Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Sub/ HU install question
Author Thread: Sub/ HU install question
Username: 03ibp_is
Okay so I installed my JL 10W6 and alpine pdx 1.600 amp with the stock head unit (using a HI/ LO converter) in my IS300 today and honestly the sound quality isn't too bad at all however the sub is definately not hitting as hard as a W6 should hit. The amp is 600 watts RMS and even though I'm sure the W6 can handle more I would think that is a decent amount of power hooked up to one 10. So my question is does an aftermarket headunit really make that much of a difference or do I just need to buy a higer watt amp?
Username: Jtown
Texas
Post Number: 3389
an aftermarket head unit will generally have higher voltage pre outs, that and the signal quality should also increase.
Username: Joebruce
TC Sounds/DLS
Post Number: 2527
I wouldnt put any more power on a 10" W6. I think the rms is 400? Maybe 500 Im not sure. I had 500wrms on my 12w6 and it was plenty of power.
Diamond Member
Post Number: 23164
first of all nice car chris.
thieves is right. its the stock hu. you won't get the kinda bass you want with that unless you get an aftermarket hu. but i am sure you want to keep your dash looking oem so you wouldn't want to change. so get yourself a oem interface by jl audio or rockford fosgate. i am sure you can afford it mr is300. :-)
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14594
what type of box is the sub in ...
Username: 03ibp_is
wow wasn't expecting so many responses that fast! yeah i was pretty sure I was going to need a new headunit I just really didn't want to give up my 6 disc player..
It's a ported box but it's actually speced to the W7's exact demensions not the W6, would that be a problem?
Diamond Member
Post Number: 23165
i know a couple of guys using this with their factory stereo and it works great.
http://www.hookedontronics.com/show_product_details.jsp?cid=39910&c=0812Froogle& b=Rockford+Fosgate_3SIXTY.1
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14600
yep here on E we respond pretty fast - - i know of some 'reputable' forums where u have to wait days b4 any1 answers ...
Username: 03ibp_is
Oh yeah I meant to ask if you were referring to the 3sixty and cleansweep. There was a guy on an IS forum talking about how awesome the cleansweep worked for him but I never jumped on it. And believe it or not Chad I actually bought my IS off of my aunt for 10 grand and had to take out a loan.. haha So does anyone know where I could get a killer deal on the 3sixty or cleansweep?
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 2102
what enclosure do u have the sub in?
Username: 03ibp_is
Post Number: 7
http://cgi.ebay.com/VENTED-MDF-SUB-BOX-ENCLOSURE-for-a-JL-AUDIO-10W7-10-W7_W0QQi temZ390014769198QQcmdZViewItemQQptZCar_Subwoofers_Enclosures?hash=item3900147691 98&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A 1318%7C301%3A1%7C293%3A1%7C294%3A50
Of course I had to modify it a little because I didn't realize the W7 is actually narrower than the W6. lol
Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > Sub/ HU install question [ « Previous ] [ Next » ]
