someone to be so helpful free of charge makes a difference, was wondering if you could find my code also if ok, friends car broke down used my bat to charge his reset my radio.
New member Username: Mott
| Posted on Thursday, July 30, 2009 - 10:06 am: |
I have lost code for radio please help - scenic 2004: renault cd-radio RENRDW131-10 8200 300 858 T J473 FD 0604360195200 RNRD0340195200 I hope you can help, thanks |
Post Number: 1528 Registered: Aug-08
| Posted on Thursday, July 30, 2009 - 11:11 am: |
Chris New member Username: Ademea Scotland Post Number: 1 Registered: Jul-09 Posted on Thursday, July 30, 2009 - 09:17 am: Hi there So nice for someone to be so helpful free of charge makes a difference, was wondering if you could find my code also if ok, friends car broke down used my bat to charge his reset my radio. ==================================== Sorry...not in my database |
Post Number: 1529 Registered: Aug-08
| Posted on Thursday, July 30, 2009 - 11:12 am: |
omasz New member Username: Mott Post Number: 1 Registered: Jul-09 Posted on Thursday, July 30, 2009 - 10:06 am: I have lost code for radio please help - scenic 2004: renault cd-radio RENRDW131-10 8200 300 858 T J473 FD 0604360195200 RNRD0340195200 ==================================== Try code 7196
Scotland
| Posted on Thursday, July 30, 2009 - 11:23 am: |
Thank you for trying Reg Rooster .... Any ideas were I might find it?, miss my music >.<. "its an older renault clio Y reg if any help or if need any other details" ----------------------------------------------------- Model No: 22DC259/62F T0F205 RN259F10305804 PROD NO: FD0401030305804 8200029539TF205 8200 029 539 ----------------------------------------------------- |
Post Number: 1531 Registered: Aug-08
| Posted on Thursday, July 30, 2009 - 11:31 am: |
Try emailing here restoredclassic@aol.com and see if they can help Mention this forum |
Scotland
Post Number: 3 Registered: Jul-09
| Posted on Thursday, July 30, 2009 - 11:34 am: |
Thanks again will try ... ^.^ |
New member Username: Thonil
| Posted on Friday, July 31, 2009 - 11:53 am: |
hello, i need a code for my renault clio stereo, battery died on me. not sure what numbers are necessary so here are the ones i have: VF1BBEB0F23923753 8200084449 7700416199C thanks in advance |
Post Number: 1540 Registered: Aug-08
| Posted on Friday, July 31, 2009 - 02:24 pm: |
Username: Thonil Post Number: 1 Registered: Jul-09 Posted on Friday, July 31, 2009 - 11:53 am: hello, i need a code for my renault clio stereo, battery died on me. not sure what numbers are necessary so here are the ones i have: VF1BBEB0F23923753 8200084449 7700416199C =================================== Insufficient information Try emailing here restoredclassic@aol.com for advice Mention this forum |
New member Username: Spreizwinkel
Post Number: 1 Registered: Aug-09
| Posted on Sunday, August 02, 2009 - 05:05 am: |
Need code for: RNRD0430034988 FD0203450034988 TK628 Many thanks in advance |
New member Username: Mewiggy
| Posted on Monday, August 03, 2009 - 04:30 pm: |
Hello, My battery recently died, would be very grateful if someone could sort me out with a code :D Numbers off stereo. Philips radiosat 4000 VIN: RN451FW2014385 MODEL No: 22Dc451/62E PROD No: FD 0898382014385 OTHERS: 276 7700 433 073 9022 214 51622 PA2, 2*8W, RDS 08 98 38 2014385 2014385 7700 433 073 K382 Thanks in advance!! ********************************************************** |
New member Username: Richard10
Post Number: 4 Registered: Aug-09
| Posted on Tuesday, August 04, 2009 - 08:04 am: |
ahoj, mozes mi pomoct najt CODE na autoradio Renault radiosat 6000. 7700 433 070 PHILIPS 22DC481/62 PA5, 4*15W,RDS NO CD CHANGER CONTROL 7700 433 070 FD 11 99 15 9164694 MODEL NO: 22DC481/62 PROD NO: FD 1199159164694 CODE GRAVAGE 9164694 A NA BOKU TO MA 90222148162 22DC481/62 M/ch:164516 |
New member Username: Adambor
| Posted on Wednesday, August 05, 2009 - 06:40 am: |
Can everyone help me. I loose my code to Renault Megane 1997. Radio Phillips. Model NO : 22DC449/62L RN449FV4009890 FD 00 97 30 4009890 7700 426 414 U773 Thanks ! |
New member Username: Fjm1986
| Posted on Thursday, August 06, 2009 - 08:25 am: |
hi there can anyone help iv just got a 2004 meganesport and the radio is askin for a code the numders on the radio are as follows model no : RENRDW134-00 security : E733 RNRD1040001447 prod no : FD0304140001447 would love if someone could help me out cheers frase |
New member Username: Johnny2009
| Posted on Saturday, August 08, 2009 - 06:47 am: |
pls code F965 7700434436TF965 22DC259/62 |
New member Username: Wojtek32
| Posted on Sunday, August 09, 2009 - 06:26 am: |
help me I need radio code for my Renault Megane 1997 model: 22DC459/62F prod: FD0097273000376 RN459FV3000376 7700426413P160 |
New member Username: Daniel23
Post Number: 2 Registered: Aug-09
| Posted on Sunday, August 09, 2009 - 11:53 am: |
Hello Help my same problem, need the code for my Renault Mod No.22DC277/62 N928 Security RN277F40573534 8200256141 8200256141TN928 FD0604280573534 |
New member Username: Jnn1
| Posted on Sunday, August 09, 2009 - 01:35 pm: |
Hi! Need some help with the radio in my Megane 1997 Mod No: 22DC594/62F Prod no: fd0397133060114 RN594FV3060114 Many thanks! Johan |
Post Number: 1563 Registered: Aug-08
| Posted on Sunday, August 09, 2009 - 06:20 pm: |
johan nilsson New member Username: Jnn1 Post Number: 1 Registered: Aug-09 Posted on Sunday, August 09, 2009 - 01:35 pm: Hi! Need some help with the radio in my Megane 1997 Mod No: 22DC594/62F Prod no: fd0397133060114 RN594FV3060114 Many thanks! Johan =================================== Sorry...not in my database Try asking here to see if they can help restoredclassic@aol.com Mention this forum |
New member Username: Xxmiroxx
| Posted on Thursday, August 13, 2009 - 06:01 pm: |
Renault Philips RADIOSAT 6010. label Radiosat 6010 7700 426 412 Philips 22DC459/62L 9022 214 59624 PROD NO: FD 07 98 18 4123603 Many thanks! |
Post Number: 1627 Registered: Aug-08
| Posted on Friday, August 14, 2009 - 09:47 am: |
Mirek Z. New member Username: Xxmiroxx Post Number: 1 Registered: Aug-09 Posted on Thursday, August 13, 2009 - 06:01 pm: Renault Philips RADIOSAT 6010. label Radiosat 6010 7700 426 412 Philips 22DC459/62L 9022 214 59624 PROD NO: FD 07 98 18 4123603 ================================== Post the 14 character Serial Number beginning with PH or RG or RN (often found stamped in the metal casing) |
Post Number: 3 Registered: Aug-09
| Posted on Friday, August 14, 2009 - 11:00 am: |
Renault Philips RADIOSAT 6010. label Radiosat 6010 7700 426 412 Philips 22DC459/62L 9022 214 59624 PROD NO: FD 07 98 18 4123603 RN 459FW4123603 Many THANKS!! |
Post Number: 1629 Registered: Aug-08
| Posted on Friday, August 14, 2009 - 11:21 am: |
Mirek Z. New member Username: Xxmiroxx Post Number: 3 Registered: Aug-09 Posted on Friday, August 14, 2009 - 11:00 am: Renault Philips RADIOSAT 6010. label Radiosat 6010 7700 426 412 Philips 22DC459/62L 9022 214 59624 PROD NO: FD 07 98 18 4123603 RN 459FW4123603 Many THANKS!! ================================= Try code 6072 |
| Posted on Friday, August 14, 2009 - 12:14 pm: |
Renault Philips RADIOSAT 6010. label Radiosat 6010 7700 426 412 Philips 22DC459/62L 9022 214 59624 PROD NO: FD 07 98 18 4123603 RN 459FW4123603 WORK!!! You are THE MASTER!!! |
New member Username: Helpmepleaseeeeee
| Posted on Monday, August 17, 2009 - 01:50 pm: |
Hello I need the code for my Renault Megane Sedan Model NO: 22DC277/62 R541 Security RN277F40436143 PROD NO: FD0304090436143
Can you help me? Thank you very much! |
New member Username: Shortatall
| Posted on Monday, August 17, 2009 - 07:08 pm: |
Hi I would appreciate radio code for my renault megane 2004 as recently fitted a new battery and lost the code. Model no: 22DC277/62 G478 Security RN277F40525938 PROD no: FD0504210525938 Thanks in advance. |
Post Number: 1662 Registered: Aug-08
| Posted on Thursday, August 20, 2009 - 05:16 am: |
Shortatall New member Username: Shortatall Post Number: 1 Registered: Aug-09 Posted on Monday, August 17, 2009 - 07:08 pm: Hi I would appreciate radio code for my renault megane 2004 as recently fitted a new battery and lost the code. Model no: 22DC277/62 G478 Security RN277F40525938 PROD no: FD0504210525938 ================================== Try code 0349 |
Post Number: 1663 Registered: Aug-08
| Posted on Thursday, August 20, 2009 - 05:19 am: |
Manolo New member Username: Helpmepleaseeeeee Post Number: 1 Registered: Aug-09 Posted on Monday, August 17, 2009 - 01:50 pm: Hello I need the code for my Renault Megane Sedan Model NO: 22DC277/62 R541 Security RN277F40436143 PROD NO: FD0304090436143 --------------------------------------------------------- Try code 8421 |
New member Username: George80
| Posted on Thursday, August 20, 2009 - 01:12 pm: |
Hi, Help me, I need radio code for my Renault Megane Berline Car radio: GAMME RADIOSAT MODEL No: 22DC259/62T PROD No: FD0502163636154 Others No:TOM 312 RN 259F23636154 7700 434 422 TM 312 7700 434 422--C (BT2) |
Post Number: 1668 Registered: Aug-08
| Posted on Thursday, August 20, 2009 - 06:06 pm: |
George Bess New member Username: George80 Post Number: 1 Registered: Aug-09 Posted on Thursday, August 20, 2009 - 01:12 pm: Hi, Help me, I need radio code for my Renault Megane Berline Car radio: GAMME RADIOSAT MODEL No: 22DC259/62T PROD No: FD0502163636154 Others No:TOM 312 RN 259F23636154 7700 434 422 TM 312 7700 434 422--C (BT2) ================================== Try code 1354 |
| Posted on Friday, August 21, 2009 - 05:48 am: |
Perfect code!!! Thank you very much!!! |
Post Number: 1676 Registered: Aug-08
| Posted on Friday, August 21, 2009 - 12:01 pm: |
You are welcome ! Enjoy your music |
New member Username: Helkahyando
| Posted on Saturday, August 22, 2009 - 09:57 am: |
Can you please find my radiocode? Renault Megane 1999 Philips 22DC481/62 9022 214 81629 PA 5, FD 10 99 11 9147123 ModelNo: 22DC481/62 PRODNR: 1099119147123 NUMBER ingrave in metal box RN481FX9147123 it would be aweome it you can fin it. thanx. Manuel Panman (netherlands) |
Post Number: 1679 Registered: Aug-08
| Posted on Saturday, August 22, 2009 - 11:51 am: |
Manuel Panman New member Username: Helkahyando Post Number: 1 Registered: Aug-09 Posted on Saturday, August 22, 2009 - 09:57 am: Can you please find my radiocode? Renault Megane 1999 Philips 22DC481/62 9022 214 81629 PA 5, FD 10 99 11 9147123 ModelNo: 22DC481/62 PRODNR: 1099119147123 NUMBER ingrave in metal box RN481FX9147123 ================================== Sorry...not in my database. Try emailing restoredclassic@aol.com to see if they can help. Mention this forum |
New member Username: Dado666
BUDVA,
CRNA GORA
CRNA GORA
| Posted on Sunday, August 23, 2009 - 10:42 am: |
Hi everyone!! Please help me. I have Renault Megane 2004 and Cabasse audio system in it.Battery went out and i need the code desperately. Number: 8200205833TK099 0086170 |
Post Number: 1685 Registered: Aug-08
| Posted on Monday, August 24, 2009 - 03:07 pm: |
Dragan Stjepanoviæ New member Username: Dado666 BUDVA, CRNA GORA CRNA GORA Post Number: 1 Registered: Aug-09 Posted on Sunday, August 23, 2009 - 10:42 am: Hi everyone!! Please help me. I have Renault Megane 2004 and Cabasse audio system in it.Battery went out and i need the code desperately. Number: 8200205833TK099 0086170 ================================== Post ALL the letters+numbers including the 14 character Serial Number beginning with RN ************ |
New member Username: Awan
Post Number: 1 Registered: Sep-09
| Posted on Friday, September 04, 2009 - 11:55 am: |
I have Renault Megane model 2002 diesel and after replacing the battary, code is required to activate the CD play. Please help me out since i have lost the papers and its old car. chassis number is VF1KA050527667585 |
Post Number: 1784 Registered: Aug-08
| Posted on Friday, September 04, 2009 - 02:25 pm: |
naeemawan New member Username: Awan Post Number: 1 Registered: Sep-09 Posted on Friday, September 04, 2009 - 11:55 am: I have Renault Megane model 2002 diesel and after replacing the battary, code is required to activate the CD play. Please help me out since i have lost the papers and its old car. chassis number is VF1KA050527667585 ==================================== The radio will have to be removed from the car dashboard . Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING. |
New member Username: Pepo2207
| Posted on Saturday, September 05, 2009 - 11:59 am: |
hi, could i get code number for my radio please? here are every numbers which i found: Renaul megane r.2000 Model no: 22DC27962T Prod no: FD0199480006775 TOR797 RN279FX0006775 7700434423TR797 7700434423 Thank you. |
Post Number: 1787 Registered: Aug-08
| Posted on Saturday, September 05, 2009 - 12:58 pm: |
Peter Kret New member Username: Pepo2207 Post Number: 1 Registered: Sep-09 Posted on Saturday, September 05, 2009 - 11:59 am: hi, could i get code number for my radio please? here are every numbers which i found: Renaul megane r.2000 Model no: 22DC27962T Prod no: FD0199480006775 TOR797 RN279FX0006775 7700434423TR797 7700434423 =================================== Sorry ....not in my database Try emailing restoredclassic@aol.com to see if they can help Mention this forum |
New member Username: Cricri
| Posted on Sunday, September 06, 2009 - 01:13 pm: |
Hi, pls could you help? I blocked my radiosat 6010 of scénic 98, but I don´t know the code. Phillips 22DC459/62L 9022 214 59624 FD 06 98 05 4048604 MOD NO 22DC459/62L PROD NO 7700 426 412 X237 Thanks before |
Post Number: 1801 Registered: Aug-08
| Posted on Monday, September 07, 2009 - 01:56 pm: |
New member Username: Cricri Post Number: 1 Registered: Sep-09 Posted on Sunday, September 06, 2009 - 01:13 pm: Hi, pls could you help? I blocked my radiosat 6010 of scénic 98, but I don´t know the code. Phillips 22DC459/62L 9022 214 59624 FD 06 98 05 4048604 MOD NO 22DC459/62L PROD NO 7700 426 412 X237 =================================== Your code is 2738 |
New member Username: Iris
| Posted on Friday, September 11, 2009 - 07:09 am: |
hello i need help could i get code number for my radio, please? many thanks renault Megane 1997 VIN: VF1BA0F0F16047537 radio Phillips - I don´t know what I find a model of radio. Please, I am et the end of. |
POLAND
Post Number: 217 Registered: Jan-09
| Posted on Friday, September 11, 2009 - 07:25 am: |
Iris Rák. --->post all serial numbers from radio |
New member Username: Boxmaker
| Posted on Saturday, September 12, 2009 - 02:00 pm: |
good day all, i need help,i need a code mod 22dc259/62t prod fd0602263660654 ser rn259f23660654 TOJ916 7700434422TJ916 7700 434 422 many thanks...mark |
POLAND
Post Number: 224 Registered: Jan-09
| Posted on Saturday, September 12, 2009 - 02:12 pm: |
mark webley--->6150 -------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
Post Number: 2 Registered: Sep-09
| Posted on Sunday, September 13, 2009 - 12:42 pm: |
hello i need help could i get code number for my radio, please? I have Mégane 1997. model no: Philips 22DC594/62F PROD no: FD0297053048623 9022 215 94623 RNS94FV3046623 mamy thanks |
Post Number: 1839 Registered: Aug-08
| Posted on Monday, September 14, 2009 - 11:07 am: |
Iris Rák. New member Username: Iris Post Number: 2 Registered: Sep-09 Posted on Sunday, September 13, 2009 - 12:42 pm: hello i need help could i get code number for my radio, please? I have Mégane 1997. model no: Philips 22DC594/62F PROD no: FD0297053048623 9022 215 94623 RNS94FV3046623 =================================== Sorry ...not in the database Main Dealer or a Decoding Service |
Post Number: 3 Registered: Sep-09
| Posted on Monday, September 14, 2009 - 11:44 am: |
maybe I write a wrong number, I send o photos...
POLAND
Post Number: 227 Registered: Jan-09
| Posted on Monday, September 14, 2009 - 12:58 pm: |
Iris Rák.---> try 6655 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
Post Number: 4 Registered: Sep-09
| Posted on Tuesday, September 15, 2009 - 10:57 am: |
many many many thanks code is good. I am very happy. Thank you Michael |
New member Username: Smellington
| Posted on Friday, September 18, 2009 - 09:17 am: |
Hi, I'd like some help with finding my code too, please:
POLAND
Post Number: 246 Registered: Jan-09
| Posted on Friday, September 18, 2009 - 10:02 am: |
J C--->6738 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
| Posted on Friday, September 18, 2009 - 11:34 am: |
Thank you for your help, Michael! Have a great weekend  |
New member Username: Sowrdfish
Saint petersburg,
Liningrad ob...
Russia
| Posted on Monday, September 21, 2009 - 01:52 pm: |
can anyone hepl with my radiocar Renault megane 2008 RNRDBE80732467 RENRDW330-10 FD0708040732467 RENault 8200 607 918--b 8200607918T Q528 SECURITY E2 0204064 best regards abdallahindb@hotmail.fr |
Post Number: 1893 Registered: Aug-08
| Posted on Monday, September 21, 2009 - 02:16 pm: |
Duplicate request! Multi-posted requests are ignored as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests.. If you are that impatient for your code then try an online Decode Service who will supply your code by return. |
New member Username: Gianlucuozzo
| Posted on Thursday, September 24, 2009 - 06:21 am: |
Hope you can help me with my radio code for my renault megane cabriolet. NOW IN THE DISPLAY APPARS :ERROR....HELP ME PLEASE!!!! Model No: RENRDW130-00 Product No: FD0306130008326 Other numbers: RNRD7160008326 and 8200497243TZ778 Thank you BOYS |
Post Number: 1909 Registered: Aug-08
| Posted on Thursday, September 24, 2009 - 08:58 am: |
Gianluca Cuozzo New member Username: Gianlucuozzo Post Number: 1 Registered: Sep-09 Posted on Thursday, September 24, 2009 - 06:21 am: Hope you can help me with my radio code for my renault megane cabriolet. NOW IN THE DISPLAY APPARS :ERROR....HELP ME PLEASE!!!! Model No: RENRDW130-00 Product No: FD0306130008326 Other numbers: RNRD7160008326 and 8200497243TZ778 ==================================== Your code is 0254 |
| Posted on Thursday, September 24, 2009 - 01:15 pm: |
Thank you my friend! Gianluca |
New member Username: Alesiss
| Posted on Saturday, September 26, 2009 - 09:38 am: |
model no: 22DC259/62T RN259F23607104 PROD NO: FD 0502053607104 770043442TS566 7700 434 422 --C e2 029021 RENAULT MADE IN FRANCE FABRIQUE EN FRANCE I need code please |
POLAND
Post Number: 275 Registered: Jan-09
| Posted on Saturday, September 26, 2009 - 10:49 am: |
alexandar--->7475 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: Wollkeer
| Posted on Tuesday, September 29, 2009 - 06:18 am: |
Hi there, can you help find the code to my stereo...its a 2003 renault megane info off radio serial number RN277F30206630 model 22DC277/62 Bar code 8200256141TUO85 some other number TOU085 product number fd0103230206630 please help if you can Thanks Vaidas |
POLAND
Post Number: 290 Registered: Jan-09
| Posted on Tuesday, September 29, 2009 - 07:14 am: |
vaidas---> Sorry...not in my database. Try emailing radiocodeservice@gmail.com to see if they can help |
New member Username: Tomek72
Post Number: 1 Registered: Oct-09
| Posted on Thursday, October 01, 2009 - 03:43 pm: |
I neet the code for a renault megane radio its a Philips - RN461FX6058617 mail tomek72@poczta.onet.pl |
New member Username: Rgvivayo
San Salvador,
San Salvador
El Salvador
| Posted on Saturday, October 03, 2009 - 02:50 pm: |
if i dont have the key to remove the stereo.is there any other way to remove it? Thanks |
Post Number: 1955 Registered: Aug-08
| Posted on Saturday, October 03, 2009 - 03:00 pm: |
inchy God New member Username: Rgvivayo San Salvador, San Salvador El Salvador Post Number: 1 Registered: Oct-09 Posted on Saturday, October 03, 2009 - 02:50 pm: if i dont have the key to remove the stereo.is there any other way to remove it? Thanks ==================================== Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay ,or Auto Store ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts. An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html |
Post Number: 1956 Registered: Aug-08
| Posted on Saturday, October 03, 2009 - 03:04 pm: |
tomek New member Username: Tomek72 Post Number: 1 Registered: Oct-09 Posted on Thursday, October 01, 2009 - 03:43 pm: I neet the code for a renault megane radio its a Philips - RN461FX6058617 mail tomek72@poczta.onet.pl ================================== Your code is 9514 |
New member Username: Amimix
| Posted on Sunday, October 04, 2009 - 01:13 pm: |
Hello everybody, I need the code for my renault megane radio. RNRD8750005340 RENRDW240-15 FDO205490005340 820052325IT M236-SECURITY My email is mcolomaruiz@gmail.com Please help my |
Post Number: 1966 Registered: Aug-08
| Posted on Monday, October 05, 2009 - 10:41 am: |
maría New member Username: Amimix Post Number: 1 Registered: Oct-09 Posted on Sunday, October 04, 2009 - 01:13 pm: Hello everybody, I need the code for my renault megane radio. RNRD8750005340 RENRDW240-15 FDO205490005340 820052325IT M236-SECURITY ==================================== Try code 1560 |
New member Username: Davany
| Posted on Tuesday, October 06, 2009 - 12:48 pm: |
Hello, I need the code for a renault scenic radio its a Philips - RN481FX9278671 mail dj_davany@hotmail.com |
Post Number: 1981 Registered: Aug-08
| Posted on Tuesday, October 06, 2009 - 02:39 pm: |
Registered: Oct-09 Posted on Tuesday, October 06, 2009 - 12:48 pm: Hello, I need the code for a renault scenic radio its a Philips - RN481FX9278671 mail ====================================== Sorry...not in my database |
New member Username: Laktasi
| Posted on Saturday, October 10, 2009 - 08:50 am: |
Hello everybody, I need the code for my renault megane radio MODEL NO: 22DC279/62T TOK: 182 RN279F10146031 PROD NO: FD0301430146031 BARCODE: 7700434423TK182 7700 434 423 Thank you |
New member Username: Ald3r
| Posted on Saturday, October 10, 2009 - 11:30 am: |
Hi, wondered if you could find my code for renault megane: MODEL NO: 22DC277/62 S112 Security RN277F40555945 PROD NO: FD0504250555945 BARCODE: 8200256141TS112 8200 256 141 --D thanks in advance alder |
Post Number: 1987 Registered: Aug-08
| Posted on Saturday, October 10, 2009 - 02:23 pm: |
james alder New member Username: Ald3r Post Number: 1 Registered: Oct-09 Posted on Saturday, October 10, 2009 - 11:30 am: Hi, wondered if you could find my code for renault megane: MODEL NO: 22DC277/62 S112 Security RN277F40555945 PROD NO: FD0504250555945 BARCODE: 8200256141TS112 ========================================== Sorry ...not in my database Try emailing restoredclassic@aol.com to see if they can help Mention this forum |
Post Number: 1988 Registered: Aug-08
| Posted on Saturday, October 10, 2009 - 02:25 pm: |
Milorad Dodik New member Username: Laktasi Post Number: 1 Registered: Oct-09 Posted on Saturday, October 10, 2009 - 08:50 am: Hello everybody, I need the code for my renault megane radio MODEL NO: 22DC279/62T TOK: 182 RN279F10146031 PROD NO: FD0301430146031 BARCODE: 7700434423TK182 7700 434 423 ====================================== Try code 5718 |
New member Username: Mrshift
| Posted on Sunday, October 11, 2009 - 01:34 pm: |
Hi there, I too am stumped by my Megane Fidji 2002 radio / CD player requiring a code that I don't have following recent replacement of the battery. The following are the numbers on the unit; 22DC279/62T TOQ700 RN279F20210920 FD0402230210920 7700434423TQ700 I'd much appreciate any help you can give in finding out the code. Many thanks in advance. |
Post Number: 2014 Registered: Aug-08
| Posted on Sunday, October 11, 2009 - 02:15 pm: |
Graeme Park New member Username: Mrshift Post Number: 1 Registered: Oct-09 Posted on Sunday, October 11, 2009 - 01:34 pm: Hi there, I too am stumped by my Megane Fidji 2002 radio / CD player requiring a code that I don't have following recent replacement of the battery. The following are the numbers on the unit; 22DC279/62T TOQ700 RN279F20210920 FD0402230210920 7700434423TQ700 I'd much appreciate any help you can give in finding out the code. ==================================== Try emailing restoredclassic@aol.com to see if they can help Mention this forum |
New member Username: Homerus
| Posted on Sunday, October 11, 2009 - 05:13 pm: |
Hello everybody, please help me.I need a code for my renault megane 1998 radio.
Post Number: 2 Registered: Oct-09
| Posted on Sunday, October 11, 2009 - 05:17 pm: |
POLAND
Post Number: 318 Registered: Jan-09
| Posted on Monday, October 12, 2009 - 06:25 am: |
Post Number: 3 Registered: Oct-09
| Posted on Monday, October 12, 2009 - 07:34 am: |
I' have found one more number STAMPED IN THE METAL CASING maybe this could help: RN479FW9015600 |
| Posted on Monday, October 12, 2009 - 11:37 am: |
I need the code for a renault megane scenic radio It's a Renault Philips Radiosat 6000 7700 433 070 Philips 22dc481/62 9022 214 81629 FD 12 99 40 9278671 Model no. 22DC481/62 Prod no. FD 1299409278671 7700 433 070 s102 RN481FX9278671 greetings, dj_davany@hotmail.com |
New member Username: Johnedward
| Posted on Monday, October 12, 2009 - 05:30 pm: |
Adomukas New member Username: Homerus Post Number: 2 Registered: Oct-09 Your code is >>>>>2173 |
| Posted on Monday, October 12, 2009 - 05:33 pm: |
Graeme Park New member Username: Mrshift Post Number: 1 Registered: Oct-09 you code is >>>>>>9296 |
Post Number: 5 Registered: Sep-09
| Posted on Monday, October 12, 2009 - 05:40 pm: |
Aymen Al-Sheikhly New member Username: Aymen_a22 Uk Post Number: 2 Registered: May-09 Your code is>>>>> 0798 |
New member Username: Digiboy
| Posted on Tuesday, October 13, 2009 - 10:31 am: |
Hello, i need a code for a renault scenic radio model renrdw131-10 prod no. fd0203490087046 serial 8200300858ty041 many thanks |
Post Number: 2024 Registered: Aug-08
| Posted on Tuesday, October 13, 2009 - 01:56 pm: |
gertjan New member Username: Digiboy Post Number: 1 Registered: Oct-09 Posted on Tuesday, October 13, 2009 - 10:31 am: Hello, i need a code for a renault scenic radio model renrdw131-10 prod no. fd0203490087046 serial 8200300858ty041 many thanks =================================== Try code 1976 |
Post Number: 4 Registered: Oct-09
| Posted on Tuesday, October 13, 2009 - 02:14 pm: |
Thank you very much John edward, the code you gave me really works. |
| Posted on Tuesday, October 13, 2009 - 03:52 pm: |
code works thank you very much |
New member Username: Mikhail99
Lagos,
Lagos
Nigeria
Post Number: 1 Registered: Aug-06
| Posted on Tuesday, October 20, 2009 - 07:48 am: |
please i need help decoding my car radio.chrysler voyager. serial no:tq 1aa319533002 part no:p4704345f date code:3195 |
Post Number: 2097 Registered: Aug-08
| Posted on Tuesday, October 20, 2009 - 09:55 am: |
mike sax New member Username: Mikhail99 Lagos, Lagos Nigeria Post Number: 1 Registered: Aug-06 Posted on Tuesday, October 20, 2009 - 07:48 am: please i need help decoding my car radio.chrysler voyager. serial no:tq 1aa319533002 part no:p4704345f date code:3195 -------------------------------------------------------------- Sorry ....not in my CHRYSLER database Main Dealer or Decoding Service |
New member Username: Pmortl
| Posted on Wednesday, October 21, 2009 - 12:46 pm: |
Hi, I need a radio code for Renault Laguna 1.6 16VRN Estate, Philips RadioSat 4000 radio cassette playe. Serial Number RN449FV4004344 Product Number - FD0097274004344 Have already tried two codes in car manual 6502 and 9884, neither seemed to work which is why I'm here. Many thanks in advance |
New member Username: Egyforce
| Posted on Monday, October 26, 2009 - 09:54 am: |
hello sir i have a megan 2004 and the radio is locked can u help me to find the code MODEL NO : 22DC277/62 RN 277F40552490 PROD NO : FD0504250552490 BARCODE : 8200256141P311 thank 4 help |
| Posted on Monday, October 26, 2009 - 10:01 am: |
hello sir i have a megan 2004 and the radio is locked can u help me to find the code MODEL NO : 22DC277/62 RN 277F40552490 PROD NO : FD0504250552490 BARCODE : 8200256141TP311 thank 4 help |
POLAND
Post Number: 354 Registered: Jan-09
| Posted on Monday, October 26, 2009 - 02:31 pm: |
ahmed mostafa--->0684 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
Lagos,
Lagos
Nigeria
Post Number: 2 Registered: Aug-06
| Posted on Tuesday, October 27, 2009 - 04:43 am: |
Post Number: 2152 Registered: Aug-08
| Posted on Tuesday, October 27, 2009 - 07:08 am: |
mike sax New member Username: Mikhail99 Lagos, Lagos Nigeria Post Number: 2 Registered: Aug-06 Posted on Tuesday, October 27, 2009 - 04:43 am: please i need help decoding my car radio.chrysler voyager. serial no:tq 1aa319533002 part no:p4704345f date code:3195 ================================= Duplicate question...Already answered last week . .Main Dealer or a Decode Service |
Bronze Member Username: Amilo
Post Number: 21 Registered: Jul-09
| Posted on Tuesday, October 27, 2009 - 08:06 am: |
For mike sax Chrysler codes can be got from here for free www.ukbookshelf.co.uk |
New member Username: Artieshaw
France
| Posted on Tuesday, October 27, 2009 - 12:51 pm: |
Hi, Can you find the code for Renault Kangoo radio please; locked after battery change: Model 22DC259/62 TOW975 RN 259F20266618 Prod No FD0602210266618 7700434436TW675 Many thanks in advance. |
France
| Posted on Tuesday, October 27, 2009 - 01:32 pm: |
Hi, Half an hour ago I sent you a request for a radio code, please cancel it as I've found the number written in the bottom of the case for the hand book. Thanks! |
Post Number: 2159 Registered: Aug-08
| Posted on Tuesday, October 27, 2009 - 01:41 pm: |
Bob Miller New member Username: Artieshaw France Post Number: 1 Registered: Oct-09 Posted on Tuesday, October 27, 2009 - 12:51 pm: Hi, Can you find the code for Renault Kangoo radio please; locked after battery change: Model 22DC259/62 TOW975 RN 259F20266618 Prod No FD0602210266618 7700434436TW675 ====================================== Try code 3082 |
New member Username: Robgr85
Post Number: 1 Registered: Nov-09
| Posted on Sunday, November 01, 2009 - 07:42 am: |
Can anyone help me in encoding my renault radio, here is the sticker with numbers: http://robertgrubba.com/radio_code.jpg |
Gold Member Username: Regrooster
Post Number: 2178 Registered: Aug-08
| Posted on Sunday, November 01, 2009 - 07:49 am: |
Sorry...not in my database Try emailing here restoredclassic@aol.com to see if they can help Mention this forum |
New member Username: Mounirrajab
| Posted on Sunday, November 01, 2009 - 08:32 am: |
Hi, help me!!! I need my radio code renault clio 2001 mod. 22DC279/62F T0T757 RN279FY0101748 prod. no: FD 0300 490101748 8200029541TT757 Thanks! |
Post Number: 2183 Registered: Aug-08
| Posted on Sunday, November 01, 2009 - 08:36 am: |
Mounir Rajab New member Username: Mounirrajab Post Number: 1 Registered: Nov-09 Posted on Sunday, November 01, 2009 - 08:32 am: Hi, help me!!! I need my radio code renault clio 2001 mod. 22DC279/62F T0T757 RN279FY0101748 prod. no: FD 0300 490101748 8200029541TT757 Thanks! ================================= Try code 6287 |
New member Username: Mxman
Ljubljana Slovenia
Post Number: 2 Registered: Nov-09
| Posted on Friday, November 06, 2009 - 04:26 am: |
Hello! I changed battery in my Renault megane II, and now my radio is locked. I can't find right code anywhere, so here I am, asking for your help. RNRN6950068985 RENRDW240-00 FD01 0515 0068985 8200 483 757T D220 - SECURITY |
POLAND
Post Number: 375 Registered: Jan-09
| Posted on Friday, November 06, 2009 - 05:13 am: |
Gasper Adamlje--->0346 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: Szehr
| Posted on Friday, November 06, 2009 - 08:17 am: |
Hi, help me!!! I need my radio code renault megane 2002 Model Nr:.22DC259 / 62T Prod No.:FD0602353675250 T0G459 RN259F23675250 7700434422TG459 7700 434 422 --C} |
Post Number: 2216 Registered: Aug-08
| Posted on Friday, November 06, 2009 - 09:33 am: |
aba csaba New member Username: Szehr Post Number: 1 Registered: Nov-09 Posted on Friday, November 06, 2009 - 08:17 am: Hi, help me!!! I need my radio code renault megane 2002 Model Nr:.22DC259 / 62T Prod No.:FD0602353675250 T0G459 RN259F23675250 7700434422TG459 7700 434 422 --C} ================================== Try code 0316 |
