Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Shock sensor placement
Author Thread: Shock sensor placement
Username: Kragan
Post Number: 19
Anyone have any suggestions for where to place the shock senor? I have a 2002 focus and right now I can rock it back and forth without the shock sensor triggering. I have played with the sensitivity but it did not help much.
Thanks
neonb
Were is it located now? Normally they locate them toward the bottom of the steering column.
Username: Kragan
Post Number: 20
at the moment I have it behind the center console below the head unit.
neonb
In my last two cars and some of my friends it has been located toward the bottom of the steering column. Try that set the sensitivity, hit the windshield and see if that works...
Username: Kragan
Post Number: 22
Thanks for the help. As soon as I get home from work I will give it a shot.
Thanks again
yes you need the sensor under the steering column. Then play with the sensitivity some more if that doesn't work then your sensor may be bad.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Shock sensor placement [ « Previous ] [ Next » ]
