Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > What to get?!
Author Thread: What to get?!
Username: That_guy_u_dont_know
Kaplan, Louisiana
United States
Post Number: 40
ok guys im askin for the last time what should i get for my 96 ford ranger extended cab i have the whole back extended part to work with and i have a kicker zx1500.1 to push the speaker i get
i want a good sql daily speaker i want loud but i want clean bass
im gettin a 15 but idk wat kind
so far i have looked at the following
HDC3
DD3500
DC lvl 4 lvl 5 coils
re sx
what would be my best bet i really dont wanna spend more then 300
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6055
either one.. whichever you can ge tthe best deal on
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 2074
DD3515 0r DD 9515
rd alpha v.2
treo ssx. you may have too much power for the ssi
re sx
HDC3 15
IMO that is the order i would look in that order
i would forget about Scotts Dc LVL 4's unless you know someone who would buy the other one as they are sold in pairs.
i'm thinking that you should be able to fit a ported 6 cubes box after port/sub displacement. if not after displacement, before displacement at least.. which would easily be good for a 2-12" setup.
downside is more money for subs and more power needed with above mentioned subs as well as electrical upgrades for more power. i imagine your keeker amp is hel_l on your stock charging already.
other option. downgrade subs (ex 2-treo ssi's) on 1500 wrms would wang in right enclosure.
if you get a chance, measure max dimensions of available enclosure area and post.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6058
idk, im happy with my SXs.. had them 3 yrs with no issues even running one daily with 2.5x the rms
easy to find for under 300 too
can't wait to get them in another car :-)
Kaplan, Louisiana
United States
Post Number: 41
mark im gunna give u a call tmrw i got some questions and i had a L7 15 so i think i could fit on of those 15s and i looked at the treo thats out the picture im really thinkin about the HDC3 or the SX watever is cheaper or would sound better remeber i want a sql which would be better as sql i dont want two speakers if i cant fit the 15 i will just get one 12 like i said i will call tmrw
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 2084
neither one are really sql... both are more spl.
call me... ill be bored at work i'm sure
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 2086
u look into the RD Alpha v.2?...they are a sql sub leaning more towards spl side of the spectrum. sound good and get loud as hell. I am currently running 2-18's. and love em
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6060
SX is more SQL than an HD3..
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 2090
but is still a spl sub..
decent SQ for a spl sub
Kaplan, Louisiana
United States
Post Number: 42
what would be the best sql sub for my money? thats all im looking for i want sql the most
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 2096
if you can find a used re xxx 0/4-0/5 model that is dual 1 or dual 4 ohm. That would be your best bet. Call me
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6061
Out of your list.. the SX would be the best SQL sub.. compare the t/s specs and you'll understand
the SX is not an SPL sub.. where as the MT would be
Kaplan, Louisiana
United States
Post Number: 43
i already told u mark i would rather not buy used if i dont have to
and wouldi have enough power for the sx and enough room to fit the box for it?
ill call u a lil later mark its my moms bday so im spending time with her
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6063
rms on the SX is 1000rms.. 1500rms would be plenty of power.. more than the RMS but still not too much for the sub to handle unless you set your gain wrong and abuse the sub by how you play it
you should have no problems fitting it in an EXT cab.. we ran an RE SX 18" in my friends old small Mazda EXT cab on a massive 1500.1
Kaplan, Louisiana
United States
Post Number: 44
dang that must have been a big box lol and wat u meen by abuse the sub?
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6066
bump it full tilt for a long period of time.. especially if the box is not to specs..
certain h/u will start sending a clipped signal after a certain volume.. listening after that level sending a dirty signal as well
setting the gain incorrectly..
playing music well below tuned frequency..
incorrect xover points..
the list could go on
Kaplan, Louisiana
United States
Post Number: 46
dude u confusein me "bump it full tilt for a long period of time.. especially if the box is not to specs.. " bump it full tilt? wat that meens
setting the gain incorrectly i normally set my gain at around three quarters and the xover about a quarter to half way
Kaplan, Louisiana
United States
Post Number: 47
i just remembered another speaker i didnt mention was a fi bl 15 any suggestions on that?
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6067
from what your saying you have no idea how to properly install :-(
i see a blown sub in the near future
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6068
and the bl will be along the lines of the HD3.. for SQL from FI do the Q
...but bring it to someone who knows how to install
Kaplan, Louisiana
United States
Post Number: 48
ok i know how to install a little bit tell me what im doing wrong? setting the gain how i set it is wrong i know u supposed to put your volume on the radio like half way or something like that i dont do that it take to much time and all the car install places around here suck BALLS big one rickysmith and avi or the two biggest around here and they dont know anything
Kaplan, Louisiana
United States
Post Number: 49
Username: Talon01
Team Revolution , Pa
Usa
Post Number: 1928
how much are you looking to spend?
Kaplan, Louisiana
United States
Post Number: 50
lookin around 300
Username: Joebruce
TC Sounds/DLS
Post Number: 2528
Please use periods! It hurts to read your posts.
Username: Talon01
Usa
Post Number: 1934
i may have a deal in progress. if you can wait a day or 2. i might be able to sell you one dc as requested.
Kaplan, Louisiana
United States
Post Number: 55
ok sounds good scott is those 12s or 15s?
Username: Talon01
Usa
Post Number: 1935
Kaplan, Louisiana
United States
Post Number: 57
aww i was kinda lookin for 15 those 12s bang?'
Username: Talon01
Usa
Post Number: 1937
oh yeah!!
Home > Message Board > Car Audio > Subwoofers > Archive through January 07, 2009 > What to get?! [ « Previous ] [ Next » ]
