Thread: 2002 bmw z3 radio code |
New member Username: Tnnslvr
Post Number: 1 Registered: Sep-08
| Posted on Sunday, September 21, 2008 - 08:20 pm: |
Help, I took my husbands car in because the turn signal was clicking too fast. The mechanic told me the battery needed to be replaced. Now we can't listen to the radio because we can't find the security code. Can anyone help, the radio is a BMW Business cd and the serial #29965225. Please help, Thanks |
Bronze Member Username: Regrooster
Post Number: 26 Registered: Aug-08
| Posted on Monday, September 22, 2008 - 10:08 am: |
Quote the radio MAKE + MODEL and ALL the NUMBERS+LETTERS found on any labels,barcodes or stamped in the metal casing |
Post Number: 2 Registered: Sep-08
| Posted on Monday, September 22, 2008 - 11:24 am: |
bmw business cd bmw part#65126909884 cd43 blaupunkt part#7640273343/7640273643 harmon kardon speakers hope this helps, thnx |
Post Number: 27 Registered: Aug-08
| Posted on Monday, September 22, 2008 - 01:37 pm: |
bmw business cd bmw part#65126909884 cd43 blaupunkt part#7640273343/7640273643 There should be another Serial Number , usually stamped in the metal casing...possibly beginning with BP273++++++++++ |
Post Number: 3 Registered: Sep-08
| Posted on Monday, September 22, 2008 - 03:32 pm: |
didn't actually take the radio out to get the serial #. i used the trick of pushing the m button to get it. there were no letters only numbers. 29965225 was the only thing that came up. don't really want to take the radio out if i don't have to. |
Post Number: 28 Registered: Aug-08
| Posted on Monday, September 22, 2008 - 06:55 pm: |
29965225 was the only thing that came up. don't really want to take the radio out if i don't have to. Sorry , I can`t help then. |
