Thread: B0cks............. |
New member Username: Deusle
Post Number: 2 Registered: Nov-08
| Posted on Monday, November 10, 2008 - 09:19 pm: |
whats the best box for a 15 L7? Im lookin to really hit the lows like esp in White Girl and Put On in order to fit in my trunk, box cant be any larger than 36x12x18 but if its a really good box i suppose i could put it in my back seat.............................................................. |
Gold Member Username: Frkkevin
Team DLS SuperNatural...
Post Number: 5883 Registered: Nov-05
| Posted on Monday, November 10, 2008 - 09:24 pm: |
given those dimensions you don't have enough room to properly run that sub ported. 3.459^3ft before displacement of the port and driver.. and L7s generally need a larger box |
Gold Member Username: Surferdude9371
Get loud or go home....
Post Number: 1432 Registered: Mar-07
| Posted on Monday, November 10, 2008 - 09:52 pm: |
if you can port it id stick around 32-34 hz for the lows |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8908 Registered: Jul-06
| Posted on Monday, November 10, 2008 - 10:57 pm: |
If you didn't buy that sub already don't |
Gold Member Username: Bonhamd
Post Number: 1425 Registered: Nov-07
| Posted on Monday, November 10, 2008 - 11:05 pm: |
i dont know why everyone bashes L7s like they are the worst subs - ive had 3 different 15s and never had a problem with 1 of them they are not SQ subs so do not expect unreal sound quality - they are made to get loud and they do that kicker recommends like 5 or 6 cubes for the L7 15 IIRC |
Diamond Member Username: Bestmankind
Post Number: 22705 Registered: Oct-05
| Posted on Tuesday, November 11, 2008 - 12:03 pm: |
M.S. is just hatin. lol. chris, from the specs you don't have enough space for a nice ported box. not only does that L7 need to be ported, it needs to have a good size port area. you just won't get that. you can try a sealed box and see if you like it. i have heard 2 sealed L7 15s and they sounded really good. just make a large sealed box. at least 3.5 cuft. |
Silver Member Username: Basebalz13
Moneta,
Va
Usa
Post Number: 803 Registered: Aug-07
| Posted on Tuesday, November 11, 2008 - 11:26 pm: |
4.5 cubes might be fine if you did external port, and sub inverted, and had a lil extra power |
