Home > Message Board > Car Audio > Accessories > Archive through September 24, 2008 > Need help does a cap have to have it ...
Author Thread: Need help does a cap have to have it own ground and does it mater if dis block power is runing into a output and not a input
Username: Deanf515
Des moines, Iowa
Usa
i have a problem battery keeps draining i have rockrord fosgate cap and DB AMP AND A KICKER AMP HOOKED UP GOING TO A DISTRIBUTION BLOCK BUT MY FREIND PUT THE BATTERY WIRE IN TO ONE OF THE OUT PUTS AND THE THEN RUNS TO THE CAP THEN TO THE AMP IS THIS WRONG PLEASE HELP
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 263
get rid of the cap it only makes things worse.
Username: Glasswolf
Wisteria, Lane
Post Number: 12126
grounds are called "common" for a reason.
any bare chassis metal is generally a ground point, so you can use separate points, or a single common one as a ground.
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2008 > Need help does a cap have to have it ... [ « Previous ] [ Next » ]
