Thread: Fi Q 15 question |
Bronze Member Username: Dan_white
Post Number: 89 Registered: Jun-08
| Posted on Thursday, November 06, 2008 - 01:52 am: |
Been runnin it for about 2-3 days now in my roughly 1.75-2cuft box with a pound of polyfill. The low's hurt my ears and shake the whole damn truck. Low's im guessin in lows 30's mid 30's? Dont have a frequency test cd as i cant make cd's anymore...but.... the notes a bit higher in rap songs dont hit as hard as the SX did. I realize that may just be the way it is but thats the only thing Im unhappy with in the Q. Sounds great and I know its not broken in... was just wondering if somethin else might help or if this is usually the case with the Q. Maybe tampering with the LPF? |
Gold Member Username: Livin_loud
COD4 Addict
Post Number: 2715 Registered: Jan-06
| Posted on Thursday, November 06, 2008 - 03:30 am: |
no, everything is fine. Q's don't really like the highs, from experience with mine at least... i'm assuming you have it in a sealed box, which is the best your going to get on higher note output. if you want to fill that gap i'd suggest finding a small 8-10" sub that takes 2-400wrms and run that as well. good powered components/6x9's in an enclosure may also do the trick |
Post Number: 90 Registered: Jun-08
| Posted on Thursday, November 06, 2008 - 03:58 am: |
i see. and running another sub would cause cancelation if im not mistaken and im pretty sure im not. ive yet to install my components. |
COD4 Addict
Post Number: 2717 Registered: Jan-06
| Posted on Thursday, November 06, 2008 - 04:04 am: |
correct, assuming you run that sub in the same frequency range, which you wouldn't be. the components will make a noticeable difference |
