Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > How to disable handbreak immobiliser ...
Author Thread: How to disable handbreak immobiliser on cliford g4
Username: Gaz2374
hey all really need this sorting my car wont start by key but will only remote start on fob as the clamshell has broke on my cliford g4 concept 500 and its going to cost more to get it towed to the security place 4 miles away than it is to fix it so can someone help as to disabling the handbreak shut off so i can save some money and drive it to get fixed.
Username: Gaz2374
done it its ok
Home > Message Board > Car Audio > Security Systems > Archive through January 22, 2009 > How to disable handbreak immobiliser ... [ « Previous ] [ Next » ]
