Home > Message Board > Car Audio > Security Systems > Radio Codes For Free > Archive through October 18, 2008
Author Thread: Archive through October 18, 2008
Username: Gareth1125
Manchester
England
And if one could be so kind, i'd be most grateful for a code for mine too... It's a ford radio... M441855.
Thanks.
Gareth
Username: Katzumi
Try 9375 for you Ford Radio
It should work.
Username: Katzumi
Anyone who needs a code for Ford radios, send me a message - I'll do my best to sort you out a code for free within 24 hours!
Username: Katzumi
Oh, and thanks Reg, the Renault code worked a treat!
Username: Louis2fiddle
Hi Reg
Did you have any luck in finding a code for this radio?
Make: Phillips
Model: 79RC600/95
Serial No: PH600C10323245
Prod No: CG0001450323245
Vehicle: Daewoo Nubira 2002 ( built after 8/2001)
Thanks again
Paul
Username: Regrooster
Post Number: 51
Paul ShepherdUsername: Louis2fiddle
Posted on Saturday, October 04, 2008 - 10:11 am: E
Make: Phillips
Model: 79RC600/95
Sorry, this PHILIPS is not in my database as it is too recent . .... and I`ll think you`ll find that it won`t be available on any of these free Help Boards.
All the PHILIPS codes are held in a mega/ massive database so it will have to be the Main Dealer or search for one of the larger profession Radio Decode Specialists on Ebay or via Google
Username: Beauchampy
Hi there, I messed up trying to fit a newer head unit into my clio, only to find that it was incompatible and now I need to fit my original stereo, only I don't have the code!
Make: Renaut:
Model: Tuner List
Model no. 22DC278 / 62B
TOS326
RN278F10009387
Prod No: ID0101180009387
Then written under a barcode is;
8200057681TS326
I hope those figures are right because someone has written 'Clio 51/184022' in big black maker all over the label.. don't think that's the code though because it's supposed to be 4 digits?
If you could help me get out of this mess I would be truly greatful:-)
Post Number: 52
Posted on Saturday, October 04, 2008 - 02:43 pm:
Make: Renaut:
Model: Tuner List
TOS326
RN278F10009387
8200057681TS326
Your code is 7636
Username: Landers
Hi I have a 1995 Audi 80E with a locked radio the only reference I can find is "eurovox" and "Audi" on the radio,
model 7479m
serial 256001175.1.
Any help to unlock would be appreciated.
Regards.
Post Number: 53
Username: Landers
Posted on Saturday, October 04, 2008 - 09:15 pm:
model 7479m
serial 256001175.1.
Sorry I can not decode a EUROVOX make of radio
Code didn't work for my Renault.. Probably because I didn't give you the right figures.
Which ones do you use to actually generate the code? I'll double check them.. Wish someone hadn't scrawled all over the label..
If you could help me Reg I would really appreciate it! Not looking forward to the prospect of driving to work tomorrow with no music :-(
Post Number: 54
Posted on Sunday, October 05, 2008 - 09:14 am: Edit Post
Code didn't work for my Renault.. Probably because I didn't give you the right figures.ake: Renaut:
Model: Tuner List
TOS326
RN278F10009387
8200057681TS326
Code 7636 is correct because there is a "double check" facility with the numbers quoted.
Are you entering it correctly?
If you have already entered wrong codes, then leave it switched ON UNDISTURBED until it resets
Philips DC278/62B/P Renault Code Entry Instructions
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬ ] button then rotate the thumb wheel for the correct first digit
Press the [ ¬ ] button then rotate the thumb wheel for the correct second digit
Press the [ ¬ ] button then rotate the thumb wheel for the correct third digit
Press the [ ¬ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, press and hold the [ ¬ [ button for up to 3 seconds to store the code
Ahh yeah, I just wasnt holding down the button for 3 seconds! Read on another site it should just accept it automatically.
Anyway it's working! Thank you so much I owe you one!
Username: Andreas_84
Hello Reg,
I have a Peugeot406 98 model, and i would appreciate if you could provide me with the correct radio code.
the numbers i found on the label:
22DC722/65
9022 217 22659
M/ch 064094
Thanks a lot, Andreas
sorry i forgot: PHAPCFV9064251
Username: Neewee
Hi Reg
Can you provide a code for Philips radio in a peugot 406 please?
The inf I have is as follows;
SN = PHAPBFT9065437
Many thanks!
Username: Hum
Hi Reg,
I have a Grunding 2014 rds
GR0981W6762169
02 00981 0330 676216 9
dad 96 232 272 80
Would youy have the code for this plase
Many Thanks
Post Number: 55
Username: Neewee
Posted on Monday, October 06, 2008 - 03:29 pm:
SN = PHAPBFT9065437
Your code is 0523
Post Number: 56
Username: Hum
Posted on Tuesday, October 07, 2008 - 03:35 am: I have a Grunding 2014 rds
GR0981W6762169
dad 96 232 272 80
Sorry not in my database. It might be too recent to obtain from any of these free Help Boards.
Post Number: 57
Posted on Monday, October 06, 2008 - 11:42 am: I have a Peugeot406 98 model, and i would appreciate if you could provide me with the correct radio code.
22DC722/65
9022 217 22659
M/ch 064094 PHAPCFV9064251
Your code is 3364
Username: Neewee
cheers Reg!
Username: Stefan85
Hi Reg,
I have a Philips BMW Business RDS
22DC785/23F
Serial: PH7850T1160865
KW 49/96 INDEX: 01
'97 BMW Compact
Would you have a code for it please?
thank you very much,it works
Post Number: 58
Username: Stefan85 Tuesday, October 07, 2008 - 06:53 am: ,
22DC785/23F
KW 49/96 INDEX: 01
'97 BMW Compact
Your code is 7702
Username: Stefan85
Thank you Reg, I'll try this as soon as I take the car from repairing...
Username: Skydiver82
Hello Reg,
I have a Philips autoradio (Renault Clio 2002), these are the information:
Model No: 22DC278/62B
Barcode: 8200057681TR999
Prod No: FD0202170186266
Other indications:
T0R999
RN278F20186266
Would you have a code for it?
Thanks by advance !!!
Username: Motanu_tano
hi,
the battery in my vectra b was dead and now I don't have the code for Philips CAR400.
serial: GM90383441
no: 90 462 560
Many thanks in advance.
Post Number: 59
Posted on Tuesday, October 07, 2008 - 03:40 pm: I have a Philips autoradio (Renault Clio 2002), these are the information:
Other indications:
T0R999
RN278F20186266
Sorry , this one is another one of the French (Renault )Philips radios and is not in my database.(My database only appears to have around 50% of them ) Try restoredclassic@aol.com as they have a larger database and can normally calculate these French models ( Mention this forum and there should be no charge)
Post Number: 60
Wednesday, October 08, 2008 - 10:51 am: Edit Post
serial: GM90383441
no: 90 462 560
Please post ALL the NUMBERS and LETTERS found on any LABELS , BARCODES and STAMPED IN THE METAL CASING.
Username: Spud1066
Looking for unlock code on Renault philips radio
Model no : 22DC279/62
TOP462
RN279FY0106199
Prod No : FD0300400106199
7700433948TP462
Thanks
Username: Laguna_boy
Ireland
i just got a renault laguna 1996 i need code for cd player in it, it only has renault and pioneer on front of head unit so not sure what model is,its eon rds and on the inside of faceplate it has 7700 841 008
pl45342 on silver sticker any help wud b great cuz i avnt a clue thanks
Post Number: 62
Username: Spud1066
Posted on Friday, October 10, 2008 - 02:17 pm: Looking for unlock code on Renault philips radio
TOP462
RN279FY0106199
7700433948TP462
Post Number: 63
Ireland Posted on Friday, October 10, 2008 - 04:34 pm:
Sorry PIONEER codes not available.
Try your Main Dealer or Radio Decode Specialist
Username: Pookie22
New orleans, La
Us
part no 09375643,id # 2001,scan # 89cwtwr283383093. for a 99 oldsmoble intrigue
Username: Altan
W
Weew
Hi Reg and others,
I need a code for my Renault radio Tuner List>
Model No> 22DC279\62T
TON 860
RN279F20204137
PROD NO. FD0402200204137
BAR CODE. 7700434423TN860
MADE IN FRANCE
THANKS A LOT!
ALTAN
Username: Wailingwimmy
i need a code too
Becker grand prix
BE7995
sern. 65001924
10 presets
Can you help me out
could only find calculator up t0 9 pre sets
Username: Albain
rover 620 blaupunkt code for radio please
below are
BP2013S7637299
7 642 013 390
IF ANYONE CAN HELP MUCH APPRECIATED AGAIN THANKS.
Post Number: 64
Username: AltanPosted on Saturday, October 11, 2008 - 06:46 am:
TON 860
RN279F20204137
MADE IN FRANCE
Post Number: 65
Username: Albain
Posted on Saturday, October 11, 2008 - 01:35 pm: rover 620 blaupunkt code for
BP2013S7637299
7 642 013 390
Try 6172..and let me know if it works as I don`t think any of my BP calculators work for this (Rover) BP Serial Number.
Post Number: 66
Posted on Saturday, October 11, 2008 - 09:19 am: Edit Post
i need a code tooBecker grand prix
BE7995
sern. 65001924
10 presets
Can you help me out
Try 44611
If not, then use your Becker Calculator for each preset up to 9 and the chances are that one will be correct.
Leave 10 minutes (switched ON) between each code entry so that radio resets
Post Number: 67
Username: Pookie22
New orleans, La
UsPosted on Friday, October 10, 2008 - 05:16 pm:
I don`t recognise these numbers.
Please post the radio MAKE , MODEL and ALL the NUMBERS+LETTERS found on any LABELS , BARCODES or STAMPED IN THE RADIO METALWORK.
see examples here
http://www.davidsonelectronics.co.uk/serial_locate.htm
Username: Ervin979
TOR058
model no:22dc 229/62T
prod no:FD0303140117129
RN229F30117129
LOST RADIO CODE AS NEEDED CAN YOU HELP
ervincomsped@hotmail.com
Username: Ervin979
TOR058
RN229F30117129
Post Number: 71
Username: Ervin979
Posted on Sunday, October 12, 2008 - 01:58 pm: TOR058 model no:22dc 229/62T
RN229F30117129
Your Code is 8969
Username: Turbodoc
Reg,
I needed to do some work on my BMW Z3 yesterday, that involved disconnecting my battery. I checked my owners manual and found my security card that listed my radio data. It clearly listed the Model, serial number and "safety number" on it.
I felt confident I could do the repair and put in the unlock afterward and be back in business...wrong. I put the code in 3 times and got CODE WAIT on the LCD. I turned off the ignition then turned it back on and left it for an hour and a half. I now have CODE_ _ _ _ _ back on the LCD. I pushed the "M" button and scrolled through the settings using the "+" button and got a completely different Serial Number than what was listed on my owner manual security card. I need some help to unlock the system. I have pulled the unit out copied all the data from the sticker on the right side of the unit:
Manufacture: Blaupunkt WERKE GMBH Germany
Model: BMW Business CD
Part Number: 7 649 272 042/040/44
Serial Number: BP9272X2135579
Thanks in advance,
Audy,
I posted this thread on another forum then seen your post
Username: Jj72uk
Hi Reg, fingers crossed you have this one on your database
Manufactur: Tuner List ( renualt scenic)
Model: 22DC279/62P
T0V772
RN279fy0120617
Prod No: FD0100290120617
Then under a barcode: 7700434425tv772
Really hope you can help!
Username: Mykans
Lagos, Lagos
Nigeria
Hello Reg,
Sure you are doing a great job.
Please, assisit with the code of my radio. I replaced the battery of my vehicle, Mitsubishi Montero 2001.
VIN: JA4MW31R71J020024
S/N: 99F56286
Make: Matsushita
Model No: MR563520
Regards,
Mike
Username: Robi99
Hi Reg,
Can I get the code for my 1997 VW Golf?
P/N: 1HM-035-186-D
Date Code: 2506
Vendor Code: PE9B39W-01
Serial number: VWZ9Z7T3371392
Many thanks!
Rob
Post Number: 72
Username: Jj72uk
Posted on Monday, October 13, 2008 - 12:01 pm:Manufactur: Tuner List ( renualt scenic)
Model: 22DC279/62P T0V772
RN279fy0120617 Prod No: FD0100290120617 Then under a barcode: 7700434425tv772
Username: Spud1066
Username: Spud1066
TOP462
RN279FY0106199
7700433948TP462
Thankyou for taking the time to check this for me - I will try restored classics
Username: Albain
thanks reg your a saviour
Post Number: 73
Username: Robi99
Posted on Monday, October 13, 2008 - 02:04 pm:Can I get the code for my 1997 VW Golf?
P/N: 1HM-035-186-D
Date Code: 2506
The VWZ9Z is a CLARION unit and the only codes that can be calculated on these free Help Boards is where there is a barcode Serial Number beginning with C700000......
Otherwise try your Main Dealer or Google/Ebay for a professional Radio Decode Specialist
Post Number: 74
Username: MykansLagos, Lagos
NigeriaPosted on Monday, October 13, 2008 - 01:31 pm: code of my radio. I replaced the battery of my vehicle, Mitsubishi Montero 2001.
S/N: 99F56286
Make: Matsushita
Model No: MR563520
Sorry MATSUSHITA codes are not available on any of these free Help Boards. Try your Main Dealer or Google/Ebay for a Radio Decode Specialist
Post Number: 75
Audy Goodin Username: TurbodocPosted on Sunday, October 12, 2008 - 07:32 pm:
Your code is 0819
Blaupunkt 7649272042 - BMW Code Entry
Turn on the radio, the display should show ' CODE - - - -'.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
To save the code press [ > ]. The set will now operate.
Username: Ervin979
thank you very much,it works .
Username: Sdannenberg
Hello helpful people - Can anyone get (or point me in the right direction to get) the unlock code for our radio. When I called the dealer with the vin, the code he gave did not work...it turns out that the folks we bought it from had switched radios from a different car.
The car it was switched from was a Volvo sedan...(1994?) but I do not have that vin.
The radio model is 3533535-4969 9442
The serial number is B41053554
Thank you very much !!!
email: sdannenberg@tds.net
Post Number: 77
Posted on Monday, October 13, 2008 - 05:44 pm: Hello helpful people - Can anyone get (or point me in the right direction to get) the unlock code for our radio. When I called the dealer with the vin, the code he gave did not work...it turns out that the folks we bought it from had switched radios from a different car.
I don`t recognise any of your numbers. Volvo radios can be a variety of different makes so if you remove it from the dashboard and can quote the radio MAKE , MODEL and ALL the LETTER + NUMBERS on any labels , barcodes or stamped in the metal casing then I might be able to help.
Username: Turbodoc
Reg,
I tried the code, it didn't work. my unit needs a 5 digit code. when I press 1 it apears in the field. If I push 1 a second time it appears in the second position in the field until the whole field is filled "Code 11111" then it reverts to Code _ _ _ _ _.
Thank you very much for trying,
Audy
Post Number: 79
Username: Turbodoc
Posted on Monday, October 13, 2008 - 08:33 pm:
Audy
I have seen this before with Blaupunkt radios. I believe that your radio can be set to different areas of the world ( eg USA and EUROPE) and the tuning range will be different for each set area. Also the Security Code is different and it is 5 digits for USA and 4 digits for Europe. I believe that one of the tricks to try if you do NOT have the 5 digit code , but have the 4 digit code is
1...Set your radio to EUROPE
2...Enter 4 digit code
3..Reset your area to USA.
There are many references to Radio Codes on this Z3 forum including this
http://bimmer.roadfly.com/bmw/forums/z3/216059-1.html
Username: Turbodoc
Reg,
Changing to "Europe area" on the settings did the trick!!! I just listened to Missisippi Queen by Mountain on CD..way to loud in the parking lot of my plant ha ha.
Thank you so much, I was about to give up and buy a after market head unit, but I really wanted to keep the car as original as possible. Once again, thank you Reg for all your efforts..you are the man!!
Audy
Username: Donpapa3
Hi i have problem with code after replaced car battery. I have no service book to my car just logbook. All a can find is details on the radio label:
philips 22DC481/62
9022 214 81629
FD 12 99 17 9174379
MODEL NO: 22DC481/62
PROD NO: FD 1299179174379
SERIAL NUMB: RN481FX9174379
Can You help mi how to obtain radio code?
Thanks
Tom
Post Number: 80
Username: Donpapa3
Posted on Wednesday, October 15, 2008 - 03:43 pm: Hi i have problem with code after replaced car battery. I have no service book to my car just logbook. All a can find is details on the radio label:
philips 22DC481/62
9022 214 81629
FD 12 99 17 9174379
If this is fitted in a French car ( Renault/Peugeot/Citroen) then there should be some more letters+ numbers on a label beginning with 7 and ending with letters/numbers
Something like 7700433970 X823
or even the word Security X823
If so, then please post
If not, then I can not help you
Username: Donpapa3
Yes I've got another label with number:
7700 433 070 W923
Username: Kaurimees
Model: 22dc279/62P
RN279fx0011307
Renault megane code needed
Post Number: 81
Username: Donpapa3
philips 22DC481/62
9022 214 81629
FD 12 99 17 9174379
7700 433 070 W923
Your code should be 3046
Post Number: 82
Username: Kaurimees
Posted on Thursday, October 16, 2008 - 06:00 am:
Model: 22dc279/62P
RN279fx0011307
Please quote ALL the LETTERS + NUMBERS found on any LABELS , BARCODES or STAMPED IN THE METAL CASING
Username: Kaurimees
well.....
Model: 22dc279/62P
RN279fx0011307
TOP749
prod nr: FD0199480011307
and nothing else.....
Username: Saraanddaz
need code for renault scenic philips radio model number 22dc459/62L product number fd0898224160038
Username: Wizlon
Hello, Can anyone help?
I'm trying to help a friend find a radio code for his Philips R660 Radio Cassette from his fathers Rover 200. His Dad recently passed away and the car sat unused for several months before being passed down to him. Subsequently the battery went flat and needed replacing. Since then the radio is asking for a code and he can not find any documentation at his fathers house or garage.
Any help much appreciated.
Thanks.
Code on side of product (Serial Number?) - RG349FV1083022
Username: Wizlon
opps. just read previous post -
'Please quote ALL the LETTERS + NUMBERS found on any LABELS , BARCODES or STAMPED IN THE METAL CASING'
Will get all details tomorrow.
Post Number: 83
Username: Kaurimees
Posted on Thursday, October 16, 2008 - 09:26 am: Model: 22dc279/62P
RN279fx0011307
TOP749
Your code should be 0224
Post Number: 84
Posted on Thursday, October 16, 2008 - 09:59 am:
The radio will have to be extracted from the dashboard.
Then please quote ALL the LETTERS and NUMBERS found on any LABELS , BARCODES and STAMPED IN THE RADIO CASING
Username: Donpapa3
It is working!!! You are STAR.
Thank You Very Much.
its a renault radiosat 6010, barcode 7704264120954, others numbers found are 9022 214 59624, has another barcode says code gravage with number 4160038 number etched in on it rn459fw4160038 thats all i can find thanks
Post Number: 85
Username: SaraanddazPosted on Thursday, October 16, its a renault radiosat 6010, barcode 7704264120954, others numbers found are 9022 214 59624, has another barcode says code gravage with number 4160038 number etched in on it rn459fw4160038 thats all i can find thanks
Sorry, these Serial Numbers aren`t in my PHILIPS database. If you email restoredclassic@aol.com they have a larger database and should be able to help. Mention this forum and there should be no charge.
Username: Waxnool
Hi i have problem with code after replaced car battery. All i can find is details on the radio label:
philips 22DC594/65
Serial: PHAPBFT9045110
some other number m/ch:044991
also 902221594659
Username: Jjsimpson
I am hoping you can provide me with the radio code for my 1998 Audi A8 Concert radio(4D0 035 186B).
SN AUZ5Z6V0026280
Username: Jsorensen
I need a radio code for my 2001 Mitsubishi Mirage De...when I was fixing the headlights I had to undo the battery.
Model #: MR472955
Ref. #: CQ-JB3910A
Serial#: 99A224617
If you could get me that code that would be awesome...Please email me @: jjsorensen07@yahoo.com
Thank you so much!!
thanks for you help ill email them now
Post Number: 86
Username: Jsorensen
Posted on Thursday, October 16, 2008 - 10:44 pm: I need a radio code for my 2001 Mitsubishi Mirage De...when I was fixing the headlights I had to undo the battery.
Model #: MR472955
Ref. #: CQ-JB3910A
Serial#: 99A224617
Thank you so much!!
Sorry , this is a MATSUSHITA unit and I don`t think the code will be available from any of these free Help Boards.
Try your Main Dealer or Ebay/Google for a larger Radio Decode Specialist
Post Number: 87
Username: JjsimpsonPosted on Thursday, October 16, 2008 - 09:31 pm: I am hoping you can provide me with the radio code for my 1998 Audi A8 Concert radio(4D0 035 186B).
SN AUZ5Z6V0026280
Sorry , the AUZ5Z is another MATSUSHITA unit and I don`t think the code will be available from any of these free Help Boards.
Post Number: 88
Username: Waxnool
Posted on Thursday, October 16, 2008 - 08:47 pm: Hi i have problem with code after replaced car battery. All i can find is details on the radio label:
philips 22DC594/65
also 902221594659
Your code should be 5870
Username: Cxzcxz
Hallo!
I need a radio code for my 1997 Peugeot 406 Phillips radio.
Model #: DC 722-65L
No#: FD 0097164001557
If you have a code email me: koziuri@hotmail.com
Thanks!
Post Number: 89
Username: Cxzcxz
Posted on Friday, October 17, 2008 - 02:43 pm: I need a radio code for my 1997 Peugeot 406 Phillips radio.
Model #: DC 722-65L
Please post ALL the NUMBERS+LETTERS found on any LABELS , BARCODES or STAMPED IN THE RADIO METALWORK.
Username: Vrolijkkoos
Hi,
The battery of our Renault is replaced and we don't have the radio code of our second hand Twingo.
Information on the side of the radio:
Model: 22DC239/62P
Prod no: FD0001370039202
Sn: RN239F10039202
It would be great if you could provide me the code for this radio.
Username: Tjbccs
I have 96 Audi A4 with Delta radio
Serial number is: AUZ1Z4S5456071
Can you help with the security code please?
Post Number: 90
Posted on Friday, October 17, 2008 - 04:22 pm: The battery of our Renault is replaced and we don't have the radio code of our second hand Twingo.
Model: 22DC239/62P
Sn: RN239F10039202
Please post ALLthe NUMBERS+LETTERS found on any LABELS , BARCODES or STAMPED IN THE RADIO METALWORK.
Post Number: 91
Username: Tjbccs
Posted on Friday, October 17, 2008 - 05:21 pm:
Sorry ,codes for the Audi AUZ1Z4 are not usually available from anyone on these free Help Boards.
It`s your Main Dealer or a larger , professional Radio Decode Specialist via Google or Ebay search
Username: Waxnool
REG ROOSTER Thank you so much for your help
My Son & Daughter wanted to extend to you our most heartfelt thanks for helping us.
Thank You Very Much.}
Username: Waxnool
Username: Waxnool
REG ROOSTER My husband and I are writing to say how much we appreciate the help
Information on the label on the right sideof the radio:
Model: 22DC239/62P
TOH916
RN239F10039202
8200041271TH916
8200 041 271 (in a box)
Label on left side:
8200041271TH916
Post Number: 92
Posted on Saturday, October 18, 2008 - 07:19 am: The battery of our Renault is replaced and we don't have the radio code of our second hand Twingo.
Model: 22DC239/62P
TOH916
RN239F10039202
8200041271TH916
Label on left side:
8200041271TH916
Sorry, these Serial Numbers aren`t in my PHILIPSdatabase. If you email restoredclassic@aol.com they have a larger database and should be able to help. Mention this forum and there should be no charge.
Username: Nickybbad
Hi Guys & hi Reg Rooster,
Please can you help me with my lost Code:
The Car is a BMW Z3 '99
The Serial number is PH7850W1401563
Other info on the radio was:
KW33/98
Index 00
Phillips
65.12-8 379 230
Its a BMW Business RDS Car Radio
Thanks in advance!
Nic
Post Number: 93
Username: Nickybbad
Posted on Saturday, October 18, 2008 - 09:44 am: Please can you help me with my lost Code:
KW33/98
Index 00
Phillips
65.12-8 379 230
Thanks in advance!
Username: Space1090
Hello, please can you tell me the code for my VW Radio Beta (Golf Mk3, 1994). I have 2 of them here - and no code from both :-(
Serial Number1: VWZ2Z2P1778525
Serial Number2: VWZ2Z2R2447247
Thanks a lot!
Post Number: 94
Username: Space1090
Posted on Saturday, October 18, 2008 - 02:16 pm:
The code for VWZ2Z2P1778525 is 1783
Unfortunately the later VWZ2Z2R2447247 is not in my GRUNDIG database but if you contact restoredclassic@aol.com then they should be able to help as they have a larger database. Mention this Ecoustics forum and there should be no charge.
Username: Mytumyeto
Acura legend '92 stock radio into my integra.
P/N:39100-SP0-A100-M1
REF.NO. : CM3919
Serial number: B11042862
Thank you
teatoe@gmail.com
Home > Message Board > Car Audio > Security Systems > Radio Codes For Free > Archive through October 18, 2008 [ « Previous ] [ Next » ]
