Thread: Wires. |
Bronze Member Username: I0s
Post Number: 29 Registered: Jun-08
| Posted on Friday, July 25, 2008 - 10:33 pm: |
Where do you go about getting the necessary wirees to hook up a system? Do the subs generally come with wires? HUs with wires? Amps? And what are the good brands to look at? Thanks in advance. |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
Post Number: 248 Registered: Mar-08
| Posted on Friday, July 25, 2008 - 11:17 pm: |
www.knukonceptz.com subs dont come with wire, nor amps. HU's have about a foor of wire to connect to stock wiring, thats it. hope this helps. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 17585 Registered: Jun-06
| Posted on Saturday, July 26, 2008 - 01:10 pm: |
I have a wide variety of wire and power cable available at cost for E members only. 2ga, 4ga, 8ga, 12ga. Whatever you need that I have I sell dirt cheap. When you decide on what you need let me know and you wont regret it. I have ED 4ga. Good wire. 17' lengths of Raptor 2ga with ring terminal one one end. Not great wire but well worth what I charge. Audiopipe 8ga. Very good wire IMO. Stinger 12ga speaker wire. More good stuff. Lengths of Raptor 8ga. In blue or silver. Worth what I charge. The size of wire is based off the size of your equipment. Bigger amps require larger wire for power and ground as well as the big three upgrade if necessary. I only have 6' or so left of ED 1/0ga. Very good stuff. |
