Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > HT sub
Author Thread: HT sub
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2481
So im selling my 18" AA Avalanche becuase i just dont have enough space in my room for the box.
I an looking to get a 10" or 12" sub after the avalanche is sold. I think it would be cool to get a 10 or 12" avalanche if i could find one, but opinions?
Username: Insearchofbass
Post Number: 10769
Get one that can go sealed so you can hit those low notes since some movies hit down to 10 hz.
Username: Snarl2004
Post Number: 2482
you think a sealed box rather then ported around 18-22hz
Username: Snarl2004
Post Number: 2483
cuz my 18" ava was in a 24hz ported box, and it murdered the lows. made stuff fall of shelfs in the whole house lol
Username: The_image_dynamic
San Diego, California
Post Number: 4708
It is hard to beat the SS RL-S for HT use... like Sean said, in a sealed box. The issues are that they are expensive and require a huge box and alot of clean power. High-powered plate amps are not cheap. For a budget system that will still slam, the Diamond 3 series subs work great (for whatever reason) in HT subs. They were used in the Von Schweikert VRS/1 mini-sub which got stellar reviews. An added advantage is they only need 300-500RMS to get loud and they work in a much smaller box. HT is a completely different beast than car audio. The room size allows the bass waves to expand and you don't need mega power to shake the house. Paul knows this very well.
A pic is worth
1000 posts!!
Post Number: 18812
"The room size allows the bass waves to expand and you don't need mega power to shake the house. Paul knows this very well. "
You bet I do. Room acoustics play a big role also as well as sub placement. Depending on the room's decor you may need bass traps. A home is indeed a different animal than inside a car.
I'm so crazy about the feeling of bass in my movies/music I more than once considered an IB in my home. I just can't imagine topping that. Can you imagine using the entire room/house as part of the design/enclosure? Amazing.
Post Number: 10771
Ive seen sonotube setups online that supposedly were capable of 130 db. One hundred and thirty db in a house is a incredible feat and has to seem very loud.
Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > HT sub [ « Previous ] [ Next » ]
