Thread: Aero Ports |
Bronze Member Username: Yfz_rcr_12
NC
Post Number: 16 Registered: Aug-08
| Posted on Tuesday, November 04, 2008 - 02:56 pm: |
I have searched the forum, and didn't really find anything, so could someone help me to understand aero ports? How do you tune your box using them? Do they have any advantages over a slot port? Are there any aero port box calculators? |
Gold Member Username: Talon01
Team Revolution ,
Pa
Usa
Post Number: 1719 Registered: Jun-07
| Posted on Tuesday, November 04, 2008 - 03:11 pm: |
it is actually very simple. figure your round port calculations for the aero you are using but with one diff. the aero is 5" then add the tube length to it. example i need a 4" aero at 12" so i need to cut the aero tube to 7" bute with the total flare it will be 13". one inch of mount and taper of the flare. the aero will flow air better in the correct application. |
NC
Post Number: 17 Registered: Aug-08
| Posted on Tuesday, November 04, 2008 - 04:29 pm: |
Volume of Box in Cubic Feet: 2.66 Tuning frequency: 33 Port diameter: 4 Number of Ports: 2 Straight Length Port required 20.46 Flare Length Port required 21.46 Does this mean I need two 21.46 inch ports or that the total port length should be 21.46? |
Platinum Member Username: Insearchofbass
Post Number: 10743 Registered: Jun-04
| Posted on Tuesday, November 04, 2008 - 04:32 pm: |
Yes and they only make 17 inch lengths. |
Team Revolution ,
Pa
Usa
Post Number: 1723 Registered: Jun-07
| Posted on Tuesday, November 04, 2008 - 04:42 pm: |
drop to 2 3" aero ports. how many subs and power? |
Post Number: 10745 Registered: Jun-04
| Posted on Tuesday, November 04, 2008 - 04:47 pm: |
Good idea. It should be enough port area for average power amounts. |
NC
Post Number: 18 Registered: Aug-08
| Posted on Tuesday, November 04, 2008 - 04:55 pm: |
1 sub about 1200 watts rms. Do you think there would be port noise issues with 2 3" ports? |
Post Number: 10746 Registered: Jun-04
| Posted on Tuesday, November 04, 2008 - 05:29 pm: |
Do two 3 inch aeros you wont have port noise because of the flares. |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2067 Registered: May-07
| Posted on Tuesday, November 04, 2008 - 09:11 pm: |
Not trying to thread dump here... Do you ride mx? Were both Donnie, and have a single sub off 1200w |
NC
Post Number: 19 Registered: Aug-08
| Posted on Wednesday, November 05, 2008 - 05:03 pm: |
I actually race ATVs at a local track called North Carolina Motorsports Park. I ride a YFZ 450 and I'm #12, hence the username. |
Illinois
Braaap MX
Post Number: 2069 Registered: May-07
| Posted on Wednesday, November 05, 2008 - 05:32 pm: |
Ah gotcha. Ya I ride bikes, don't race tho, but do keep it on the mx track. I ride a YZ250. Yamaha FTW! And good luck with the box, post some pics when done. |
