Thread: Infinity or phoenix gold |
Silver Member Username: Talon_es93
Trinidad,
Co
Post Number: 816 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 10:20 pm: |
what would fit me best between 6x9 phoenix gold ryvals or 6x9 infity reference 3-way?.. i'm not sure what i can say other then i like really bright tweeters. it will be goin in the front doors or a 01 grand cherokee larado |
Silver Member Username: Ducka
Houghton and/or Macomb,
MI
United States
Post Number: 702 Registered: Jan-08
| Posted on Monday, November 10, 2008 - 10:26 pm: |
Have you thought about getting some component speakers instead? They usually sound better. Are you gunna amp them? |
Trinidad,
Co
Post Number: 817 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 10:27 pm: |
6x9 infinity reference or phoenix gold ryval 6.5 components*** |
Gold Member Username: Frkkevin
Team DLS SuperNatural...
Post Number: 5884 Registered: Nov-05
| Posted on Monday, November 10, 2008 - 10:30 pm: |
just buy yourself 20sets of pyle tweets.. you'll be in heaven oh, forgot to mention the pa speakers on the outside playing some highs too |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 784 Registered: Nov-06
| Posted on Monday, November 10, 2008 - 10:35 pm: |
u mean the horns under the hood .... |
Trinidad,
Co
Post Number: 818 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 10:37 pm: |
well i don't have an amp for them yet..i'd run them off my deck for a while but ya i plan on running them on an amp in the future.. but not till i replace my rear door speakers also |
Post Number: 5886 Registered: Nov-05
whatever they do that they think is cool.. |
MI
United States
Post Number: 703 Registered: Jan-08
| Posted on Monday, November 10, 2008 - 10:38 pm: |
lol^ so the 6x9s are coaxials and the 6.5s are components? Do you have a link? |
Trinidad,
Co
Post Number: 819 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 10:41 pm: |
idk if i would throw in 20 lol... but i was thinking about just adding in a couple of decent tweeters and also power my stock speaker on an amp... not sure if it would work... but nw that i think about it it would be smarter to try that 1st |
MI
United States
Post Number: 704 Registered: Jan-08
| Posted on Monday, November 10, 2008 - 10:43 pm: |
stock speakers can rarely handle the power of a new HU without blowing, much less an amp, but good luck... |
Trinidad,
Co
Post Number: 820 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 10:53 pm: |
no just the reference 6x9s or the ryval 6.5 comp. from ebay.. they both at about 60 bucks... or unless if you know of anything else in that price range that would be good.. |
Trinidad,
Co
Post Number: 821 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 11:05 pm: |
i put an amp to the stocks in my honda before and it sounded much better and it all worked good until i lent the car to some one and got it back with the speakers blown  |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8909 Registered: Jul-06
| Posted on Monday, November 10, 2008 - 11:06 pm: |
Have you actually heard good high end components? I find it baffeling how people can like the sound of these cheap azz speakers. |
Trinidad,
Co
Post Number: 822 Registered: Mar-06
| Posted on Monday, November 10, 2008 - 11:09 pm: |
ya i've heard good set up but i've never heard these infinitys or the PGs.i just decided on those b/c of another thread here on E and i trust the ppl on here |
