Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > Viper 5900 SST & 1701G Remote Start L...
Author Thread: Viper 5900 SST & 1701G Remote Start Locking problems
Username: Dsteinmann
I installed the 5900 with the 1701g. But if its armed then remote started it keeps tring to lock the doors every 10 seconds or so? It Does not do this when unarmed and remote started. Or if i arm it then remote start it then unarm it quites trying to unlock? Any Ideas
So i guess i narrowed it down a bit I unplugged the Door Lock Harness (green & Blue) and also the H2 Harness Off the Viper In one of its locking fits. And it was still doing it. So I guess it may be the 1701G (the Settings are still default). I didnt see anything else on the Viper that could be sending out lock commands with the 2 harness removed. So is it a setting on the Truck or the 1701g or could this be a flakey 1701g. I did notice it doesnt always do it now though.
Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > Viper 5900 SST & 1701G Remote Start L... [ « Previous ] [ Next » ]
