Thread: Mtx tc6001 blows rf p3 without playinng music |
New member Username: Quebasa
Post Number: 1 Registered: Jul-08
| Posted on Friday, July 25, 2008 - 01:22 am: |
i hooked up my mtxtc6001 amp to my sub turned the car on no music playing amp started making weird noise and fried my rf p3 anyone know why this happend |
Bronze Member Username: Elandman
Post Number: 11 Registered: Jul-08
| Posted on Friday, July 25, 2008 - 10:04 am: |
Possibly reversed polarity on power maybe??? |
Bronze Member Username: Neptune07
Grand Junction/Golden,
CO
Post Number: 100 Registered: Jun-08
| Posted on Friday, July 25, 2008 - 10:32 am: |
please tell me you didn't hook anything up without disconnecting the negative terminal on your battery... |
Post Number: 2 Registered: Jul-08
| Posted on Friday, July 25, 2008 - 03:24 pm: |
i did disconnect then i connected everything to the amp put the ground back on the battery turned the car power on the amp powered up then started making weird noises like popping noises also the power and ground wire from the amp got hot i have no idea what caused it the amp just started sucking alot of current and fried my voice coils on the sub |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1876 Registered: May-07
| Posted on Friday, July 25, 2008 - 08:03 pm: |
Sounds like the coils were out of phase with each other. |
Post Number: 4 Registered: Jul-08
| Posted on Friday, July 25, 2008 - 09:03 pm: |
oh so is it safe to try the amp on another sub |
Platinum Member Username: Insearchofbass
Post Number: 10012 Registered: Jun-04
| Posted on Saturday, July 26, 2008 - 08:16 am: |
Phasing of the sub will not cause the problem you had. Take this situation to a car audio shop in your area. |
