Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Quick battery question
Author Thread: Quick battery question
Username: Redliner
Wilmington, Ma
Post Number: 4819
hey guys sorry to ask this but.
wat size battery do i need for a 00 mitsubishi eclipse. I mean to fit upfront under the hood.
I am thinking about getting a 200 amp alt and 1 batt under the hood then 1 lg battery in the back. ill be running about 3.5 krms
Username: Deadrabit
Marionville, MO
Post Number: 1207
for my car i just measured and got the biggest i could get to fit
Username: Van_man
Boston South, MA
Post Number: 4533
x2. I went to sears and got the biggest die hard they sell.
Username: M0nstar
Toledo, OH
U.S.
Post Number: 43
i bought my 2 yellowtops for 60 dollars. i didnt care that it didnt fit, i bent and broke until it did then strapped that son of a batch of cookies down.
come to find out i don't even need 2 lol.
Username: Deadrabit
Marionville, MO
Post Number: 1213
now i would not go cutting stuff.
put those in ur car some place
Username: Nd4spd18
Philadelphia, PA
Post Number: 9420
Just b/c you can't modify stuff doesn't mean other people can't...... I've got a bigger battery than I should be able to fit.... just had to cut the tray a bit
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3535
x2 MS, i had to toss the HC2000 sideways and cut one side of the bracket off to get her in there, but it fit.
Measure and buy accordingly.
Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Quick battery question [ « Previous ] [ Next » ]
