Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Speaker advice
Author Thread: Speaker advice
Username: Kungwaz
Post Number: 28
Hi!
I am looking for new speakers for my car. I have decided that my budget will be about $100. I have a head unit with 4x50w output and I need 4 speakers. I want to have a pair of 5,25" in the front doors and a pair of 6x9" in the rear. What could you pro's here recommend for me? Just need a solid beginners system that plays decent
Regards
Daniel
Username: Exige
CDT, Audiopulse Dealer
Post Number: 647
That budget is REALLY low to work with. Can you do any better on it? If you could do $200 total you'd have a lot more options, and some quality ones at that.
Username: Kungwaz
Post Number: 29
I could maybe start with only fronts fr $100 and wait a couple of weeks with the rears. What would you recommend for $200 ?
Regards
Daniel
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > Speaker advice [ « Previous ] [ Next » ]
