Thread: Atomic 3000D |
Gold Member Username: Loc_out
Team RE XXX
Post Number: 2638 Registered: Feb-05
| Posted on Wednesday, November 05, 2008 - 05:01 pm: |
Sorry about posting on the wrong section. I know this amp is solid my question is its rated at 3000@ 1ohm. What kind of power would i see at .5? Would it be safe to run it as a daily? Look forward to the replies. |
Gold Member Username: Mixmastaspig
Team RD,
Post Number: 1911 Registered: Sep-05
| Posted on Wednesday, November 05, 2008 - 06:09 pm: |
Don't quote me on this but I assume you will get roughly ~4000rms @ .5 ohm as long as you have a proper charging system. I do this to figure it out fast .5ohm= 4000ish 1ohm= 3000 2ohm= 1500 4ohm= 725 |
Gold Member Username: Jkidder
Worlds gunna end,
In
2012
Post Number: 3847 Registered: Nov-05
| Posted on Wednesday, November 05, 2008 - 08:20 pm: |
yea thats not entirely accurate at all lol |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 780 Registered: Nov-06
| Posted on Wednesday, November 05, 2008 - 08:31 pm: |
it all depends on ur voltage really. i'd imagine u'll pull probably in a range of 400amps @ .5ohms or possibly more. given u can keep voltage @ 12.8 or higher, 3700wrms would be my guess. I'd look at the sundown 3k's test results to give u a "general" idea. |
Gold Member Username: Andrew571
Stillwater/Edmond,
Oklahoma
Post Number: 2102 Registered: Oct-05
| Posted on Wednesday, November 05, 2008 - 08:41 pm: |
i run my AT7000.1 @ 0.5ohm and its beast. Just gotta have good charging. I run a HO alt and 5 kinetiks. Also the 3000.1 is pretty efficient, but the 5000 is more. Then the 7000 is the most eff. |
