Thread: ~Help choosing components~Already made a List!!! |
Silver Member Username: Cashby
Post Number: 653 Registered: Oct-06
| Posted on Monday, July 28, 2008 - 07:38 pm: |
Hey guys, Im looking for a 2 way component set(6.5") for 1998 s-10 Regular cab. It is my winter/beater vehicle so i will not be putting a sub in. BUT i want a component set that has a woofer that really adds some good clean bass, and i want a tweeter that is not to tingy/harsh BUT still has a really precise and clean sounding high. I will be purchasing an amp to power which ever component set i decide to go with. So i compiled a list of ones that i have researched about and heard somethings about and i listed them below..My goal is to keep just the component set under $200 and the amp for them will be on a seperate budget. Also if you guys no of any other good set-up's that are under 200 please let me know. Also i have heard that CDT makes good components, so if they have one for under $200 let me know! Thanks a bunch guys! http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D190239096091&ssPageNam e=STRK:MEWA:IT&ih=009 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=007&sspagename=STRK% 3AMEWA%3AIT&viewitem=%26item%3D170243846132%26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D280248023292&ssPageNam e=STRK:MEWA:IT&ih=018 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D130241824364&ssPageNam e=STRK:MEWA:IT&ih=003 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3372 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6201 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4965 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6843 |
Post Number: 655 Registered: Oct-06
| Posted on Monday, July 28, 2008 - 09:48 pm: |
THESE ARE THE ONES THAT DO WORK..USE THESE LINKS!!!!!^^^^^^^^^^^^^^^^^ http://www.woofersetc.com/index.cfm?...roduct_ID=4927 http://www.woofersetc.com/index.cfm?...roduct_ID=6598 http://www.onlinecarstereo.com/CarAu...roductID=17540 http://www.onlinecarstereo.com/CarAu...roductID=12428 http://www.woofersetc.com/index.cfm?...roduct_ID=3372 http://www.woofersetc.com/index.cfm?...roduct_ID=6201 http://www.woofersetc.com/index.cfm?...roduct_ID=4965 http://www.woofersetc.com/index.cfm?...roduct_ID=6843 |
Silver Member Username: Exige
CDT, Audiopulse Dealer
Post Number: 588 Registered: Nov-07
| Posted on Tuesday, July 29, 2008 - 03:38 am: |
Sent you a PM regarding CDT since you were asking. Got much better pricing for you  |
