Home > Message Board > Car Audio > Multimedia Systems > Which is better Dual xdvd8181 or jene...
Author Thread: Which is better Dual xdvd8181 or jenen 9311ts?
Username: Quest4life
I went to Walmart to pick up the Jensen that was on close out,Or so I thought. The display unit was the jensen9311ts. What they give you is the Dual 8181. They look very similar and with the mind set I was buying the Jensen I didn't notice. I could take it back however they do not have any of the Jensens left so I would have to just get a refund. Does anyone know the difference between the two? Thanks
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Multimedia Systems > Which is better Dual xdvd8181 or jene... [ « Previous ] [ Next » ]
