Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > Focus remote starter - routine ok, d...
Author Thread: Focus remote starter - routine ok, does not start the engine
Username: Theolix
Montreal, QC
I Have a 2004 Focus - Zetec engine
Got a problem - Last week i had to go under the dash to change a relais; i've found a black box from a cellphone hands-free car-kit - no longer in use - removed it, changed the fuse.
Since then, the remote starter isn't working properly - lights flashing, horn signal, radio and air blower start working all the routine is ok, but the engine won't start.
I guess I touched "something", like the ignition wire? Or other thing? The starter is an ASTROSTART model, cheap - 2 buttons only and a led...
I intend to take a look tomorrow, but i am not sure what to verify.
Could someone please give me a hint on what kind of wire should i verify?? can be something else?
Thanks a lot for your help ! !
Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > Focus remote starter - routine ok, d... [ « Previous ] [ Next » ]
