Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > 1400-1500RMS to work with - need opin...
Author Thread: 1400-1500RMS to work with - need opinions on new 12's
Username: Skateguy92
Post Number: 10
Well I finally blew one of my Type-R's in my expedition with my new box so im looking for a new setup. Hoping I can find some opinions on here.
Going in : 97 expedition
box : 2 2.3^ft tuned to 34htz (12")
amp : Hifonics Brutus 1500 (had it tested actually puttin out 14XX)
Just looking for an upgrade from my generic Alpines but im not looking to break the bank either.
Thoughts so far are Fi BT even though under powered a little should sound good.
Thanks in advance.
Username: Kingandsons07
TEAM REVOLUTION
Lincoln,NE
Post Number: 268
BT??? do u mean BTL or BL?
look at RE SX or RD Alpha
how much u want to spend?
Post Number: 11
I meant BL my bad. Im not really looking to spend much its just my daily ride but at the same time im still looking to upgrade and have something decent that will last me a while.
Ive always wanted a set of the RE SX but I dont know if I can shell out that much per sub.
Hopefully looking to spend 150-250 maybe 300 per sub.
TEAM REVOLUTION
Lincoln,NE
Post Number: 270
http://cgi.ebay.com/RE-AUDIO-SX12-D2-12-2000w-COMPETITION-CAR-SUB-SX-12_W0QQitem Z350120246317QQihZ022QQcategoryZ18805QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m15 3.l1262
$229.95 sound good :D
Username: Insearchofbass
Post Number: 10799
Those re sx subs should serve you well performance wise. And the price is good also.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 5877
either or switch up to a single 15" since you don't have much power to work with
TEAM REVOLUTION
Lincoln,NE
Post Number: 271
x2
Post Number: 10801
x3
Username: Basssquared
Kansas
Post Number: 2368
i've ran a Single 15" RE SX on 900 watts and loved it i can only imagine it would sound nicer on 14xx watts
Post Number: 12
Im kinda stuck with keeping the two 12's the main reason being I just had this box custom molded in the back of my truck.
Dont really feel like tossing out a brand new box.
I found and liked the AudioQue SDC2.5 and I really like the company from what I can tell and it sounds like the product is just as good, fits right in with my power range and for $140 a pop it almost sounds perfect.
I havnt heard the woofer in person though, any experience?
Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > 1400-1500RMS to work with - need opin... [ « Previous ] [ Next » ]
