Thread: Box help |
Silver Member Username: Pbplayer05
Omaha/council bluffs,
Iowa
Post Number: 777 Registered: May-07
| Posted on Tuesday, January 06, 2009 - 02:58 pm: |
i need help getting my box going my max dimensions are 32 wide 22 deep and 16 tall and the sub is an alpha v2 15 not exactly sure how to go about getting the box made and knowing what dimensions to use |
Gold Member Username: Bonhamd
Traverse City,
MI
Post Number: 1639 Registered: Nov-07
| Posted on Tuesday, January 06, 2009 - 03:30 pm: |
i would contact steve for a design those are about as big as you want to go in a grand prix though i would actually go smaller than those dimensions for the alpha |
Silver Member Username: Kingandsons07
TEAM REVOLUTION
Lincoln,NE
Post Number: 440 Registered: Aug-08
| Posted on Tuesday, January 06, 2009 - 03:36 pm: |
u need at lest 3-3.5 cubes @ 35Hz |
Iowa
Post Number: 778 Registered: May-07
| Posted on Tuesday, January 06, 2009 - 04:02 pm: |
yah is there any program that can get me a cut sheet or something |
Traverse City,
MI
Post Number: 1640 Registered: Nov-07
| Posted on Tuesday, January 06, 2009 - 04:03 pm: |
you can mess around with this http://reaudio.com/speaker_box/LPort_Box_Calc.html |
Iowa
Post Number: 779 Registered: May-07
| Posted on Tuesday, January 06, 2009 - 04:28 pm: |
how accurate is that i just did it and it came out pretty well i did 16 high 28 wide and 20 deep 3.5 inch port openeing and 6 inch piece on the other side of the port wall to make the l shape and it came out to like 3.29 for the box volume and a little over 35 hz |
