Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Ideal box for Type X
Author Thread: Ideal box for Type X
Username: Camdry90
Sudbury, Ontario
New to the forum here just had a question... I purchased an Alpine Type X 12 inch Subwoofer and the Alpine PDX 1.1000 amplifier to put in my 03 Jetta, i was wondering what would be the best box to put this sub in since i haven't purchased one yet... ps. I'm new to car audio, does having a good deck matter when it comes to sound quality? I'm already pleased with the components as my jetta has a moonson stereo package...
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14632
have no experience with type X so others will post later but HU IMHO is the most important part of any good quality system since its like the brain of the operation...
Username: Deadrabit
Marionville, MO
Post Number: 1197
yes the HU is very important. i have a golf and the moonson is pretty good for stock. after that i upgraded to a kenwood hu then an eclipse and everytime it gets better. a new set of components and speakers would do the trick if u want to spend. if ur happy with the moonson then keep it. its kinda nice to be able to put all those cds in it.
i would do 1.5 cuft if u do it sealed. the manual says .65 to 1.25,
if u want ported i would do a good 2cuft or 2.5 cuft. tuned to 34Hz
Username: Nyyfan13
Http://lowdo...
Join My User...
Post Number: 10946
I have not used one but everything I've read is that that sub likes a small sealed box best. I'll let someone else come on and either confirm that or fix it.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3534
1 cuft after sub disp sealed.
Username: Camdry90
Sudbury, Ontario
lol, nevermind guys... the jetta decided to break down, gunna cost $1200.00 2 fix putting my system on hold for now!!! :-(
Username: Deadrabit
Marionville, MO
Post Number: 1214
so did u not have the type Xs yet? maybe u should look into other subs when u get ur car up and going again
Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Ideal box for Type X [ « Previous ] [ Next » ]
