Thread: Tuning Tips. |
New member Username: Yenkozl1
PHOENIX,
AZ
UNITED STATES
Post Number: 5 Registered: Oct-08
| Posted on Wednesday, February 04, 2009 - 06:08 pm: |
Looking for some advise on tuning a complete system. When tuning my system I put all the presets on the stereo for bass,treble,and sub at zero. I fade everyting to the front with the amp turned all the way down and the volume knob turned all the way up. Then I turn the gain up on the amp just before the speakers start to distort and then do the same for the rear speakers but not as much gain for those to keep the front sound stage effect. Then I adjust the crossovers on the amp w/in the Hzs specs on the speaker box. Is this correct or am I a fool? I do this so I can crank it up without having to worry about blowing a speaker. I've heard some systems where they get a lot of sound at low volume levels but if the volume goes past 15 the speakers start to distort. And I think that cant be tuned right. Any input would be great! |
Silver Member Username: 71_chevelle
Post Number: 159 Registered: May-08
| Posted on Monday, February 23, 2009 - 04:40 pm: |
Yes from what i have heard that is a good way for tuning your speakers. |
PHOENIX,
AZ
UNITED STATES
Post Number: 6 Registered: Oct-08
| Posted on Wednesday, February 25, 2009 - 01:21 am: |
Ok,Cool Thanks for the input Hunter....But is there another way to go about it? Or should I stick with what I'm doing? |
Post Number: 170 Registered: May-08
| Posted on Wednesday, February 25, 2009 - 03:05 am: |
The way you are doing it is the best! You wont distort your speakers, your amp wont shut off in protection mode trying to turn your volume up loud to have loud speakers and you wont blow your speakers either. stick with your method. |
