Home > Message Board > Car Audio > Subwoofers > Archive through January 16, 2009 > Hifonics amplifier power ratings expl...
Author Thread: Hifonics amplifier power ratings explained
Username: Nd4spd18
Philadelphia, PA
Post Number: 9440
Some people just don't seem to get it so I think this deserves a detailed explination.
Power ratings in watts specify how much power an amplifier can produce before it exceeds a specified amount of distortion (clipping). The accepted industry standard is 1% total harmonic distortion, and most amplifiers are rated equal to or less than this.
Now, hifonics "cheats" by not specifing at what distortion level their power ratings are obtained.
Power ratings are essentially useless without a THD rating also. As power output increases so does distortion. So without a THD rating, a company could rate their amplifier at say 50% distorion, or something rediculous like that, and make the amplifier appear to produce WAY more power than it is actually able. And while they are not lying technically, the power at that level would be horriably distored, not "clean" at all.
Now for everyone who has been b!tching about an actual bench test to prove this. Here are the results of a CA&E mag bench test of an XX-Goliath which claims 5000w @ 1 ohm:
TEST RESULTS
OUTPUT POWER @ 1%THD,
100Hz, 14.4 Volts
Mono @ 4 ohms 1,708 watts
Mono @ 2 ohms 3,062 watts
Mono @ 1 ohm 4,696 watts
100Hz, 12.5 VOLTS
Mono @ 4 ohms 1,237 watts
Mono @ 2 ohms 2,223 watts
Mono @ 1 ohm 3,512 watts
Distortion at rated power,
100Hz, 14.4 volts 0.1% @ any impedance
http://www.caraudiomag.com/testreports/ 0608_cae_hifonics_xx_goliath_amplifier/power_charts.html
The author also notes why the acutal output is less than claimed:
"When I began to measure power levels, I found the power at 1.0% THD+N was a little lower than quoted in the specifications. After double checking all my measurements, I realized that Hifonics does not qualify their power figures with a distortion limit. By letting the amp run a little into clipping, I could get the claimed power from it, but at distortion levels around 2% to 5%."
As shown by that test the XX amps are somewhat overrated. The brutus and lower lines are even more.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6127
From my reading most Hifonics amps are 10% over-rated.
People just don't realize you get what you pay for.. Yes they are rated well and cheaper. But now compare the cost of that amp to other companies that actually post a true rms at 1% distortion on 14.4v or 12.5v.. The cost difference alone shows you what you are getting yourself into.
Don't go cheap, save and buy quality. Or at least expect that what you are getting will not do rated power or have the near build quality of something else rated the same but more expensive.
Now this may not be true with everything, but it is for the most part.
Username: Th3pwn3r
I compensate...
Post Number: 9165
A test means nothing for a comparison if the test is done differently than the way the manufacturer does their test. That's the only way you can say if something is over-rated or not. The test would have to be done exactly the same with no variance in between.
Username: Th3pwn3r
I compensate...
Post Number: 9166
I think we need some Team Maxxsonics members in here :-)
Username: Deadrabit
Marionville, MO
Post Number: 1240
the maxxsonics would have nothing to say. hahaha
Username: Glasswolf
Raccoon City, MI
Post Number: 12254
The other thing Hifonics has been known for in regards to misleading power ratings, is the use of unregulated power supplies, with a stated power output for the amplifier measured at 16VDC as opposed to the more accepted 12 or 14.4VDC.
There are many ways to mislead uneducated consumers.
Yet another, even with a THD rating stated, is that THD can be measured in a number of ways, including the use of a narrow band frequency range or a burst as opposed to sustained output for measurement.
In the end, you need to have a thorough understanding of the numbers you read, and ALL of the information has to be stated, correctly, by the manufacturer, or you may as well ignore them all together.
Also, instead of using the typical "xxx watts RMS) ratings, stick to CEA ratings, as they are a more strictly controlled means of comparing two brands of product.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9442
^^^^^ very good point I forgot to bring up
When dealing with brand name products CEA ratings are the best way to be sure the ratings you're looking at are accurate.
But if you're dealing with an "underground" company like AQ or RD with a good rep then you can be reasonable sure their ratings are fairly accurate. And small inconsistencies shouldn't be a problem since you should always use an amplifier that can produce more power than you will actually use...... it's hugely inaccurate ratings like hifonics's to beware of.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9445
Rob doesn't get it either.
Their ratings may be perfectly accurate in that the amp produces 5000w @ X% THD. Problem is they don't tell you what X is. Anything over 1% is considered too much distortion/clipping, and they are clearly using some level higher than that to come up with their power ratings.
All of this is a practice designed to deceive consumers and sell more products, since it appears that you are getting more for less money. And that is one of the biggest problems in the car audio world right now.
Username: Redliner
Wilmington, Ma
Post Number: 4840
which is why someone should buy my rd 1750's they actually do there rated power and are great amps.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9446
No offense to anyone but please keep OT stuff out of this thread and keep it on topic. I want to bookmark this for all the times in the future when people ask about hifonics ratings.
Username: Andrew571
Stillwater/Edmond, Oklahoma
Post Number: 2182
Good explanation, MS.
Something useful on E??????? amazing!
Username: Tatonka
-[Team Audible
Insanity]-
Post Number: 2601
M.S. makes a good post! w00t
AQ really did a good job coming out with a real 1200rms amp around the same price as a Hifonics 1206d.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6128
AQ amps are made in Korea right?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9449
Yes they did. The AQ 1200 actually uses the same board as the hifonics 1606.... but obviously better quality components.
Username: Insearchofbass
Post Number: 11156
Good post.
Username: Glasswolf
Raccoon City, MI
Post Number: 12259
If you want a better understanding of amplifiers, here's a page on how they work:
http://www.glasswolf.net/papers/amplifiers.html
Another even better site that goes into more detail, would be BCAE1.com
Username: Southernrebel
Monroe, Louisiana
Team Audible...
Post Number: 7198
nope.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9452
It is the same board as one of maxxsonics's amps..... I thought it was the 1606 but maybe not.
This amp, I can't tell the model from the pic just the maxxsonics logo:
http://i181.photobucket.com/albums/x60/get_er_dun90/GEDC0191.jpg
The AQ:
http://www.ddaudio.com/aq/AQ1200D_Guts.htm
Username: Nd4spd18
Philadelphia, PA
Post Number: 9453
BTW there is a TON of good info on Glasswolfs site as well as bcae1. If anyone wants to learn more about car audio or just electronics in general I suggest reading those sites.
Username: Imalik
15 FI BL9.1=Boom, New Jersey
Jerzee Playa
Post Number: 641
Is the Hifonics 1608 same as AQ 1200
like the RD 1750 is same as Sundown 1500
Username: M0nstar
Toledo, OH
U.S.
Post Number: 57
glasswolf, post your site again, i clicked it to see what i tlooked like and it didn't work.
Username: Livin_loud
COD4 Addict
Post Number: 2854
^or go to glasswolf.net and search for it...
Username: Glasswolf
Raccoon City, MI
Post Number: 12268
www.glasswolf.net under the "tech papers" section of the left menu.
I recently rewrote the site so links changed from what they were a while back, and I gave up the old wickedcases domain so its just glasswolf net now.
Username: Tatonka
-[Team Audible
Insanity]-
Post Number: 2607
Nope. The 1750 is a little more beefed up than the 1500.
Username: Jason420
PIMP CITY, GA
Post Number: 36
i have Hifonics 2608d i gave 375 shipped so how much clean watts do i have
Monroe, Louisiana
Team Audible...
Post Number: 7201
prolly ~2-2.2kw...if your electrical system can keep up.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9454
So anyone want to try and ID that maxxsonics amp? Would be nice to know what it is......
Home > Message Board > Car Audio > Subwoofers > Archive through January 16, 2009 > Hifonics amplifier power ratings expl... [ « Previous ] [ Next » ]
