Thread: Batery descisions |
Bronze Member Username: Lil_justin850
Justin smith, crestview,
Fl
Okalossa
Post Number: 19 Registered: Sep-08
| Posted on Wednesday, November 05, 2008 - 11:22 pm: |
well im getting my 200 amp alt here in a coulple days and im ready to get some batteries i think so hers what ive come up with yellow top up front hc2400 in the back or two yellow tops or finally two hc2400s i think that the hcs are better but on a practicality/ expenses rout what do you guys think about it i just want to be able to handle a zx2500.1 and my zx650.4 with the ac on hopefully thanks |
Gold Member Username: Snarl2004
Digital Design 9515,
Massive Audi...
Post Number: 2479 Registered: Dec-06
| Posted on Wednesday, November 05, 2008 - 11:28 pm: |
im running a P3000.1 (rated at 3000rms) ive got a 220 amp alt, stock battery in the front and a hc2400 in the back. my voltage never goes under 12.5 volts |
Massive Audi...
Post Number: 2480 Registered: Dec-06
| Posted on Wednesday, November 05, 2008 - 11:29 pm: |
i say deffinitly the hc2400 in the back they are great betterys. then a hc1400 under the hood |
Bronze Member Username: Wickedbass
Nashville,
Tn
Post Number: 56 Registered: Jan-08
| Posted on Wednesday, November 05, 2008 - 11:46 pm: |
^^^Agreed. I run two of the 2400s and love them. Also Odyssey and Powermaster make great batteries as well. http://www.odysseybatteries.com/ http://www.powermastermotorsports.com/mobile_audio.html |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8840 Registered: Jul-06
| Posted on Thursday, November 06, 2008 - 02:23 am: |
Yellow tops suck..... any of those batteries will be better |
Gold Member Username: Talon01
Team Revolution ,
Pa
Usa
Post Number: 1727 Registered: Jun-07
| Posted on Thursday, November 06, 2008 - 08:01 am: |
"Yellow tops suck..... " actually i did a ahead to head test with a yellow top and a kinetik1800. very close in size but on a burp the yellow top outperformed the kinetik. the kinetik will recharrge faster though. so for strtaight spl yellow top daily pounding kinetik. make sure you run the same batt up front and in back. wicked bass is right both of those batts are very good also. i actually prefer northstar batterys. |
Platinum Member Username: Insearchofbass
Post Number: 10755 Registered: Jun-04
| Posted on Thursday, November 06, 2008 - 10:16 am: |
Northstar is a very good battery. |
Silver Member Username: Ridinspinnas
Windsor,
Ontario
Post Number: 485 Registered: May-06
| Posted on Thursday, November 06, 2008 - 01:20 pm: |
im going to be running approx 2700 watts rms, will my one kinetik hc2400 and the big3 be alright until i get a ho alt? |
Gold Member Username: Snowball123
West Allis,
WI
Post Number: 1577 Registered: Oct-07
| Posted on Thursday, November 06, 2008 - 01:37 pm: |
just set the gains less until you get the alt then set the gains at your 2700 watts. |
Team Revolution ,
Pa
Usa
Post Number: 1732 Registered: Jun-07
| Posted on Thursday, November 06, 2008 - 01:38 pm: |
if you dont hammer it for long periods of time you should be ok but it is going to stress the alt. |
Platinum Member Username: Rovin
1 15 = 149.5 DBs Trinidad & T...
Post Number: 14328 Registered: Jul-05
| Posted on Thursday, November 06, 2008 - 07:49 pm: |
i have never heard anybody say yellow tops sux .... |
Fl
Okalossa
Post Number: 20 Registered: Sep-08
| Posted on Thursday, November 06, 2008 - 08:10 pm: |
well im just tired of voltage drops i khow what it does to amps im just trying to do this right i think i can get two yellow tops were i live at oreileys for 200 apiece i just dont know how long they have been sitting there i can also get hc2400s for 270+ like 50 bucks shipping on amazon ive also heard good things about d3100 but there real pricey arent they i know that with 3000+ rms you cant skimp on anything so thanks all |
Philadelphia,
PA
Post Number: 8857 Registered: Jul-06
| Posted on Thursday, November 06, 2008 - 08:58 pm: |
Must not read my posts.... cause I've said it like 1000 times |
Post Number: 10767 Registered: Jun-04
| Posted on Thursday, November 06, 2008 - 09:20 pm: |
Northstar has better batteries than powermaster. nsb 90 is 287.75 http://cell-phone-accessories-wholesale.com/index.asp?PageAction=VIEWPROD&ProdID=18034 |
Gold Member Username: The_image_dynamic
San Diego, California
Post Number: 4707 Registered: Dec-06
| Posted on Thursday, November 06, 2008 - 09:34 pm: |
Sealed lead batteries have been around since the late 60's/early 70's when Gates made them for commercial use, but Optima designed the Spiral Cell technology for automobile use in the 80's. And while I agree that they don't seem to be as good as years ago... very few successful products are... to say they "suck" is a bit of an overstatement. |
Massive Audi...
Post Number: 2484 Registered: Dec-06
| Posted on Thursday, November 06, 2008 - 09:42 pm: |
theres some hc2400's floating around ca.com you can get one for a good price. i bought mine for 250 shipped bout a year and a half ago. it was only used for 1 month in a comp car. |
Philadelphia,
PA
Post Number: 8868 Registered: Jul-06
| Posted on Friday, November 07, 2008 - 01:33 am: |
Well I guess they don't "suck" all together. But for car audio purposes they don't stack up to odyssey, kenitik, etc. |
Post Number: 10770 Registered: Jun-04
| Posted on Friday, November 07, 2008 - 07:30 am: |
Two northstar batteries will impress you. My brother ran 7000 watts for 30 seconds using a northstar nsb 90 and a kinetic 1800 under the hood but you sound like you have the room to run two northstars only drawback is they are 83 pounds each. ps....Dont run a kinetic and a nsb 90 together for daily they arent really made to run together. |
Gold Member Username: Renegadesrun
Lafayette,
IN
US
Post Number: 1006 Registered: Oct-04
| Posted on Friday, November 07, 2008 - 09:57 pm: |
Id save my money and buy this. http://cgi.ebay.com/Hooked-on-Phonics-Learn-to-Read-K-3-ages-4-8_W0QQitemZ260309 159445QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item260309159445&_trksid=p3286. c0.m14&_trkparms=72%3A1420%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 |
Post Number: 4727 Registered: Dec-06
| Posted on Friday, November 07, 2008 - 10:09 pm: |
Renegade is back and dishing out the truth! What up Les lol. Although... these days it's probably called "Hooked On Phizzonics". |
Lafayette,
IN
US
Post Number: 1008 Registered: Oct-04
| Posted on Friday, November 07, 2008 - 11:12 pm: |
Should i just laugh at that or just wait for the racist police to let me know if i can? Sup man? Sick of all the political threads so i felt like stirring the collective pots for amusements purposes only.  |
Fl
Okalossa
Post Number: 23 Registered: Sep-08
| Posted on Saturday, November 08, 2008 - 12:00 am: |
well if i think im just gonna get 3 yellow tops cause ive heard that more decent batteries are better than one badass one plus i jut like being able to go and by them and not worry about sipping |
Post Number: 10795 Registered: Jun-04
| Posted on Saturday, November 08, 2008 - 06:56 am: |
Three of those should do just fine. |
Lafayette,
IN
US
Post Number: 1010 Registered: Oct-04
| Posted on Saturday, November 08, 2008 - 01:23 pm: |
Optimas are junk IMO. Think Kinetik, or Audio Force, or any of the numerous batteries rebadged under different names by the same original distributor. |
