Home > Message Board > Car Audio > Security Systems > Blaupunkt code
Author Thread: Blaupunkt code
Username: Clydsdale
Muswellbrook, Nsw
Australia
Bought my car from auctions,No books or codes etc,need code for radio,a Blaupunkt 520,p/n 92 057 951,S/n BP8393X1739434,any help with security code and entry proceedure would be greatly appreciated.cheers kev.
Username: Regrooster
Post Number: 472
Quote ALL the NUMBERS+LETTERS on the radio plus the MAKE of CAR it is fitted into
Username: Clydsdale
Muswellbrook, Nsw
Australia
No.:92057951,Type Blaupunkt 520,U1E,BP8393X1739434,Fitted to Holden Barina.Hope this is what is needed,cant see any more info. Kev.
Username: Decode
Post Number: 18
Kevin Clydsdale try--->6944
Username: Clydsdale
Muswellbrook, Nsw
Australia
Many thanks Michael,code worked straight up,so does radio.cheers Kev.
Username: Massi
I have an '02XC Barina. After changing my battery- have lost code for blaupunkt 2020, 92 094 577, barcode BP0485 2 7895446. Also cannot clear 10 safe, tried holding down ac button. Any help very much appreciated.
Username: Decode
POLAND
Post Number: 189
Adam Aretino ------> try code 0941
turn on radio and wait for 0000 maybe even 12 h
If this code has helped you in anyway - and you want to say thanks ,like beer donation:-)...
this is my paypal ( www.paypal.com ) e mail:
lynx222@o2.pl
Username: Massi
Thanks Michael for your reply. I will try this as soon as I can. Adam.
Username: Massi
From 10----, I entered '0941' but radio display went straight back to 10 safe. What now?
Post Number: 1263
Your radio is not accepting 0941 which is the correct code according to my calculator (as well as michael`s)
Perhaps your radio has been recoded in the past to a completely different number.
You could try emailing
restoredclassic@aol.com
to see if they have any suggestions
(Mention this Forum)
Otherwise your only option now is a Decode Service who will electronically read your memory chip (EEPROM) for the code.
Username: Massi
Thanks Regrooster, I will keep trying '0941' as we have owned it from new.
Username: Jasamas
Could you possible help, I am looking for the code for a Blaupunkt car 300 (d) stereo
s/N GM 1300T5819674
90 532 620
7 645 852 320
Kind Regards
Jasamas
Username: Balazs
New York
US of A
Hi,
Beer money reward offered for radio code for a Blaupunkt Audi Gamma radio, s/n AUZ1Z6N0521022. It is in a '93 Audi 90 quattro CS.
Much appreciated!
Post Number: 1305
Username: Balazs
New York
US of A
Registered: Jun-09 Posted on Friday, June 26, 2009 - 02:21 pm:
Hi,
These AUDI BLAUPUNKTs are very difficult(Impossible ?) to calculate using the Serial Number
If you can quote the other number beginning with 7 *** *** *** then I`ll attempt it for you
Post Number: 1306
samas
Username: Jasamas
Registered: Jun-09 Posted on Friday, June 26, 2009 - 10:52 am:
s/N GM 1300T5819674
90 532 620
7 645 852 320
Try code 2774
Username: Balazs
New York
US of A
Okay, I got the following set of #'s:
7 640 859 381
4 AO 035 093
Hope this helps!
Post Number: 1327
<i>alazs
Username: Balazs
New York
US of A
Registered: Jun-09 Posted on Friday, June 26, 2009 - 08:09 pm:
7 640 859 381
4 AO 035 093
Try code 0766
If this does not work then it will not be available for free from anywhere on the Internet.
Main Audi Dealer or a Decode Service only
Hope this helps!
Username: Balazs
New York
US of A
Try code 0766
Hope this helps!
Hey,
I tried the code, it didn't work =( Can you recommend a decode service perchance? How much would they charge?
Post Number: 1328
Unfortunately I cannot recommend a Decode Service as they will require the radio so that they can connect it to a laptop with specialist software to electronically "read"+ recode your memory chip (EEPROM).
Ask at your local Car Radio /Audio Store or try Ebay or via Google
Username: Eajihoon
Could you please help me with security code for my radio "Blaupunkt 520"? It is fitted to Holden Astra. Here is all the numbers and letters I have.
Blaupunkt 520, U1E, No: 92057957, BP8622403494. I will be greatly appreciated for any help. Thanks : )
Post Number: 1499
Duplicate request!
Multi-posted requests are ignored as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
If you are that impatient for your code then try an online Decode Service who will supply your code by return.
Username: Nestorluiss
Hello, I need the security code for an old radio cassette BLAUPUNKT model RICHMOND
The No. is B513003192
(I bought it used, I don`t know about the car where it was installed)
Thank you in advance.
Post Number: 1628
Nestor Santomartino
Registered: Aug-09 Posted on Thursday, August 13, 2009 - 05:30 pm:
Post ALL the LETTERS+NUMBERS on any labels, barcodes or stamped in the metal casing
Over my old radio cassette BLAUPUNKT model RICHMOND:
Made in Japan
Warranty No. B513003192 (sticker)
Serial No. 61055300 (stamped)
Thatīs all. Thank you in advance.
Post Number: 1755
Nestor Santomartino
Registered: Aug-09 Posted on Saturday, August 29, 2009 - 07:15 pm:
Made in Japan
Insufficient information.
Try emailing
to see if they can help.
They offer free advice etc.
Mention this forum
Username: Back2future
I recently bought my car from an auction, Battery was flat and needed changing. My Blaupunkt 520 radio asks for a Code, and cannot find a code in my manual.
If anyone can please help I would appreciate this very much.
The details are:
Type Blaupunkt 520, U1E,
No.:92057951
BP2391 4 6268572, Fitted to Holden Astra 2004 model
Any help with security code would be greatly appreciated....
Cheers Peter.
Post Number: 1781
Peter Mannings
Registered: Sep-09 Posted on Thursday, September 03, 2009 - 09:27 pm:
The details are:
No.:92057951
Cheers Peter.
Try code 6670
Thanks Reg,
Mate that worked beautifully, I can't thank you enough.
I appreciate the great help you have been for me.
Thanks again,
Peter
Username: Jackywu_xp
My radio BLAUPUNKT SQR 29
Made in Japan
Warranty No. X182910142 (sticker)
Serial No. 61006026 (stamped)
My Email:xyqxyq@126.com
That is all. Thank you very much
Post Number: 2092
jackywu
Registered: Oct-09 Posted on Monday, October 19, 2009 - 12:07 pm:
Made in Japan
Post ALL the LETTERS+NUMBERS on ANY LABELS,BARCODES or STAMPED IN THE METAL CASING
Username: Giannis121
Please provide me the code for the following Blaupunkt:
BP 5019 W 3416 502
7 607 005 019 8
Installed on a MAN
(Has also a label MAN2446RDS)
Thank you in advance)
Post Number: 2156
yian
Registered: Oct-09 Posted on Tuesday, October 27, 2009 - 08:28 am:
BP 5019 W 3416 502
7 607 005 019 8
Installed on a MAN
These are awkward to calculate
Try emailing
Mention this forum
Username: Musician1
North Carolina
Can someone help me? We bought this unit about 15 years ago and cannot find the code to save our lives.
Label Reads:
Blaupunkt
Bosch Gruppe
BP9570A1560044
Tampa SQR 29
7 649 570 517
FD069
thank you kindly
Post Number: 2228
Tom Molan
Username: Musician1
North Carolina
Registered: Nov-09 Posted on Saturday, November 07, 2009 - 08:38 pm:
Label Reads:
Blaupunkt
Bosch Gruppe
BP9570A1560044
Tampa SQR 29
7 649 570 517
FD069
Try code 5418
Username: Nboskic
i have a Fiat Punto and the blaupunkt radio need a code (XXXX).
I write the numbers information, if somebody can get the code iīll very grateful.
Prod.nr fiat
735289640
BP nr:
7641374316
Post Number: 2232
nikola
Username: Nboskic
Registered: Nov-09 Posted on Sunday, November 08, 2009 - 11:57 am:
Prod.nr fiat
735289640
BP nr:
7641374316
Post the 14 character Serial Number usually beginning with BP++++++++++++ and often found stamped in the metal casing
Username: Smamfer
Hi there,
I have recently bought a 1996 1.6 p reg astra with a blaupunkt stereo in,,, sn is GM 0300T5193188
Is anyone able to help me with the code please as the previous owners have not written it in the book when they gave it to me
Many thanks
Sam
Username: Decode
POLAND
Post Number: 439
SAM BAILEY------>7170
If this code has helped you in anyway - and you want to say thanks ,like beer donation...
this is my paypal ( www.paypal.com ) site:
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=9592785
Username: Medix
Wexford
hi guys i have a car radio just bought of one friend but he have no code .just wondering can u please can help me ?Thank you very much
Blaupunkt GMBH
BP 503869178953
7645038392
date 23/03/06
Post Number: 2288
arry
Username: Medix
Wexford
Registered: Nov-09 Posted on Friday, November 20, 2009 - 01:50 pm:
Blaupunkt GMBH
BP 503869178953
7645038392
Try code 1929
Username: Jamesy1
Mid glam
United Kingdom
Hi all recently bought a new van and previous owner has misplaced the service book and the code for the radio was in there and when a new battery was put on the van it was lost could anyone please help
serial no: M024931
thanks
Username: Ivyness
Hi,
Could someone help me with a security code, my radio stopped working after the battery died.
Holden Astra, No: 92057957 BP: 8 622 401 324
Any help will be much appreciated.
Post Number: 2291
Ivy
Username: Ivyness
Registered: Nov-09 Posted on Saturday, November 21, 2009 - 12:24 am:
Hi,
These HOLDEN radios can be awkward to decode
Try emailing
and they should be able to help
Mention this forum
Post Number: 2292
MARK JAMES
Username: Jamesy1
Mid glam
United Kingdom
Registered: Nov-09 Posted on Friday, November 20, 2009 - 04:01 pm:
serial no: M024931
try code 1578
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Security Systems > Blaupunkt code [ « Previous ] [ Next » ]
