Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Quality sound?
Author Thread: Quality sound?
Username: Thelonewolf
Post Number: 152
I am looking for a good sound for my car, will be doing subs sometime along the line. I was looking at Clarion SRQ1630R and JBL GTO637, any thoughts or other idea? amp thoughts?
Username: Exige
CDT, Audiopulse Dealer
Post Number: 665
You can do better. What's your budget for a set of speakers and an amp? Are you willing to do components? This is highly advised in place of coaxials.
Post Number: 155
i do not want to modify this car that the system would be going into, i also do not want to spend a lot on the system, i want it to sound good and go somewhat loud. I am out of date on the tech now a days. what would you recommend?
Username: Exige
Post Number: 672
K start here:
Budget:
Year, Make, Model:
We'll go from there. Gotta figure out the basics though first.
Post Number: 156
2003 Subaru legacy sedan L
i honestly have no idea how much, i can save up because there isnt a big rush. i dont want to be limited by some arbitrary amount i throw out there.
Username: Exige
Post Number: 673
K 6.5" all around. Even if you can save up...you gotta post a budget. In a nutshell...we can come up with speakers costing >$1k for a set. Just a baseline would help out tremendously.
Post Number: 163
ok how about 400ish with an amp?
Username: Exige
Post Number: 681
Ricky can you PM me your email address? I will send you a few options.
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Quality sound? [ « Previous ] [ Next » ]
