Thread: 15" vs. 2-12" |
Silver Member Username: Teamdeboy1971
OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 530 Registered: Nov-06
| Posted on Tuesday, November 11, 2008 - 01:56 am: |
Hello I am writing in regaurds to my 19 yr old son! He has a 1995 olds Cutlass Ciera 4 door with a back seat that will not lay down!! I know my son is more of an SPL type of guy you could say, maybe 70/30 SPL over SQ, but here's where we sit? We have a Pioneer HU with a .5 ohm stable Lanzar Opti2000d we were going to maybe go with a sub 300 or under! I thought a 15 would hit a little harder but with the amp we have a single 15 dvc 2x2 won't go to .5 I don't think! 2 -12" optidrives will wire down to .5 and they sound good, we have heard a set before in my car! So, with a trunk set-up will a single 15 hit harder than the 12's???? Thanks, always enjoy your comments! Ps. I had a guy going to sell me a MT RE 15 for 380 shipped on ebay, but you know how that works? I have also ran accross a 15" L7 DVC 2X2 250.00 WITH A 4.0cu ENCLOSER! And a BL 15 FOR UNDER 300! remember he likes SPL so besides getting a new car what can we do??????? HELP!! 15 OR 12X2 |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8912 Registered: Jul-06
| Posted on Tuesday, November 11, 2008 - 02:47 am: |
Two 12s would be louder than one 15" Two standard BLs would do well NO L7s And that amp is very inefficient and will put a hurtin on your electrical system.... don't try and run that without a high current battery and preferrably HO alt also. |
Gold Member Username: Talon01
Team Revolution ,
Pa
Usa
Post Number: 1764 Registered: Jun-07
| Posted on Tuesday, November 11, 2008 - 08:10 am: |
two 12's as far as subs fi bl would be a good choice. there alot of subs in that price range though. sql subs i would rec are dcsoundlab.com lv4 rdaudio.net sonance series ddaudio.com 3500 series |
Platinum Member Username: Rovin
1 15 = 149.5 DBs Trinidad & T...
Post Number: 14351 Registered: Jul-05
| Posted on Tuesday, November 11, 2008 - 10:20 am: |
2 12s have slightly more cone area than 1 15 but both occupies closely about the same amt of cuft .... |
