Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > 98 Audi A4 Need Stereo COde
Author Thread: 98 Audi A4 Need Stereo COde
Username: Wjp1984
I just bought a 98 Audi but dont have the stereo code and i dont have the manual. What can i do to get it? I called the dealer but they said its about $65 to find out whats the code, but im just checking if maybe there is another way that is cheaper
Username: Regrooster
Post Number: 581
Audi do not make radios but affix their badge on a radio manufactured by someone else ( eg Alpine , Grundig etc)
Unfortunately the majority can not have their codes calculated for free anywhere on the Internet.You have to obtain it from the Main Audi Dealer or a Radio Decode Specialist.
There are just 1 or 2 exception so what you have to do is
1...Quote the radio MAKE + MODEL
2....Quote ALL the LETTERS+NUMBERS found on ANY LABELS , BARCODES + STAMPED IN THE METAL CASING of the radio .......but being realistic, the chances of obtaining your code for free will be verysmall.
Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > 98 Audi A4 Need Stereo COde [ « Previous ] [ Next » ]
