Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > Viper 480xv - Turbo timer feature
Author Thread: Viper 480xv - Turbo timer feature
Username: Subasi
Dorch
England
Hi all,
I have a Viper 480xv alarm system fitted and I would like to find out how you connect up the turbo timer function?
I beileve this function to be the channel 3 output on the alarm which from the manual states...
"A 30 (60, 90) second timed output will send a signal for 30 seconds when Channel 3 is pressed.
This output can be turned off during the 30-second period by pressing Channel 3 again"
I believe this is what im after but do i connect this to a relay or what?
The wire i need to connect to something is this one...
"H1/9 WHITE/BLUE 200 mA (-) channel output 3
This wire provides a (-) 200 mA output whenever the transmitter button(s) controlling Channel 3 is pressed."
If anyone knows it would be much appreciated?
Many Thanks
Simon
Username: Subasi
Dorch
England
Anyone???
Any Ideas?
Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > Viper 480xv - Turbo timer feature [ « Previous ] [ Next » ]
