Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Quick question
Author Thread: Quick question
Username: That_guy_u_dont_know
Kaplan, Louisiana
United States
Post Number: 58
i hooked my amp up put hooked up the sub nothing comes out the sub at all not even a slight movement at any volume and yes everything is hooked up right
wat could this be?
Username: Talon01
Team Revolution , Pa
Usa
Post Number: 1946
power light on?
Kaplan, Louisiana
United States
Post Number: 59
yeap the power light is green and not blinking nothing
A pic is worth
1000 posts!!
Post Number: 19547
Muted?
Username: Talon01
Usa
Post Number: 1947
rca's connected?
get a 9v batt and touch the speaker wires from the sub to the connections on top and see if it pops. just tap it dont hold it!!!
Kaplan, Louisiana
United States
Post Number: 60
rcas or connected and that sounds like it will mess up something rather not risk that
and paul im not that stupid
Username: Talon01
Usa
Post Number: 1948
do you have any way to test the sub? new or used? it wont hurt it btw i do it all the time.
correct rca connect from hu?
Kaplan, Louisiana
United States
Post Number: 63
i had my L7 15 hooked up to it and it worked fine took it out cause i sold it and i had a old JL 10 layin around so i decided to hook it up and well nothing happens (i took the amp out with the L7 then put it back in when i wanted to put the 10 in)used sub i have it hooked up in my room and its workin so i dont think its the sub yea the rcas or connected right i havent changed anything since the last time the amp was in
A pic is worth
1000 posts!!
Post Number: 19548
"and paul im not that stupid"
Well sometimes I am so it never hurts to ask.
Take a close look at the tinsel leads.
Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2241
Test your amps output with a multi-meter and your box terminals to see if everything is hooked up.
Kaplan, Louisiana
United States
Post Number: 64
no terminal straight to sub..... tinsel leads? that would be and yes i know stupid question
Username: Tylersliva
St.Ignace, Mi
U.S.
Post Number: 120
u know what i would do i would find someone that will let you try and hook their sub to it and see if it works... if it dont work somthin is wrong with amp... check all fuses and connections
A pic is worth
1000 posts!!
Post Number: 19550
Tinsel leads. You know, the thin silvery wires that connect the coil to the terminals? Check to see if one of them jarred loose. It happens.
Kaplan, Louisiana
United States
Post Number: 65
i got it guys i changed the rcas to a diffrent one and it seems to work now lol
Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Quick question [ « Previous ] [ Next » ]
