Thread: 6X9's for under $90.00 |
Silver Member Username: Teamdeboy1971
OPTIDRIVE LN. La F...,
TN
Major Bass P...
Post Number: 553 Registered: Nov-06
| Posted on Sunday, December 21, 2008 - 04:43 pm: |
Hello I am hooking a system up and need to get some decent quality 6x9" speakers for under 100 bucks with shipping included! I found a set of kicker 3 way and a set of MA Audio 3way for 49.00 for each pair. What kind of sound quality will the ma audio have? I don't have an amp to run with the 6x9's right now, it will just be the 50x4 pioneer HU.. I should probably go with a small amp but don't have the extra money rt. now, so It will just be sorta factory replacements, not even sure if its DVC or not... Help! |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 9242 Registered: Jul-06
| Posted on Sunday, December 21, 2008 - 05:10 pm: |
ma audio is complete junk and kicker speakers are not much better. IDK what to tell you for that price really, except that rear speakers are unnessecary and only screw up the soundstage. (im assuming these are rears) Most high end systems dont use rears at all. I have a cheap set that I keep turned off unless I have people riding in back. |
Gold Member Username: Loudon
Post Number: 2837 Registered: Jun-04
| Posted on Sunday, December 21, 2008 - 06:08 pm: |
depending on kicker speakers ... if ur using the ds line then there junk but the rs and the ss series speakers from kicker are quite nice |
Gold Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 1976 Registered: May-07
| Posted on Sunday, December 21, 2008 - 06:36 pm: |
infinity kappa coaxles sound nice.. I liked mine until I upgraded. |
Gold Member Username: Mendonmafia
Post Number: 1643 Registered: Aug-06
| Posted on Monday, December 22, 2008 - 04:04 pm: |
i got a lightly used set of jbl 937 3 way 6x9's $45 shipped. you wont find a batter value than that |
Silver Member Username: Dsmith07
NC
Http://com4....
Post Number: 872 Registered: Jun-06
| Posted on Monday, December 22, 2008 - 04:12 pm: |
JL Audio TR 6x9 100shipped some people thought i had a 10 in the car with these. pics upon request |
Silver Member Username: Cashby
Post Number: 660 Registered: Oct-06
| Posted on Sunday, January 04, 2009 - 12:14 pm: |
I have a pair of Infinity Kappas 6x9s if interested..95 shipped.. pics upon request. |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 826 Registered: Nov-06
| Posted on Sunday, January 04, 2009 - 01:58 pm: |
i got a pair of infinity kappas also....2way with external Xovers...u could go "active" with them down the road.....PM me if ur are interested, i also have a cheap amp that would go good with them. |
Gold Member Username: Mj23dynasty
Alpine ida-x001/2 dd 2...,
Woodlawn Por...
Post Number: 1980 Registered: Oct-07
| Posted on Sunday, January 04, 2009 - 02:20 pm: |
I was jus going to reccomend I was thinking about getting those a while ago from my local shop jus for a tiny bit of rear fill when I have passengers. So I second what derek said thy r some beefy lil 6x9 to make sure you have enuf clearance before you buy. |
Woodlawn Por...
Post Number: 1981 Registered: Oct-07
| Posted on Sunday, January 04, 2009 - 02:21 pm: |
I was jus going to reccomend I was thinking about getting those a while ago from my local shop jus for a tiny bit of rear fill when I have passengers. So I second what derek said thy r some beefy lil 6x9 so make sure you have enuf clearance before you buy. |
Woodlawn Por...
Post Number: 1983 Registered: Oct-07
| Posted on Sunday, January 04, 2009 - 02:29 pm: |
Lol I forgot to put what kind lol I reccomend the JL Audio TR 6x9 also my bad... |
Post Number: 664 Registered: Oct-06
| Posted on Sunday, January 04, 2009 - 03:10 pm: |
mine are the 3 ways with the crossovers |
