Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Electrical Terms
Author Thread: Electrical Terms
Username: Roentgen
North Carolina
What does ground strap and ground return mean & when you upgrade them, how does it benefit your electrical system?
Also, does anyone think using 2AWG power cable is a little too big to run sub amps. It's beneficial to do this for future upgrades, but 4AWG is big enough for 1000 watt amps. Just wanted to get some feedback on what size to get -4AWG or 2AWG since none of my amps will go above 1000 amps.
Username: Pat_l
Tucson, AZ
Post Number: 204
Stick with 2AWG Wire, 2AWG is used mostly for 2 AMP's sharing the same power cable or its probably benifical in compition.
Username: Pat_l
Tucson, AZ
Post Number: 205
Opp's, Typo i ment stick with 4AWG Wire sorry.
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 48
4 guage is fine for the average system. 2 guage or 0 guage is for the big boys. As for the ground strap, or ground return, I am not sure what you mean. However I will tell you I always run a 4 guage wire between my alt and battery, and from my battery to ground. By adding a second wire you alow for more current flow with less restriction. As for the benifit on the ground side of the electrical system. Electricity flows from ground to positive. (most people don't know this). So by adding a second shorter ground wire you are again increasing the current flow, and reducing resistance.
Username: Glasswolf
NorthWest, Michigan
Post Number: 4401
wire gauge is based on distance, and current.
see here:
http://www.the12volt.com/info/recwirsz.asp
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Electrical Terms [ « Previous ] [ Next » ]
