Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > Critical mass ul12's
Author Thread: Critical mass ul12's
Username: Mendonmafia
Post Number: 1502
Ok as you may know i have been very disappointed with the output of my sx's and i plan to upgrade yet agian. i still dont have room for 15's so im stuck with 12's
I am really interested in the critical mass ul 12's but am wondering if there is similar performance drivers for a lower price. i dont care that the ul's only weight 16lbs i just like how they only need 2 cubes ported and how efficient they are.
also how many hc2400's should i get to properly power 5krms. 160 amp alt is gonna have to do tho.
Username: Wickedbass
Nashville, Tn
Post Number: 41
Can't really help much with the sub question but as far as the hc2400's two of them should be sufficient for 5krms. I have two of them and it is complete overkill (although I am only running a 3250.1). Hope this helps.
Post Number: 1503
yes that helped very much. thanks a lot.
now for the subs
Username: Deadrabit
Marionville, MO
Post Number: 1016
have u seen the american bass subwoofers?
i know a place that can get them pretty cheap
Username: Jkidder
Worlds gunna end, In
2012
Post Number: 3845
lol you're the worst BLK. no clue how to read and no common sense. shut the fvuck up.
Username: Snowball123
West Allis, WI
Post Number: 1549
x2
Username: Nd4spd18
Philadelphia, PA
Post Number: 8819
I think you should definitely get the ULs and write a review with pics and vids and the whole nine yards.
Just because I've always wanted to hear a system with those and haven't got to :-)
Post Number: 1504
I would love to but i dont want to spend 1600 on subs if i can have the same performance for less.
Username: 04redmach1
Es DEALER, GA
Post Number: 2423
They are nice subs for sure, but honestly the only advantage is weight. I have delt with 1 myself in a customers ride and used it for the weight factor in a mustang. Great little sub for sure, but if you don't care about weight, you can for sure save some money elsewhere.
Kevin
Username: Cozce
St. Louis ILLside
U.S.A.
Post Number: 363
I'd get one. Just to have one.
Post Number: 1506
kevin what would you reccomend. the enclosure size is also a benefit. only needs 2 cubes ported.
Es DEALER, GA
Post Number: 2424
Honestly, on 5K and 2 cubes ported the UL is probably the best choice for you. Hard to find a sub to take 2500 rms and fit in such small enclosure with the same performance. $1600 is a good price if that is with warranty as well :-)
Kevin
Post Number: 1508
its 2 cubes each just in case i wasn't clear, but yea thats still pretty small for 2500 rms. and no 1600 is not with the warranty thats off of ca.com. w/ warranty would prob be like 4k.
Es DEALER, GA
Post Number: 2425
Well, if you want a warranty I can probably do something for you, but it will be a little more, but not much. Shoot me an email.
Kevin
lowhz01@yahoo.com
Post Number: 1512
any other recommendations?
Home > Message Board > Car Audio > Subwoofers > Archive through November 14, 2008 > Critical mass ul12's [ « Previous ] [ Next » ]
