Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Honda Ridgeline Radio Code
Author Thread: Honda Ridgeline Radio Code
Username: Usanda
Hi,
I bought a 2007 Honda Ridgeline on auction. The radio is locked. Kindly help me with the code. These numbers are on the radio which is a 6 CD loader which i think is pioneer.
0937121 IFI5
30014995
FJ014995
39100-SJC-A200
DEH-MG6547ZH
XU/UC
The vehicle VIN is: 2HJYK16527H535144
send to my e-mail: umarsanda@hotmail.com. Thank you
Username: Regrooster
Post Number: 519
This is a MATSUSHITA radio requiring a five digit code.
try 31113
If not try 35113
If neither work , then it is doubtful that you will be able to obtain this code for free from anywhere on the Internet.
Main Dealer or Decode Specialist only
Username: Usanda
Hi Reg,
Pioneer Corporation was written on the sticker at the back of the radio. The codes did not work. Please advice where i can get the code. The honda website requires i give the registered address of the vehicle as it appears on their database. I do not have that address. Thanks
Post Number: 522
It will have to be taken into a Decode Specialist who will electronically read/recode your radio.
Google search or try local Car Radio / Audio shop
(Matsushita are part of the Pioneer Group)
Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Honda Ridgeline Radio Code [ « Previous ] [ Next » ]
