Home > Message Board > Car Audio > Head Units > Archive through August 05, 2009 > Pioneer DEH-P6000UB vs. Alpine CDA-9886
Author Thread: Pioneer DEH-P6000UB vs. Alpine CDA-9886
Username: Squatch1009
Post Number: 9
Which unit would you guys recommend? I've heard very good things about both, but I just can't decide. I like the Pioneer because the preamp voltage is 4 volts compared to only 2 volts in the Alpine, but my friend has the Alpine 9886 and it sounds really good. I have 2 12" Alpine Type Rs by the way.
Username: Camdry90
Sudbury, Ontario
Post Number: 17
alpine 9887
Username: Joe1234
I have both. Similar SQ (both very good) but the Pioneer have an integrated 7 band EQ among other sound enhancing features & price is much lower (if you care).
The Alpine has Imprint but you have to add a very expensive extra device plus setup (don't have Imprint myself).
the 9886 is good, but I think it is just not worth the extra $$$ let alone the 9887 (not even USB out of the box).
I understand the 9886 is 4v.
Home > Message Board > Car Audio > Head Units > Archive through August 05, 2009 > Pioneer DEH-P6000UB vs. Alpine CDA-9886 [ « Previous ] [ Next » ]
