Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Single enclosure versus dual enclosur...
Author Thread: Single enclosure versus dual enclosure...
Username: Sk8er_drin
I never thought of this before, so i wonder and ask, what are the pro's and con's of a single enclosure compared to a dual?
Do you get more Db out of a dual or better frequency response?
Username: Rideredder
Cornell, IL
Post Number: 1533
You mean common chamber vs dual chamber or what?
im talkin about terms of sealed enclosures, forgot to put that in there.
I dunno exactly what a chamber is.
A pic is worth
1000 posts!!
Post Number: 19505
A chamber is what they keep criminals in.
Username: Deadrabit
Marionville, MO
Post Number: 1181
hehehe
Username: Cepedamarc
Bay Area, CA
Post Number: 12
I think he means two single sub enclosures vs one dual sub enclosure...
Post Number: 8
yes that is what i mean
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14607
http://www.diysubwoofers.org/ ...
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14608
do u mean 2 subs in 1 chamber with 1 port OR 2 subs in the same box & separated chambers with separate ports ?
1st 1 sounds louder thought the 2nd way sounds more cleaner ...
Username: Armykyle1
Ms
Us
Post Number: 77
i like that link, im gonna pass that out to my friends
Post Number: 9
omg i said sealed above......im talking 1 sub in its own box compared to 2 subs in same box, same chamber, no divider between the 2 subs
Username: Snowball123
West Allis, WI
Post Number: 1876
just stfu.
Bay Area, CA
Post Number: 13
Really helpful, Snow...
Anyway, ad, take a look at the link that Rovin posted. With a bit of reading, you'll more than likely arrive at a more informed answer if not better questions.
You have to remember that how "good" something sounds also depends on the listener's taste. An enclosure that sounds "good" to me might not sound "good" to you.
West Allis, WI
Post Number: 1877
you stfu too.
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14609
''''''omg i said sealed above......im talking 1 sub in its own box compared to 2 subs in same box, same chamber, no divider between the 2 subs'''''
u really should be very specific to what u asking
so u mean using 2 subs in the same exact size box as 1 sub ? - that will mean each sub will be operating in 1\2 of what it should be in which will sound like @ss ....
Bay Area, CA
Post Number: 14
You high, Snow? Go shoot some squirrels or something.
Rovin, unless ad corrects me here, he is referring to using 2 subs in two separate sealed enclosures versus 2 subs in one sealed (combined chamber) enclosure. I'm also assuming he means that dual sub enclosure has the same volume as the two separate ones combined.
Ad, it would help if you were clearer in the original topic. After you post, you get a preview. Read it over and make sure what you want to say comes across clearly.
Username: Big_edge_head
Milwaukee, WI
Post Number: 3205
Snow...high....
Calm down snow}
Username: Armykyle1
Ms
Us
Post Number: 79
lol. my old box was 2 12's that shared a center port, it sound ok. then i got a half assed trans line box with a divider between them. it sounded overall better no matter the music. if its a sealed box i dont think it makes much of diff if they're divided
Username: Boston_spl
Highland, CA
United States
Post Number: 81
19 posts in & we're still not EXACTLY SURE what his question is, due to his lack of specificity. Classic.
West Allis, WI
Post Number: 1880
nah, the new people on E are just pissin me off.
West Allis, WI
Post Number: 1882
yup, im gonna go shoot some squirrels...
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14611
i thought was only me who needed a translator to understand ....
Bay Area, CA
Post Number: 15
Ad, clear this up and you will get an answer. If you have to, post some pics of what you're trying to describe. >.>
Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Single enclosure versus dual enclosur... [ « Previous ] [ Next » ]
