Thread: Best amp for 15" BTL fully loaded |
Silver Member Username: Themann
Mt. Holly,
NC
Post Number: 157 Registered: Jan-06
| Posted on Wednesday, December 31, 2008 - 01:16 pm: |
Hey guys, This question is for my friend, he won't get an ecoustics account. He has one 15" BTL fully loaded one ohm in a fisher customs ported box running off two hifonics 1600 watt amps. He is wanting to get the most out of this sub and isn't feeling like he's currently getting the job done. So the question is what amp is best suited for this sub? He is going to upgrade his big three, his alt, and get a battery in the next little while. Budget is less than $900 Thanks so much. |
Diamond Member Username: Bestmankind
Post Number: 23170 Registered: Oct-05
| Posted on Wednesday, December 31, 2008 - 01:18 pm: |
first amp that pops in to my head is the kicker zx2500.1. its 2ohm stable so its perfect for that dual 1ohm btl monster. very nice sub might i add. |
Platinum Member Username: Rovin
1 15 = 149.5 DBs Trinidad & T...
Post Number: 14610 Registered: Jul-05
| Posted on Wednesday, December 31, 2008 - 03:03 pm: |
whats the exact model no of that hif amp - is it 1600wmax or wrms ? ... |
Mt. Holly,
NC
Post Number: 158 Registered: Jan-06
| Posted on Wednesday, December 31, 2008 - 03:48 pm: |
it is the Hifonics BXi 1608D |
Gold Member Username: Mendonmafia
Post Number: 1674 Registered: Aug-06
| Posted on Wednesday, December 31, 2008 - 03:56 pm: |
i personally just bought the same sub and am going to be using an atomic 3000.1d i think that should drive it nicely. Its 3200 rms @ 1 ohm. but my sub is a dual 2 ohm your gonna need something that does that power at .5 ohms or 2 ohms. |
Gold Member Username: Hittin1
TEAM REVOLUTION Lake Charles...
Post Number: 2112 Registered: May-07
| Posted on Wednesday, December 31, 2008 - 04:03 pm: |
The Brutus's are not likely doing the job because of the stock charging.. Both combined should put out 2500 wrms with proper charging. I assume he has one amp/v.c.. I p/u a rd5750.1 for less than $900. That would easily put out enough power at 2 ohm. |
Mt. Holly,
NC
Post Number: 159 Registered: Jan-06
| Posted on Wednesday, December 31, 2008 - 05:01 pm: |
Alright thanks so much. I'll be sure to let him know. I can't wait to hear it with the proper charging. I have a BL and love it so I'm excited to spread the Fi around. |
Gold Member Username: Jkidder
Worlds gunna end,
In
2012
Post Number: 3921 Registered: Nov-05
| Posted on Wednesday, December 31, 2008 - 06:30 pm: |
buy a stetsom 7k. run it at 2 ohms daily... easy decision |
Gold Member Username: 04redmach1
Es DEALER,
GA
Post Number: 2473 Registered: Mar-06
| Posted on Wednesday, December 31, 2008 - 08:13 pm: |
You could grab a RD 3250.1 and run it at .5 ohm. With box rise you will be in the 1 ohm area. Pretty good price on the 3250's right now as well. Kevin se_rdaudio@yahoo.com |
