Thread: New speakers |
Silver Member Username: Tpizzle
Post Number: 542 Registered: Apr-05
| Posted on Tuesday, August 19, 2008 - 01:07 pm: |
Im looking to get my brother some new speakers for his murcury. He is mostly into rap music and therfore would probably prefer something with bass over sound quality. His current speakers get pretty muddy at high volume levels and I know that bugs him, so some sound quality is important. He has a panasonic deck (50W x 4) and no subwoofer. Please give recommendations for brands and models, since at this point I am not sure the size of the speakers. My budget is about $200 for 4 speakers. Thanks guys |
Silver Member Username: Exige
CDT, Audiopulse Dealer
Post Number: 642 Registered: Nov-07
| Posted on Wednesday, August 20, 2008 - 01:33 pm: |
What year and model is the car? We can figure out what size speakers he needs once we have this info. Consider using an external amplifier rather than the head unit. If he likes rap but doesn't want to go with a sub, consider 6x9's if they'll fit. The important part right now is simply finding out what size speakers he has. Can't really do much til we know that. |
Post Number: 543 Registered: Apr-05
| Posted on Wednesday, August 20, 2008 - 02:17 pm: |
1998 Dodge Stratus |
Post Number: 644 Registered: Nov-07
| Posted on Thursday, August 21, 2008 - 03:06 am: |
The car's speaker setup is as follows: Front speakers Dash: 3-1/2" Front Door: 6-3/4" Rear speakers Rear Deck: 6x9" Based on that, go with a set of 6x9's in the back for the added bass he's looking for (since he won't be getting a sub). To stay within your budget, go with 6.5" coaxials in the front. This recommendation is based on what you said in your original post: no sub, bass is more important than pure sound quality. Now if you're willing to spend a bit more, the ideal setup is a set of 6.5" components in the front and a sub. A small 8" is all that would be needed for your purposes. Consider if you can spend anymore than $200. If so, this second option might become possible. If I can be of any further assistance, feel free to PM me. I'm happy to help out. Mike Exige Audio |
Post Number: 544 Registered: Apr-05
| Posted on Thursday, August 21, 2008 - 03:00 pm: |
Thanks Mike, I appreciate the help. This forum needs more members like you |
