Home > Message Board > Car Audio > Security Systems > Radio Codes For Free
  Thread Last Poster Posts Pages Last Post
Archive through July 21, 2009Kevin Medley100 2009-07-21  07:46 ET
Archive through May 31, 2009ND100 2009-05-31  11:33 ET
Archive through March 28, 2009Reg Rooster100 2009-03-28  09:59 ET
Archive through February 03, 2009Humberto Galindo100 2009-02-03  12:04 ET
Archive through December 22, 2008Reg Rooster100 2008-12-22  11:20 ET
Archive through November 10, 2008Jeffrey100 2008-11-10  00:05 ET
Archive through October 18, 2008tito100 2008-10-18  22:22 ET
Archive through October 03, 2008Reg Rooster100 2008-10-03  12:03 ET
Closed Closed: New threads not accepted on this page
Author Thread: Radio Codes For Free
Username: Durdesire
Hi I just purchased a 98 range rover can anyone help me get the radio code? Radio Diversity by land rover(original Radio)
Type No. Pu-9887A
Rover Part No. AMR2672
FCC ID AX2PU9887A
And some other numbers embeded on the radio r as followed;
311-1591
310-1527
CR0195V0025783
Username: Regrooster
Post Number: 1469
Josue Perez-Cejuela
Username: Jnpc
Registered: Jul-09 Posted on Monday, July 20, 2009 - 05:57 pm:
Because of a change of battery,my radio's locked. I want to unlock it.My car is a Peugeot 309.The radio is a Clarion Product N: PU-9318A
Serial N: 0110305.
Thanks
I believe that this Clarion uses a hard-wired code and will require further information (The code for this model is NOT calculated using the Serial Number).
If you email
restoredclassic@aol.com
Then they should be able to provide further help.
Mention this forum
Post Number: 1470
ohn
Username: Durdesire
Registered: Jul-09 Posted on Tuesday, July 21, 2009 - 03:11 pm:
Type No. Pu-9887A
FCC ID AX2PU9887A
311-1591
310-1527
CR0195V0025783
Duplicate request!
Multi-posted requests are ignored as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
If you are that impatient for your code then try an online Decode Service who will supply your code by return.
Post Number: 1471
Kevin Medley
Username: Shakeyblakey
Registered: Jul-09 Posted on Tuesday, July 21, 2009 - 07:46 am:
heya, my fingers are very tightly crossed in the hope you can help me. i have a renault clio rt from 1994 and because i am a learner at the moment it isnt really getting driven, anyway ive ended up not only disconnecting the battery so the stereo is locked but also put some codes i found in my paper work into it that were all wrong so now it wont let me put a code in. it says itll take 2 - 4 - 8 - 16 - 32 minutes of being left on to let me put one in again in between each try, but im not driving it so i cant really have it on that long, basically im a big pain the butt.
the only code i can find is on the back of the manual
NE558-77 11 092 979-04 1992
its a philips cassette radio, im not sure what else you may need for it....?
The radio will have to be removed from the dashboard so that you can quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Post Number: 1472
Marc Bergmann
Username: Taffxxl
Detmold, NRW
Germany
Registered: Jul-09 Posted on Monday, July 20, 2009 - 05:39 am:
Hello,
i need the code for a VW alpha IV Radio
You are my last chance...
please help me...
here the Numbers on the Radio:
ALPHA-IV
VWZ6Z1T1461291
Philips
1H0 C35 153A
9022 215 87716 00
003 9641 1461291
Not available for free from anywhere on the Internet
Main VW Dealer or a Decoding Service only
Post Number: 1473
hris Clarke
Username: Rafchris
Registered: Jul-09 Posted on Sunday, July 19, 2009 - 07:38 pm:
Hello there!
Usual replaced battery problem and was wondering if you could find my security code for me.
Renault Clio
Model No: 22dc279/62
Product No: FD0100230070212
TOG843
Serial: RN279FY0070212
Bar Code: 7700433948TG843
Try code 5577
Username: Luis39
Lisbon
Portugal
Heya Guys
Wonder if you could help me please, I disconnected the battery on my Peugeot 106 the other day (silly me) and now it wants a code....
Its a
Clarion PU-2294A ( C )
CL040130853008
286-8497-33
96 392 195 80
Post Number: 1485
luis martinho
Username: Luis39
Lisbon
Portugal
Registered: Feb-09 Posted on Wednesday, July 22, 2009 - 10:57 am:
Heya Guys
Its a
CL040130853008
286-8497-33
96 392 195 80
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then try your Main Dealer or a Decoding Service
Username: Luis39
Lisbon
Portugal
Tks Reg Rooster
Username: Philmax
hi ,just been asked if i can help find a radio code for a renault leguna as my mate has no internet.
not sure what you need to work out code.
there is a number rn279fy0076265 and also a barcode number 7700433948tq367 .
the model no: is 22dc279/62 .
would be great if someone knows how to find this as its quite old but still works.thanks for any advice.
Username: Darvis2
VW GAMMA V
VWZ3Z3Y7637416
Username: Kingsave
Please i need help to my audiocar, i have change battery and my creazy head not found more dthe security code.
Model no:22DC259/62P
Prod. no:FD0200130082043
Tor 194
RN259FY0082043
barcode
7700434424TR194
7700434 424
Please if is possible.
gianlucatatti@tiscali.it
Username: Alex12
hello, I disconected my radio and I don't know where the code is !
my radio is a Philips :
Model No : 22DC279/62
Q319 Secuyrity
RN279F40285484
Prod N° : FD0804060285484
Would be great if you could help me, it would solve my vacations !!!!
Thanks in advance ...
//Alex12
Username: Axon003
hi i need code for Renault Megane Radio
Model NO 22DC258/62B
PROD NO FD0101230048575
BARCODE 8200057673TL383
TOL383
RN258F10048575
Thanks
Username: Kingen10
Hi I need a code to my Renault Laguna, Philips radiosat 6000 Model 22DC481/62
S/N: Rn481FX9308442
Thanks in advance:-)
Post Number: 1489
TOMMY GUNNARSSON
Username: Kingen10
Registered: Jul-09 Posted on Tuesday, July 28, 2009 - 04:36 pm:
S/N: Rn481FX9308442
Thanks in advance
Sorry...not in my Philips database
Post Number: 1490
ost Number: 1
Registered: Jul-09 Posted on Tuesday, July 28, 2009 - 03:55 pm:
TOL383
RN258F10048575
Try code 3327
Post Number: 1491
lex Guiral
Username: Alex12
Registered: Jul-09 Posted on Tuesday, July 28, 2009 - 08:57 am:
Q319 Secuyrity
RN279F40285484
Try code 9647
Post Number: 1492
Gianluca
Username: Kingsave
Registered: Jul-09 Posted on Monday, July 27, 2009 - 03:41 pm:
Tor 194
RN259FY0082043
barcode
7700434424TR194
7700434 424
Sorry...not in my database
Post Number: 1493
darius
Username: Darvis2
Registered: Apr-09 Posted on Monday, July 27, 2009 - 03:12 pm:
VW GAMMA V
VWZ3Z3Y7637416
This radio is made by SONY and unfortunately the code is not available for free from anywhere on the Internet.
Main Dealer or a Decoding Service only
Post Number: 1494
hilmaxam
Username: Philmax
Registered: Jul-09 Posted on Monday, July 27, 2009 - 09:06 am:
Sorry ....not in my Philips database
Username: Wiep76
Volkwagen Touran
Type radio: Becker Indianapolis Pro
BE 7955
S/N 65008682
Thanx in advance
Post Number: 1542
Wybren
Username: Wiep76
Registered: Jul-09 Posted on Friday, July 31, 2009 - 02:08 pm:
Volkwagen Touran
BE 7955
S/N 65008682
Thanx in advance
Duplicate request!
Username: Wkprojects
i need a code car audio, v40 volvo 2001
Username: Tace
Hey could i get a code for my renault scenic(2006):
MAKE: RENAULT
MODEL: RENRDW240-10
MO97
SERIAL: RNRD7650003282
PROD NO: FD0105410003282
Thanks
Username: Vou200
please help...
I just bought a bmw 316ti compact and disconnected the battery(to charge it). so my radio needs a code which i cannot find.
TYP. becker indianapolis
Mod. BE 7922
Ser. 55010704
EC. 102
please help.....
Post Number: 1579
kprojects
Registered: Aug-09 Posted on Monday, August 03, 2009 - 02:01 am:
Insufficient information.
Post the radio make+model+all the letters + numbers
Post Number: 1580
ace87
Username: Tace
Registered: Mar-09 Posted on Monday, August 03, 2009 - 12:03 pm:
MAKE: RENAULT
MODEL: RENRDW240-10
MO97
Thanks
Try code 1991
Post Number: 1581
ew member
Username: Vou200
Registered: Aug-09 Posted on Monday, August 03, 2009 - 01:11 pm:
please help...
Mod. BE 7922
Ser. 55010704
EC. 102
Try code 52223
Username: Andre123
Hello,
I need the key code for VW radio-navigationssystem MFD.
Serial number VWZ1Z7B6309727.
Help pls!!!
Thank you in advance!
Best regards,
Andre
Username: Virus79
Hi,
My battery went flat and I've lost my radio code, it's a Pegueot 106 Zest with a Phillips radio/cassette.
All the codes on it are:
PHAPKF19305259
TO7554
Product No. - FD100179305259
Model No. - 22RC200/65
Thank you in advance for your help :-)
Username: Predfan04
hi , reg
hope this is enough info for you to help its from a renualt senic
mod num :22dc461762L
prod num:FD0898384029471
BARCODE:7700433072J194
SER NUM {STAMPEDONSIDE}:RN461FW4029471
its a RADIO SAT 6010
PHILIPS 22DC461/62L
COULD PLS HELP ME ! THANX IN ADVANCE PREDFAN
Username: Arindus
I just bought a Mitsubishi radio/cassette and tried to install into my 2002 Mitsubishi Galant. The Code message displays. The model # is MR238340 and the seria # is 7430A667A.Can anyone help me figure out the code email me at arindus@juno.com
Post Number: 1651
Alan Marks
Username: Arindus
Registered: Aug-09 Posted on Wednesday, August 19, 2009 - 12:40 pm:
MITSUBISHI codes are NOT obtainable for free from anywhere on the Internet.
Main Dealer or Decoding Service only
Post Number: 1652
paul rooney
Username: Predfan04
Registered: Aug-09 Posted on Tuesday, August 18, 2009 - 12:55 pm:
hi , reg
:RN461FW4029471
PHILIPS 22DC461/62L
COULD PLS HELP ME ! THANX IN ADVANCE PREDFAN}
Post Number: 1653
Richard Fox
Username: Virus79
Registered: Aug-09 Posted on Tuesday, August 18, 2009 - 11:38 am:
Hi,
PHAPKF19305259
TO7554
Post Number: 1654
Andre
Username: Andre123
Registered: Aug-09 Posted on Tuesday, August 18, 2009 - 08:38 am:
Hello,
Help pls!!!
The majority of VW codes ( including this VW BLAUPUNKT ) are not obtainable for free using the Serial Number from anywhere on the Internet
Main VW Dealer or Decoding Service only
Username: Lobice
Hi,
I lost my car radio code... Could you help me please?
Model: 22D279/62Z
TOJ579
RN279F10184363
FD0201470184363
Thanks in advance for your help
Post Number: 1680
Cippo Lippo
Username: Lobice
Registered: Aug-09 Posted on Saturday, August 22, 2009 - 11:15 am:
Hi,
Model: 22D279/62Z
TOJ579
RN279F10184363
FD0201470184363
Try code 6981
Username: Acchilees
my battery on laguna died
and now, with the new one, it requires code
serial: RNRD0140234030
bar c: 8200247962TN342
other: FD0504470234030
Username: Radiovolvo
Hi my battery died and I need the code for my Volvo V40 radio.
The car is a P-Reg 1997 1.8i
Thanks,
Ray
Username: Soundout
Hi,
Need a code for a
Delco
No 09136107
Type CDR500 (e)
2F4
GM150010318805
supplier 4660103MH
ca135124
Many thanks in advance to whoever may help myself and the idiot who through out the radio code(myself)
Soundout
Post Number: 1704
mitch cower
Username: Soundout
Registered: Aug-09 Posted on Tuesday, August 25, 2009 - 09:35 am:
Hi,
Need a code for a
Delco
No 09136107
Type CDR500 (e)
2F4
GM150010318805
supplier 4660103MH
ca135124
Unfortunately DELCO codes are not available (using the Serial Number ) for free from anywhere on the Internet as they require access to the original factory database.
Main Dealer or a Decoding Service or your local Car Radio / Audio Shop
Post Number: 1705
Registered: Aug-09 Posted on Tuesday, August 25, 2009 - 07:05 am:
Try code 2652
Username: Bluerahaf
Hi
Could anyone help me with unlockig radio?
Chrysler radio
Model no.: P05064363AA-A
S/NO : T 00 AM 207 6 C1277
Many thanks for answer.
Post Number: 1707
bluerahaf
Username: Bluerahaf
Registered: Aug-09 Posted on Tuesday, August 25, 2009 - 06:07 pm:
Hi
Chrysler radio
Sorry ...your Serial Number is not in my small CHRYSLER database.
I`ve sent you a PM suggesting another possible free source for Chrysler codes.
Username: Bluerahaf
thanks (Reg Rooster) for the reply,
but what is the (PM)? sorry I'm new.
Post Number: 1708
PM = Private Message or check your email
Username: Bluerahaf
nothing on both
Post Number: 1709
Sorry...your code is not in my CHRYSLER database
However you can try asking here (for free ) on this other forum
http://forum.eserviceinfo.com/viewforum.php?f=8
You must first
1....Register
2....Log In
3...Then ask your question
If you do not register and log in
then the question will most likely be ignored and may not be answered.
The database required for this particular code is very scarce but I know that there is at least one person on that forum who has a copy ...provided he sees your question (and is not on holiday ).
If you do get an answer, would you mind letting me know the correct code as any information is always useful in trying to "crack" these codes
Good luck
Reg
Username: Bluerahaf
thanks & I will.
Username: Blckcar
Hi,
I am selling my Renault clio and I'm replacing my headunit with the old one... The code in the booklet doesn't work.
Can you help?
Product Number: FD004350920620
Model Number: 22DC278/62B
:8200057681
:RN278540920620
Thanks.
Post Number: 1710
Alex
Username: Blckcar
Registered: Aug-09 Posted on Wednesday, August 26, 2009 - 05:13 am:
Hi,
Can you help?
:8200057681
:RN278540920620
Try emailing
to see if they can help
Mention this forum
Username: Kp31
Hi,
I was wondering if anyone could help me with a code for my stereo please?
It's a blaupunkt car 300 (D)
Serial: GM0300v4167870
No: 90532620
7647852320
If you could help be much appreciated.
Post Number: 1725
katherine pallett
Username: Kp31
Registered: Aug-09 Posted on Thursday, August 27, 2009 - 08:31 am:
Hi,
No: 90532620
7647852320
Duplicate request ...Already answered !
Please do NOT post the same request more than once as it is both timewasting and annoying
Username: Bikerclaire
Hi,
I just bought a second hand Rover 416I and need a code for a Rover R770 radio cassette.
Model 22DC594/60B
9022 215 94601
S/N is RG594FW1009208
Can anyone help please?
Post Number: 1735
claire reeves
Registered: Aug-09 Posted on Friday, August 28, 2009 - 09:28 am:
Hi,
Model 22DC594/60B
9022 215 94601
Sorry ...not in my database
Try emailing
to see if they can help.
Mention this Forum
Ok, thanks for trying Reg
Username: Hamilton301
Hello guys. Can u help me?
I have founded that on my car radio
22DC259/62P
TOG873
RN259F10311739
FD0501410311739
Thanks a lot.
Post Number: 1761
zygis
Registered: Sep-09 Posted on Tuesday, September 01, 2009 - 10:32 am:
22DC259/62P
TOG873
RN259F10311739
FD0501410311739
Try code 5578
Username: Vou200
Hello..
i have a problem with a Grundig radio with RDS
thats on it:
GR092850106978
WKC3705RDSRS9-18296GHE2700
GRUNDIG 3705 RDS
Informat
01 0092803701069785
THANK'S in advance
Post Number: 1776
imi vou
Username: Vou200
Registered: Sep-09 Posted on Thursday, September 03, 2009 - 11:37 am:
Hello..
thats on it:
GR092850106978
GRUNDIG 3705 RDS
Informat
01 0092803701069785
THANK'S in advance
This code will not be available for free from anywhere on the Internet.
Try your Main Dealer or a Decoding Service
Username: Rammerz2000
Milton Keynes, Buckinghamshire
ENGLAND
Hi,
I am hoping you are able to help me, I had to disconnect my battery for some work to be done on my car now I need a code for my radio.
Could you please tell me where I can obtain the correct code?
My car is a Renault Clio 2004 reg
Model - 22DC278/62B
FD070405072419
RN278F40721419
8200057681TD715
Thank you for your help
Karen
*Sorry if this post appears twice as it didn't seem to register first time*
Username: Cat88dog
Hi, can you help with a code for my Vauxhall CAR 300 Blaupunkt, part no. 7645852320, S/N GM1300V6726900. Thanks. A pint for you on this one. XX
Username: Roder89
Hey, i need a code for a VW PREMIUM AUDIO radio...i already take out my radio but i didnt find anything, only the serial number, wich is VWZ9Z7S3114417...already downloaded the VW RADIO CODE CALCULATOR but it only accept numbers after the last "Z", and my serial have a "S" in the middle ...if you know anything about getting the code pleaaase help me!
Thanks for ur help :D
Username: Roder89
sorry for the double post :S
Username: Joey580
i need a key code for radio
BECKER INDIANAPOLIS PRO
TYPE BE 7952
SERIAL NO 65000514
PLEASE HELP
many thanks
sorry for de double post
Post Number: 1797
Username: Joey580
Registered: Sep-09 Posted on Monday, September 07, 2009 - 09:25 am:
TYPE BE 7952
SERIAL NO 65000514
PLEASE HELP
many thanks
Try code 42111
Post Number: 1798
edgar
Username: Roder89
Registered: Sep-09 Posted on Sunday, September 06, 2009 - 04:38 pm:
This VW code is not available for free from anywhere on the Internet.
Main VW Dealer or a Decode Service only
Post Number: 1799
kim mawhinney
Username: Cat88dog
Registered: Sep-09 Posted on Sunday, September 06, 2009 - 03:51 pm:
Your code is 8622
Post Number: 1800
Karen Ramsay
ENGLAND
Registered: Sep-09 Posted on Sunday, September 06, 2009 - 12:52 pm:
Hi,
Model - 22DC278/62B
FD070405072419
RN278F40721419
8200057681TD715
try code 0046
Username: Joey580
thanks it works
Username: Wade22
hi i have a 1996 buick park ave (gmc) dolby b nr radio i cant get to the sereal codes but i do have the codes it tells you when you press 2&3 092 099
the only online place i could find it on was radiocodes.com for 6.95$
Post Number: 1807
You have to quote the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on any labels, barcodes or stamped in the casing
note: $6.95 sounds cheap for a code
Username: Oncutarkan
hi there is any one can help me to find my stereo code? audi a4 1998
7648247380
AUZ1Z3W5915260
4B0 035 168C
Post Number: 1826
tarkan oncu
Registered: Sep-09 Posted on Friday, September 11, 2009 - 10:15 am:
7648247380
AUZ1Z3W5915260
4B0 035 168C
This code is not available for free from anywhere on the Internet.
Only available from your Main Audi Dealer or a Decoding service
Username: Omessaad
I am looking for the unlock code for
Grundig WKC 5300 RDS
serial no :GR0961T0120056
and CODE for
MERCEDES-BENZ
A 168 820 01 79
audio 5 ref no : CQ-LP3920L
SERIAL No 00056
* PA992610100056 *
Post Number: 1830
AMMAR ABDELKRIM
Username: Omessaad
Registered: Sep-09 Posted on Saturday, September 12, 2009 - 07:22 am:
and CODE for
MERCEDES-BENZ
A 168 820 01 79
SERIAL No 00056
* PA992610100056 *
Sorry...too many code requests.
Single code request for personal use only
No traders
Username: Omessaad
Goodmorning
many thinks
Post Number: 1833
AMMAR ABDELKRIM
Username: Omessaad
Registered: Sep-09 Posted on Sunday, September 13, 2009 - 10:01 am:
Goodmorning
You are asking for too many free codes !
SINGLE free code request for personal use only
NO TRADERS
Username: Dekriks
Hi Reg,
I have a Philips BMW Business RDS
22DC785/23F
Serial: PH7850T1254257
KW 23/97 INDEX: 01
Would you have a code for it please?
Post Number: 1838
Stanislav
Username: Dekriks
Registered: Sep-09 Posted on Sunday, September 13, 2009 - 02:51 pm:
Hi Reg,
22DC785/23F
KW 23/97 INDEX: 01
Sorry...not in the database
Main dealer or a Decoding Service only
Username: Paulinhosoares
Hi
Laguna II 2002 with original CD radio (Phillips I believe)
There's a sticker on top of the radio (haven't taken it off yet) which says:
272 K74 3830260
Radio: 2607
KGOJOA27559056
Can you do anything with this? If not where do I find the number you really need?
Thanks in advance.
Username: Decode
POLAND
Post Number: 232
Paulo Segio Oliveira Soares--->post all numbers from radioUpload
Username: Dekriks
Sorry
I have a BMW Business RDS
Philips 22DC785/23F
65.12 – 8 374 583
PH7850V1254257
KW 23/97 INDEX: 01
9022 217 85233 01
003 9723 1254257
Post Number: 1845
tanislav
Username: Dekriks
Registered: Sep-09 Posted on Tuesday, September 15, 2009 - 02:48 pm:
Sorry
Philips 22DC785/23F
65.12 – 8 374 583
PH7850V1254257
KW 23/97 INDEX: 01
9022 217 85233 01
003 9723 1254257
Try emailing
They can normally provide codes for many BMW radios
Mention this forum
Hi
Model number: 22DC279/62Z
and as requested by Michael (14.09.09 - 2 post up):
1: RN279F20354343
2: T0U928
Circled in red: TU928
all help would be brilliant.
Post Number: 1870
Registered: Sep-09 Posted on Friday, September 18, 2009 - 06:18 pm:
Hi
1: RN279F20354343
2: T0U928
Your code is 5700
Hi
Sorry mate, just placed the radio back in the car and this didn't work. Any other codes? might I be doing something wrong? When I press the change button (under the steering controller) for up to 10 secs as instructed, the radio beeps and goes back to CODE after about 3-4 seconds and then i have to wait again. The waiting time is now over 5 minutes.
:o
PLEASE HELP!!
Thanks
Post Number: 1877
Try code 5095
Cheers mate, worked a charm!
Username: Dodo2000
Hi,
I'm looking for the code for my:
Sony MEX-100NV
Serial: 25000598
5 digits with count from 1-7
please help me.
dodo
Post Number: 1911
Username: Dodo2000
Registered: Sep-09 Posted on Wednesday, September 23, 2009 - 06:15 pm:
Hi,
Sony MEX-100NV
Serial: 25000598
please help me.
Sony codes are NOT available for free from anywhere on the Internet.
Username: Dodo2000
hmmm ok thank you for answering.
your dodo
Username: Karol_k
NEED RADIO CODE FOR MY 96 HONDA ACCORD
SERIAL # 93C1015595
MODEL # 39100-SV4-A00
HELP ME!!!!!!!!!!!!!!!!
karolservice@yahoo.com
thank you
Post Number: 1926
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Angelaot
HI i recently bought a chrysler voyager and had trouble with the battery, its asking for a code.
Details as follows:
PART NO: P56038585AQ
SUPPLIER: 17719D
SERIAL NUMBER: TCCAA051229178
MU9CY95G
please help
Post Number: 1932
angela otoole
Username: Angelaot
Registered: Sep-09 Posted on Monday, September 28, 2009 - 05:53 pm:
Details as follows:
SUPPLIER: 17719D
MU9CY95G
CHRYSLER codes are not readily available for free as access is required to the original database.
Try emailing
Mention this forum
Username: Zappycool
Recently I have changed my car battery. After that I can’t play car radio. It’s asking for code. Please help.
Description: Nissan CH916 Clarion PN-9939U Radio Cassette
Serial No. CL0257S0022078
Radio Make: Clarion
Car Make: Nissan
Car Model: Almera
Username: Decode
POLAND
Post Number: 294
Username: Bugz
Hi i need radio code for my 2005 renault megane.
Serial Number: RNRD6950006396
Security Number: 8200483757TR149
Please Help!!
Post Number: 1935
Sarah bateman
Username: Bugz
Registered: Sep-09 Posted on Tuesday, September 29, 2009 - 01:16 pm:
Sorry...not in my database.
Try emailing
Mention this forum
Username: Theclubfather
Melbourne, Foorida
Hi.I have a 2001 Deawoo Lanos. Since my battery went flat, the radio want a code. I don't have it. Please can you help me out, to finding the radio code. Model # (AKF-8846JA) Serial # U1191970 01 Part # 96334688 ID code WY Please reply to my email : vicmer58@yahoo.com Thanks in Advance Thanks victor}
Post Number: 1943
Victor M Mercado
Melbourne, Foorida
Registered: Sep-09 Posted on Tuesday, September 29, 2009 - 04:13 pm:
Daewoo codes are not available for free from anywhere on the Internet
Main Dealer or a Decode Service only
Username: Leinad
Hi i replaced the battery in my renault clio and now I need the code for the radio, could you please help.
Model - 22DC481/62
FD1299299232309
902221481629
7700433070Q913
Regards /Daniel
Username: Millerboy
Hello there!
Renault Laguna
Model number 22DC481/62
S.N 7700433070J498
Product No: FD1099029089957
Another number I have taken is 3265249
Username: Decode
POLAND
Post Number: 299
derek mcqueen---->
Try emailing
radiocodeservice@gmail.com
Username: Decode
POLAND
Post Number: 300
Daniel Bouvin---->9047
If this code has helped you in anyway - and you want to say thanks ,like beer donation:-)...
this is my paypal ( www.paypal.com ) site:
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757
Username: Jocool
Hi I need a code for my Renault clio cd player pls.
These are the no on the side of it.
RNRD5960100044
RENRDW220-60
FD0206270100044
Post Number: 1961
Joanne Cowell
Username: Jocool
Registered: Oct-09 Posted on Sunday, October 04, 2009 - 03:19 am:
RNRD5960100044
RENRDW220-60
FD0206270100044
Sorry.....not in my database
Try emailing
Mention this forum
Username: Tace
Hey again! Could i get a code for my renault scenic:
MAKE: RENAULT
MODEL: RENRDW233-70
K789
SERIAL: RNRD8560045783
PROD NO: FD0106160045783
Thanks a lot! :-)
Post Number: 1968
tace87
Username: Tace
Registered: Mar-09 Posted on Monday, October 05, 2009 - 04:21 am:
MAKE: RENAULT
MODEL: RENRDW233-70
K789
Multiple Code Requests !
Sorry...no traders allowed on this forum
Username: Tace
okay :-(
Fortunately, I gave the codes for free
But thanks to the previous! :-)
Username: Kk1
Hello,
Do you have the code for the following Phillips radio from my Peugot 206?
Model no: 22RC200/65S
Prod no: FD0401240233238
T00419
029018
These characters are also on the sticker:
PHAPMF10233238
REF.PEUGOT:
96 415 230 8002
PHM0233238
Thank you for your help!
Post Number: 1984
KK
Username: Kk1
Registered: Oct-09 Posted on Tuesday, October 06, 2009 - 06:34 pm:
Hello,
T00419
029018
PHAPMF10233238
REF.PEUGOT:
96 415 230 8002
PHM0233238
Try code 1514
Username: Kk1
It worked! Thank you so much
Username: Loximus
Kragujevac
Serbia
Can U help me?? My car is golf 3, 1997
My radio is:
Alpha IV
Volkswagen DC587/71
s/n - VWZ1Z1V0501214
Thanks
Post Number: 1989
Nenad Jankovic
Username: Loximus
Kragujevac
Serbia
Registered: Oct-09 Posted on Thursday, October 08, 2009 - 02:43 pm:
My radio is:
Alpha IV
Volkswagen DC587/71
This VW code is only available from the Main VW Dealer or a Decoding Service
Username: Vou200
Hello,
I have a blaupunkt radio from a Honda Civic
This is all I have!
BP5024T1716866
7 645 024 590
08A01-066-2300-01
(39100-ST3-E410-M1)
thank's
Username: Copi
Hi
The battery died on my wifes Peugout 106 and since replacing it the radio now needs a code.
When we bought the car there was no documentation just a note of the immobiliser code.
If anyone can help
The Radio is a Clarion PU-9971 A
CL0267V0043067
Thanks in anticipation
Post Number: 2032
dimi vou
Username: Vou200
Registered: Oct-09 Posted on Wednesday, October 14, 2009 - 08:15 am:
Hello,
This is all I have!
BP5024T1716866
7 645 024 590
08A01-066-2300-01
(39100-ST3-E410-M1)
thank's
Try code 2091
Post Number: 2033
olin Henderson
Username: Copi
Registered: Oct-09 Posted on Wednesday, October 14, 2009 - 11:16 am:
Hi
If anyone can help
CL0267V0043067
This is an older CLARION radio and requires specialist attention in order to calculate the code.
Email
and they should be able to help.
Mention this forum
Username: Iphone529
Can you help me with a code, the radio manufacturer is DELPHI.
S/N VWZ4Z7H2210118
Post Number: 2049
Duplicate request!
Multi-posted requests are ignored on this forum as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
Username: Zunny
Manchester
UK
Hia. i just bought a replacement 6 cd changer OEM Honda civic cd player from ebay.can anybody help me with the raio code? serial number is HDB 28002202, P/N 39100-SNA-E620-m1, THANKS IN ADVANCE!!! for saving me some $$$$ n time!!my email is zunnys18@hotmail.com
Post Number: 2263
Please note:
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
BLAUPUNKT.
Username: Mintyhighway
Hi, would be extremely grateful if you could supply me with the security code for a ford fusion stereo
serial no is M312931
Username: Decode
POLAND
Post Number: 430
minty highway--->1515
If this code has helped you in anyway - and you want to say thanks ,like beer donation...
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=9592785
Username: Pnda123
need a code for rover 420 1999 phillips stereo cassete player
s/n rg594fx1089785
its bad enough driving the rover but with no stereo its hell
Post Number: 2266
andy livesey
Username: Pnda123
Registered: Nov-09 Posted on Monday, November 16, 2009 - 04:49 pm:
s/n rg594fx1089785
try emailing
Mention this forum
Username: Denismoc
IASI, ROMANIA
ROMANIA
please help me with code for vw gamma IV vwz6z3r1091646
Username: Denismoc
IASI, ROMANIA
ROMANIA
PLEASE HELP ME WITH CODE FOR VW GAMMA IV VWZ6Z3R1091646
Username: Abeid
Mombasa, Coast
Kenya
hi everybody in this forum. am from kenya.kindly seek for assistance.We bought 15 units of axor trucks all have Cd70 model be6053.And are locked with codes i cant find in the trucks. thus kindly asking if can anybody send me code Calculator 5 presets.ma email=abbs008@gmail.com thanks in advance may GOD help.
Post Number: 2273
abeid khamis
Username: Abeid
Mombasa, Coast
Kenya
Registered: Nov-09 Posted on Tuesday, November 17, 2009 - 10:12 am:
SORRY....NO FREE CODES FOR TRADERS
TRY A DECODING SERVICE
On this forum it is a single free code for personal use only
NO TRADERS
Post Number: 2274
SMOC DENIS
Username: Denismoc
IASI, ROMANIA
ROMANIA
Registered: Nov-09 Posted on Tuesday, November 17, 2009 - 05:04 am:
SMOC DENIS
Username: Denismoc
IASI, ROMANIA
ROMANIA
Registered: Nov-09 Posted on Tuesday, November 17, 2009 - 05:45 am:
PLEASE DO NOT MULTI - POST THE SAME REQUEST !
Username: Danskinner
Hi there,
Hope you can help - after a new crankshaft operation my Renault TunerList headunit needs a code to restart but it wasn't included in the docs when I bought the car last year.
Numbers are:
Model Number: REN RDW 133-10
Other: 8200300860TQ903
Many thanks in advance.
Dan
Post Number: 2294
Dan Skinner
Registered: Nov-09 Posted on Saturday, November 21, 2009 - 05:56 am:
Hi there,
Numbers are:
Try code 9040
Username: Vazalfredo
Houston, Tx
Harrys
I HAVE A HONDA ACCORD 93 IS ASKIN ME FOR A CODE
SERIAL: AJ50902452
VIN :1HGCB9870PA000650
alfredo_vazquez0@yahoo.com
Post Number: 2306
alfredo
Houston, Tx
Harrys
Registered: Nov-09 Posted on Saturday, November 21, 2009 - 08:31 pm:
SERIAL: AJ50902452
Duplicate Post...Already answered
WHY post the SAME question TWICE ?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Security Systems > Radio Codes For Free [ « Previous ] [ Next » ]
