Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > (not for me)audiobahn speakers.
Author Thread: (not for me)audiobahn speakers.
Username: Cd5honda96
OR
United States
Post Number: 96
My mom got some free audiobahn speakers the other day and wants me to put them in for her which is fine, but I have never installed tweeters before and I'm looking for tips on how to go about this.
They are 6 1/2 plus separate tweeter I think and model # is
as 50q(an older version), and going into a 84 Accord.
Thanks for any help.
Username: Nd4spd18
Northwest PA
Post Number: 8257
If the cars front speakers are in the doors, the easiest way to do it is mount the midrange in the factory speaker spot, then cut a hole in the door panel for the tweeter.
If the speakers are in the dash, then you have to get creative and cut a hole in the actual door for the midrange, or if theres not enough depth, make an enclosure that you can surface mount on the door. Which is what I had to do, shown here:
OR
United States
Post Number: 100
Thanks M.S. I'll try it in the next week or so.
Home > Message Board > Car Audio > Speakers > Archive through September 18, 2008 > (not for me)audiobahn speakers. [ « Previous ] [ Next » ]
