Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > Saturn lw300 ipod help
Author Thread: Saturn lw300 ipod help
Username: Surferdude9371
Get loud or go home....
Post Number: 1403
my girlfriend has this as a temp car and wants to run a direct line from her stock HU to her ipod so i wont sound like crap any ideas?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8870
I'm guessing if the HU had inputs you wouldn't be asking this question cause then it would be easy.
Only other option is a converter that pipes the line input through the radios antenna connection. They work a ton better than a FM modulator, those are crap. But still not as good as direct input.
Post Number: 1405
thanks man
Post Number: 1406
any idea what they are exactly called or where to get them by chance?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8876
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=234550&i=142FMMOD01&tp=1 287
can probably get it even cheaper on ebay
Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > Saturn lw300 ipod help [ « Previous ] [ Next » ]
