Thread: How is verizon fios? |
Gold Member Username: Stateprop486
PA
Post Number: 1737 Registered: Jan-08
| Posted on Saturday, January 03, 2009 - 11:30 am: |
hey guys has anybody used verizon fios? if so how is it? im about to switch over from comcast HSI to verizon fios? comcast service is sh*tting on me, half of the time i try to go online it doesnt work. To get online i have to unplugg the modem for a couple secs and it works for a good 5 mins then stops. I even called the comcast guy to come out and still having problems. today im actually suprised ive been online for 5 hrs straight and havent been D/C yet. thanks for any help |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 9126 Registered: Jul-06
| Posted on Saturday, January 03, 2009 - 11:31 am: |
Wrong forum bud. But Comcast service is usually pretty bad around here in Chicago. No matter what area I've lived in I've always had lots of problems. |
PA
Post Number: 1738 Registered: Jan-08
| Posted on Saturday, January 03, 2009 - 11:38 am: |
sorry bro i had put it in off topic but no responded so i was just looking to see if anyone had used it yet. |
I compensate...
Post Number: 9129 Registered: Jul-06
| Posted on Saturday, January 03, 2009 - 11:53 am: |
Did you look on some Verizon forums? You might be able to find out if it's any good that way. I don't think too many people have experience with it since I believe that's a new service provider. This is actually the first time I've heard of it  |
I compensate...
Post Number: 9130 Registered: Jul-06
| Posted on Saturday, January 03, 2009 - 11:55 am: |
One thing that I can add is that you probably don't have too many leeches using that service so it probably wouldn't go down as often. Also, the lines should be new compared to the crappy old cable lines that most of us internet users are running. Fiber optics FTW. |
PA
Post Number: 1739 Registered: Jan-08
| Posted on Saturday, January 03, 2009 - 12:02 pm: |
haha thanks bro, appreciate the input, just like anything else some ppl say they have problems and some say it works fast/fine. I looked at a couple utube vids most of them says it worth it. It takes like 4-5 hrs to for them to install everything. |
Silver Member Username: Mrskullz1
Brooklyn, New York
Post Number: 971 Registered: Feb-07
| Posted on Saturday, January 03, 2009 - 01:58 pm: |
fios is fkin amazin state prop |
PA
Post Number: 1740 Registered: Jan-08
| Posted on Saturday, January 03, 2009 - 02:29 pm: |
lol good. im getting it installed on mon the 12th i cant wait to see how amazing it is  |
