Thread: Sub enclosure and wire |
Bronze Member Username: Brewzky
Post Number: 36 Registered: Dec-08
| Posted on Tuesday, December 30, 2008 - 11:43 am: |
The specs for the Re sx 15 call for a 4^3 ported box tuned to 34hz. I found a great box 1" MDF but is tuned to 32hz. Will that a noticeable difference. In addition, I have been reading alot about upgrading the "Big 3." Is this really necessary with the AQ1200D? I was thinking about just paralelling another smaller battery to basically act as a capacitor and provide a little more current to the electrical system. |
Gold Member Username: Hittin1
TEAM REVOLUTION Lake Charles...
Post Number: 2103 Registered: May-07
| Posted on Tuesday, December 30, 2008 - 12:30 pm: |
I see no real problem with either issue that u are inquiring about. I would still do the big 3 on top of battery addition. It's inexpensive and easy and it helps. Why put all the time and effort and not do something that is so simple?.. U will not likely be able to tell the difference between 34-32 hz tuning.. |
Platinum Member Username: Rovin
1 15 = 149.5 DBs Trinidad & T...
Post Number: 14602 Registered: Jul-05
| Posted on Tuesday, December 30, 2008 - 08:20 pm: |
well u can always trim like a 2" off the port length to get a higher tune box u dont have to do big 3 but it helps & makes a difference... |
Bronze Member Username: Tylersliva
St.Ignace,
Mi
U.S.
Post Number: 92 Registered: Oct-08
| Posted on Tuesday, December 30, 2008 - 08:38 pm: |
where did u find a box for that subwoofer with 1" mdf |
Post Number: 37 Registered: Dec-08
| Posted on Monday, January 05, 2009 - 01:15 pm: |
Mobile Soundworks. Front of ported box is actually 1 1/2 inch thick MDF. The sides and back is 1 inch. Bought it off Ebay for a 15" RE SX sub. |
Gold Member Username: Deadrabit
Marionville,
MO
Post Number: 1194 Registered: Jun-07
| Posted on Monday, January 05, 2009 - 09:39 pm: |
u don't have to do the big 3. if u have extra wire i would do it. if u have a small alt it would be smart to do the big 3 and battery. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 19570 Registered: Jun-06
| Posted on Monday, January 05, 2009 - 10:02 pm: |
"if u have a small alt it would be smart to do the big 3 and battery." Storage does NOT equal production. If you can't produce it, why bother? My man Muddy's mission statement: "Your charging system is by far the most important part of your system. Trust me." I can't argue with that. Not sure if that's Muddy's exact words but it helps to say them b4 I go to bed at night. |
