Thread: Which way should port face? |
New member Username: Mikiedoo
Post Number: 10 Registered: Jan-09
| Posted on Monday, January 05, 2009 - 06:22 pm: |
Hey guys i have a 2001 Lexus is300 with one 15"BTL in the trunk. I had fisher customs design me a box to fit and it is 3.5 cubic feet. I have my amps at the very back of the trunk and the box sitting in front of the amps. Right now i have the port faced toward the trunk of the car. It sounds good but i didnt know what would happen if i turned it around. I was wondering if it would be louder, clearer ect. If you guys could help that would be great. Thanks, Michael |
Gold Member Username: Bonhamd
Traverse City,
MI
Post Number: 1638 Registered: Nov-07
| Posted on Monday, January 05, 2009 - 06:27 pm: |
just try it out - turn it around and see which way you like it best |
Gold Member Username: Big_edge_head
Milwaukee,
WI
Post Number: 3235 Registered: Mar-07
Just experiment with different ways. |
Gold Member Username: Hittin1
TEAM REVOLUTION Lake Charles...
Post Number: 2144 Registered: May-07
| Posted on Monday, January 05, 2009 - 06:35 pm: |
usually port back works best, but try to see what sounds best to you. |
Bronze Member Username: Mikiedoo
Post Number: 11 Registered: Jan-09
| Posted on Monday, January 05, 2009 - 07:07 pm: |
thanks guys i will have to experiment. |
Silver Member Username: Mrskullz1
Brooklyn, New York
Post Number: 972 Registered: Feb-07
| Posted on Monday, January 05, 2009 - 07:36 pm: |
btw..sweet ride and sweet sub...wht amp u using? |
Post Number: 12 Registered: Jan-09
| Posted on Monday, January 05, 2009 - 07:56 pm: |
got two hifonic 1606 hooked up to each voice coil right now. i have the dvc one ohm, i am lookin to get a recone and do the dvc 2ohm so i can run it at one ohm. Want to go with a RD 3250. what do you think, or do you know of any good amps that run at .5 ohms. thanks bud. |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 9141 Registered: Jul-06
| Posted on Monday, January 05, 2009 - 07:58 pm: |
Yo Skullz, http://forum.ecoustics.com/bbs/messages/4/539758.html |
